Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Oct 21, 2015 at 2:16 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Fuck you.
    UNDEAD1153 likes this.
  2. Oct 21, 2015 at 2:18 PM
    Kerleyfries
    Zack
    Lebanon
    Does everyone with lifted rear ends have axle shims? Pretty sure I've already chewed through both of my ujoints and my CB because it is squeaking like a motherfucker.
  3. Oct 21, 2015 at 3:24 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Yah you're on the small side of a cmc. Me too. I actually cut mine more at AOP. Haha
    redtacoma88[QUOTED] likes this.
  4. Oct 21, 2015 at 3:24 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Hahaha that was pretty good
    rhion82 likes this.
  5. Oct 21, 2015 at 3:26 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Did you do the things I suggested? Mainly grease the joints and flip the bearing? And yes you will wear out that bearing very fast without correction for it for lift. You will wear it out even faster if it isn't oem
  6. Oct 21, 2015 at 3:29 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    I don't have shims but I only have a tsb pack with aal
  7. Oct 21, 2015 at 3:39 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Ok .......
    Let's start with the 4wd. Both 4hi and 4lo. Switch into 4hi while driving any speed under 70. The light will flash a few times then stay solid. You should get a noise from the actuator engaging and some kind of clunk is not uncommon. The only thing you are looking for is for it not to engage (the light will stay blinking). Try this a few times to make sure it didn't just work once as a fluke. Check 4lo at a complete stop with the pedal literally to the floor. It won't engage otherwise. If it beeps at you then you didn't do it right. Once again, just make sure it works. Check the front axles for tears in the boots or signs of them leaking grease. If they are then obviously you "need" to fix that. Check for signs of it being wheeled. Visually of coarse. Also check the driveshaft play. Both rotationally and up and down in the carrier bearing.
    That's all I got for 4wd specific. Obviously that's quite a bit of miles in 5 years but if they are street miles and the truck is stock then my guess is it's not abused much. I hope you like it though ....... Haha
    What color is it?
  8. Oct 21, 2015 at 3:50 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Wooly's. Never been there tho.
  9. Oct 21, 2015 at 3:55 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Perfect. Thanks. Speedway blue. Regretted not getting it from day one.
  10. Oct 21, 2015 at 4:20 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    I can't wait to see what has to be done for 36s
  11. Oct 21, 2015 at 5:10 PM
    Kerleyfries
    Zack
    Lebanon
    Haven't flipped the bearing. And whatever joints are in there don't have fittings at all. The new joints I have in my toolbox have fittings on them, but that does me no good for the squeak as of now
  12. Oct 21, 2015 at 6:01 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
  13. Oct 21, 2015 at 6:12 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Nice man! And I fucked up 1 word so let me say it again. When 4wd is engaged the light will STOP blinking and stay solid. That's what you are looking for. If the light stays blinking then you have problems and there are a few things it could be from a price range of >$100 to <a few thousand.
    Also more specifically, 4hi has to be engaged before 4lo will work. If you turn the switch to 4lo and it beeps AT ALL then turn it back to 4hi and then try again. It's also not uncommon to find that you need to be rolling for 4hi to engage and also that you need to be rolling for 4hi to disengage. Once again a clunk, maybe even felt like something just messed up, is not uncommon. Engaging at all is the big thing
  14. Oct 21, 2015 at 6:30 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Anyone at Memphis area have stock rear shocks I could get on Thur or Fri? I've got my old ones but there are vice grip marks and missing boot on one of them.
  15. Oct 21, 2015 at 6:41 PM
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    I have my stock rear shocks. I'm in Jackson though.
  16. Oct 21, 2015 at 7:21 PM
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    I've heard of wooly's. I need to add that to the list.
  17. Oct 21, 2015 at 7:22 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Let me know when you want to go and if I'm free I'll join in.
  18. Oct 21, 2015 at 7:24 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Sweet. If no one closer offers, i may need to meet you Fri night.
  19. Oct 21, 2015 at 7:24 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Yep, me too.
  20. Oct 21, 2015 at 7:29 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Dave, have you been able to put many miles on the 255s? What's the verdict? Or is the jury still out?
    Kerleyfries likes this.
