Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Oct 26, 2015 at 2:15 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Lincoln locker is the cheapest locker
  2. Oct 26, 2015 at 2:24 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    I've got four power door lockers? Can even control it with my key fob.
  3. Oct 26, 2015 at 2:29 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Nope. Doesn't work. That's a door lock. Not a door locker. Try again
  4. Oct 26, 2015 at 2:29 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Wish harder. It's a rule now soooooooooooo
  5. Oct 26, 2015 at 3:16 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    It takes more skill to ride without one....that's all I'm saying haha
  6. Oct 26, 2015 at 3:20 PM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    Okay this could be a shot in the dark, but doing some trail riding over the weekend I heard a light clank in my front end, seemed like the passenger side. It happend repetitively over nearly every small rock on the trail, which was the whole time. I don't notice it on the street. Does it sound like a LCA bushing or maybe a wheel bearing??
  7. Oct 26, 2015 at 4:40 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Fixed it for you...
    rngr and beertimecontinuum like this.
  8. Oct 26, 2015 at 5:35 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I agree with this. Haha
  9. Oct 26, 2015 at 5:57 PM
    beertimecontinuum
    Everett
    I've got at least 15 mins of video that shows this no-locker having, reverse and try again carnage. @Skootter14 , we don't look very badass. I may not upload it lol
  10. Oct 26, 2015 at 6:21 PM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Lol
  11. Oct 26, 2015 at 7:28 PM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Your tires holding air?
  12. Oct 26, 2015 at 8:00 PM
    beertimecontinuum
    Everett
    Yeah, no issues so far. Will still get them broke down and cleaned before too long. Alignment isn't bad either. Any info on those inner tube style bead locks? Need to research that if you can recommend a place to start.
  13. Oct 26, 2015 at 8:21 PM
    Skootter14
    Jeremy
    Haha o well. At least we "try" to keep,up with the best of 'em. Reverse or not, we still make it happen
    Thanks Dave haha
    Dave41079 likes this.
  14. Oct 26, 2015 at 8:35 PM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Staun beadlock, and you can find them all over, I'd suggest researching and reading about them before you pull the gun
  15. Oct 27, 2015 at 4:20 AM
    Dave41079
    Dave...
    Nashville, TN
    I like to think of it as you keeping things lively.
    Skootter14[QUOTED] likes this.
  16. Oct 27, 2015 at 4:23 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    A wheel bearing goin out does not make a clank noise. It will make a humming noise and you can check for this very easily. While driving swerve left to right. If you hear the noise only while turning left then it's the right bearing and vica-versa. It could be lca bushings. It could be a few things. You have ucas? And coilovers?
    redtacoma88[QUOTED] likes this.
  17. Oct 27, 2015 at 7:10 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    When lifting 4x4, how do you know whether a dif drop is needed?
    When installing longer brake lines, anything special about the TRD OR brakes? Just same normal bleed steps?
  18. Oct 27, 2015 at 7:38 AM
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    If I am not mistaken 2nd gens do not need the diff drop.
  19. Oct 27, 2015 at 8:09 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Need is a relative term. I ran a diff drop for 6 years with no problems. Some people will swear by "you're an idiot, it will fuck your truck up". This isn't the first time I've done something someone said that to and came out just fine. I did however take it off over a year ago and some irony arose in my doing so, which I'll explain in a min.
    Theres one thing a diff drop does: rotates the front of the diff downwards to help compensate the high axle shaft angles when lifting your truck. Amazingly it does just that, which in turn does 1 thing very well: keeps your axle boots from wearing prematurely. Because of where the spacers are used (placed between the front cross member and front diff mounting brackets) it lowers the brackets down probably 1" - 1 1/2". This is the reason I took them off last year. I was going to build a higher clearance skid and bumper but have yet to get to it. The skid I have now contacted the diff mounting brackets with the spacers in but not with them removed. Consequently this resulted in my axle boots wearing out very fast and leaking grease out. Now take that view with a grain of salt as those boots now have almost 8 years on them of being covered in mud, sand and gravel BUT ....... when I took the spacers out I quickly saw a new wear pattern on the boots where the fins touch and that's where the rip came from.
    So from my experience of running one for 6 years, and not just cruising the mall parking lots at 8:55 pm on Friday night, I've learned that in no way shape or form did the drop hurt my truck or cause any acute or chronic damage to it. If anything it helped my truck by keeping my axle boots from wearing holes in them. The one "bad" thing it did was lower the front mounting brackets to where if I want to build a skid for the most clearance possible then it's in my way.
  20. Oct 27, 2015 at 8:21 AM
    redtacoma88
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    Yeah Im gonna have to get under the truck this weekend. Yeah I have LR UCAs and OME 885s with top plates (getting 886x soon).
