Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Nov 17, 2015 at 5:52 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Moog. My cam bolts were seized and had to replace bushings and bolts. Used the Moog problem solvers with qrease fitting. Holding up nicely.
    redtacoma88[QUOTED] likes this.
  2. Nov 17, 2015 at 5:55 PM
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    I've seen a complete moog replacement of the LCA w/BJ and bushings on RockAuto for $130 each. Have not seen any reviews on them on here.
  3. Nov 17, 2015 at 6:14 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    New headlights in!! They make the truck look brand new again. I will be sticking LED's in these things asap.
    beertimecontinuum and rngr like this.
  4. Nov 18, 2015 at 6:10 AM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    I had to replace lca bushings on my civic a couple months ago, I just bought new lca's was much mo easy
    redtacoma88 likes this.
  5. Nov 18, 2015 at 6:47 AM
    beertimecontinuum
    Everett
    Definitely the easiest way to go.
    Kerleyfries likes this.
  6. Nov 18, 2015 at 7:41 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Obviously you know this but that's not an oem lca. I'm sure it will work fine but like most non oem items, just won't last as long. There's some things that oem is the ONLY way to go (like a carrier bearing). I'm not sure if an lca is like that or not but I would think the only downside may be strength in design/material.
  7. Nov 18, 2015 at 7:43 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Sooooooooooo hot!! Want to touch the hiney!!
    11TRDTX[QUOTED] likes this.
  8. Nov 18, 2015 at 8:46 AM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Just go +2 LT that will get you new uppers and lowers!
  9. Nov 18, 2015 at 9:01 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    if anyone wants 2 new ujoints, they're greaseable duralast ones, you can have them. I bought them like a month or two ago and never got around to putting them in, and now they're about to build my driveshaft and just put all new ujoints in it so I have no use for these.
  10. Nov 18, 2015 at 10:41 AM
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    I'll take them. Mine have seen better days
  11. Nov 18, 2015 at 11:06 AM
    Kerleyfries
    Zack
    Lebanon
    SOLD! to "the dude" for the price of free. You got any plans to be in Knoxville or Nashville anytime soon?
  12. Nov 18, 2015 at 11:09 AM
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    I will not be in knox until Thanksgiving. I can send you money for shipping though if it helps.
  13. Nov 18, 2015 at 11:09 AM
    Kerleyfries
    Zack
    Lebanon
    If you aren't in a rush, I can meet you then. Other wise I'll ship them when I get my truck back from the driveshaft shop.
  14. Nov 18, 2015 at 1:29 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Hes that guy. Haha
  15. Nov 18, 2015 at 2:09 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    so my rear leafs are squeaking like a BITCH (I also havent washed the truck thoroughly since the trip). One of the leaf packs is damn near flat. the shocks themselves are about 15kish and although I want to get a new rear susp set up (all poo 10/11 leaf pack with some fox or kings rear shocks) just not yet. Do you think actually washing the rear and spraying water between the leafs to get crud out will fix that or is it just getting that time that the factory leaf (with an AAL) is wearing out (after 62k miles)????
    EDIT: I should probably also mention that where the OEM leafs are near flat, they are almost starting to bend OPPOSITE the AAL which is the concern to me...can they snap/break off like 12" from the mounts(on both ends)??? cuz thats what I see the worst case happening
  16. Nov 18, 2015 at 2:53 PM
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    Wow you got a pic?
  17. Nov 18, 2015 at 3:48 PM
    Kerleyfries
    Zack
    Lebanon
    Mine did the same thing. Fuck the factory leaf packs. Especially with the amount of weight you've got on it. Lol. Long bed plus your whole swing out setup. If you just want to deal with the squeak, power wash them out and soak them bitches in wd-40. I didn't like the fact that mine were starting to umbrella so I swapped them out
  18. Nov 18, 2015 at 4:35 PM
    Skootter14
    Jeremy
    ill try to snag a pic tomorrow, to me it looks pretty bad haha
    and yea that weight def isnt helping. I think im gonna start saving for the standard all pro leaf pack and Fox 2.0's (with the res) unless that is a bad option (are those rebuild-able or anything cuz its like 700$ +/- which is a shit ton considering I bought my original 5100 set up (with coils, AAL, 3* shim, and 4 5100's) for 600$).
  19. Nov 18, 2015 at 5:45 PM
    Kerleyfries
    Zack
    Lebanon
    The res's will just help with heat dissapation to my knowledge. (someone else chime in)
  20. Nov 18, 2015 at 6:16 PM
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    My mesh for my grille came in today. Going to install it this weekend hopefully
    beertimecontinuum likes this.
