Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Dec 7, 2015 at 8:04 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Bull Bars are popular here!
    Anyone know the rock or metal radio stations near Nashville? All I find is rap or country.
  2. Dec 7, 2015 at 8:10 PM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    105.9 the rock
    DustStorm4x4[QUOTED] likes this.
  3. Dec 8, 2015 at 4:24 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I'm surprised you can find rap. Haha
  4. Dec 8, 2015 at 4:56 AM
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    102.9
    98.3
    105.9
  5. Dec 8, 2015 at 4:57 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    102.9 is all types of rock. 105.9 is classic rock. I wish there was a metal station, but there is not.
  6. Dec 8, 2015 at 6:01 AM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    It's 2015, stream that shit :)
    UNDEAD1153, rngr[QUOTED] and 11TRDTX like this.
  7. Dec 8, 2015 at 6:02 AM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Less rear brakes, more smokey Joe burnouts
  8. Dec 8, 2015 at 6:12 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    I do.
    I also still use cd's :anonymous:
  9. Dec 8, 2015 at 6:15 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I still do too. But since I'm an audiophile, CDs get expensive.
    I only have a couple CDs that I got(\stole:bananadance:) from friends
  10. Dec 8, 2015 at 6:21 AM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    I typically keep my old iPhone in my truck hooked up via Bluetooth. I have some cds still but my attention span is too short to listen to that many songs from the same artist in a row lol and I f'n hate the radio with a passion
    DustStorm4x4 likes this.
  11. Dec 8, 2015 at 7:28 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Best solution iPad in dash and Apple Music
  12. Dec 8, 2015 at 7:47 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    rap is universal. there is no escape.
    no rotten apples in my truck...
    still in free trial period of XM. #40 Liquid Metal :D
    DustStorm4x4 and 11TRDTX like this.
  13. Dec 8, 2015 at 7:54 AM
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    Just got an alignment this morning. They came back with these numbers and I was like "i'm sorry what?" It took an hour and a half for them to get these numbers. They did not make me pay. I am actually rather surprised though. It tracks totally straight. Didn't wander on the highway up to 70 when I tested it out. Tire is basically centered in the wheel well.
  14. Dec 8, 2015 at 8:02 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    1st gen problems.
  15. Dec 8, 2015 at 8:09 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    yeah...
    I've found some different ideas on what's best.
    Too bad none of the engineers I know from auto industry ever did drive train work.
    Video from toyota says 1st shaft piece should be almost in line with transmission. I think it said 0.8 +/-1 degree. Not perfectly in line though because then fluid won't flow to fully lube the ujoint bearings as it spins. Then make the relative angle between axle and rear shaft section be same as relative angle between the 2 shaft pieces. That method helps maximize ground clearance as well.
    Spicer generally says keep true ujoint angle (side and top view compound angle) at 3 deg or less. But, they have a chart with actual max angle based on RPM. They suggest 1 to 1.5 relative between 1st shaft & transmission and then get the axle parallel to first shaft piece.
    Then there are a handful of other sites with suggestions.
    Raising the center bearing to get the 1st shaft almost aligned with the transmission put too much angle on the back shaft relative to everything else so I'm trying to balance it all out in a different way.
  16. Dec 8, 2015 at 8:12 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    They didn't make you pay? Why not? And don't you have stock ucas? If so then I'd say those numbers are good. Most ucas have 3° built in caster
  17. Dec 8, 2015 at 8:16 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I use an app called Tune-In Radio. It's like XM but free. On stations that play continuous music it has a 30 sec commercial every 30 mins or so. On live stations it obviously plays the normal commercials.
  18. Dec 8, 2015 at 8:23 AM
    UNDEAD1153
    UNDEAD1153 Well-Known Member
    Weston
    Chattanooga Tennessee
    White 2011 TX Pro Double Cab
    Rough Country 6" lift, 17" XD Addicts, 315/70/17 Nitto Trail Grapplers, 6K HID's, Wet Okole's, Kenwood DD head unit, Custom Exhaust
    So I know it's not a yota but...my 4" turbo back rubs like crazy. I know it's rubbing a bolt that holds the crossmember in. I can move it away from the bolt but it just slides back to the original spot and rubs again. Is there any reason an exhaust pipe would need to move freely? I have an idea of moving the pipe away from the bolt and welding a rod to the frame and to the pipe so that it can't slide back to rub up against the bolt. I know it's rubbing there, but I'm afraid it might also be rubbing the firewall and I'll have to figure out how to move it away. Any ideas or suggestions? I don't remember it rubbing when I first got it back from the shop, but as time has passed, it has gotten progressively worse. I went to the bonfire spot up here in cookeville this past weekend and as much as I was flexing going through the trail, it got so bad that it constantly rubbed over every bump and anytime it gets above 2k rpm's. It's extremely annoying and the noise breaks my heart every time haha. I just want to get this fixed ASAP.
  19. Dec 8, 2015 at 8:34 AM
    TacoBurrito07
    Jake
    Arizona
    Yeah they said since they couldn't get it in specs they wouldn't let me pay. I tried. I was handing the guy my card but he refused to take it.
    Yeah I have stock UCAs but most people are able to get at least in spec at 2"-2.25" and many people report up to 2.5" being in spec. I am just below 2".
  20. Dec 8, 2015 at 9:50 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    First thing I'd do is make sure you don't have a loose bolts or broken/bent brackets anywhere that has caused parts to move out of position. When you push the pipe back out of the way, can you see anything moving with it more than it should?
    You need some movement of the exhaust pipes so the normal flex of everything else doesn't put extra stress on headers, turbo, or whatever else by pushing on the pipes too much. That's why we have those rubber exhaust hangers, rubber mount under transmission on crossmember, and so on.
    If you do want to weld a rod in to pull the pipe back, I'd suggest doing a 2 piece bracket with one of those rubber exhaust hangers to join them so that it can still move a little when needed. A rigid connection might crack something over time.
    UNDEAD1153[QUOTED] likes this.
