Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Dec 22, 2015 at 8:09 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    How much gap do you guys have between body and sliders rail? Parked next to a FJ yesterday and he had maybe 2 inches body clearance from sliders. I've got about 1/2 inch. Pictures I found looks like it can vary on Tacomas but hard to tell from camera angles usually.
  2. Dec 22, 2015 at 8:18 AM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    I think I did about a half inch on mine
  3. Dec 22, 2015 at 8:21 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    About 1" on mine. It should be fine as long as there isn't enough flex under load to make it contact the body. I'd put a jack under it and go up real slowly to make sure it doesn't touch. Mine flex a tiny bit, but not 1/2" worth.
  4. Dec 22, 2015 at 8:23 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    hahaha. that would either be funny as hell or really bad.
  5. Dec 22, 2015 at 9:02 AM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I thought u saw "Wilbur" when u stopped by the house. He's a corn snake, bout 2 ft long now.
    Dave41079 likes this.
  6. Dec 22, 2015 at 9:55 AM
    vvmountainvv
    vvmountainvv Well-Known Member
    TN
    14 SR5 4x4
    well took they swapped the front L and R, and the pull nearly totally went away. They wanted to look at the tires again after I drove it like that....and still ended up wanting to give me 4 new tires. Who am I to argue? They were cagey about telling me if they found something specifically wrong so it's hard to say. But 4 new tires....something must have been wrong that they found is my guess. Asked me if I wanted same size and model....after thinking it over I'm sticking with the AT2's. Glad to have a good tire center helping out. Hopefully the new set solves all issues.
  7. Dec 22, 2015 at 10:22 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I still don't get how you can have a bad trip. It's all in your mindset but why trip if you are sad, mad or depressed knowing it won't be fun. Makes no sense to me.
  8. Dec 22, 2015 at 10:23 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    About 1/2". I also based location on being able to open my back doors with out scraping the sliders
  9. Dec 22, 2015 at 10:32 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    No I didn't. I now remember y'all mentioned it though. I've never owned such a small snake. Seems easy to lose. I like my big snakes so when they escape they are easy to find ......
  10. Dec 22, 2015 at 10:47 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    You know you in the hood when.........
    you out in the front yard playing with your snake in your PJs.
    hahaha sorry i couldn’t resist.
  11. Dec 22, 2015 at 2:18 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    I play with my snake in my pjs all the time.
    TnRedNeck721, Skootter14 and 11TRDTX like this.
  12. Dec 22, 2015 at 3:07 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Freak
    Dave41079[QUOTED] likes this.
  13. Dec 22, 2015 at 3:07 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Hahaha that was pretty good. But yes. You right
  14. Dec 22, 2015 at 3:45 PM
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    Do I need to change the front differential fluid after 30k?
  15. Dec 22, 2015 at 4:04 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Sig worthy^^^
  16. Dec 22, 2015 at 6:04 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    I'm glade you found that funny.
  17. Dec 22, 2015 at 6:40 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    So, question for y'all... Obviously I fucked up building these headlights because my passenger side is tilted and aimed a little high. The drivers side is absolutely spot on perfect though. I tried to get over it but they're really starting to piss me and my OCD off. I'm ready to sell these things or tear them back apart but don't know how well trying to get all this fucking jb weld off would go. Anyone think I could get anything out of them money wise or should I just slowly try to deemed through this jb weld? Pic of the beam attached.
  18. Dec 22, 2015 at 8:14 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    I have almost the exact problem, idk what exactly is wrong but something happened when my tire fell off and the driver side aim is off now. I'm a pussy though and don't want to pull them apart, I didn't build them so I have no idea what I'd be doing lol
    I will probably end up doing it though since they're fucked right now, had to pull them off the truck after the bucket the dtrl sits in melted to the point it pushed the bulb out of the socket and I obviously couldn't get it out so I had to break the bulb and scrape the melted shit away to get it out. Now it's full of shit from that and the driver side is close to doing the same thing
  19. Dec 23, 2015 at 4:30 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Man those damn things are bright!!! And you jb welded the lens cover back on? That seems kinda extreme. Haha if you can get it apart, it should be pretty easy to rotate it slightly. If you sold them, someone would be doin the same thing I'm sure
  20. Dec 23, 2015 at 4:35 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yes. Also remember that the miles isnt the only thing you need to consider. Time may be a more determining factor. Oils molecular bodies don't last for forever.
