Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Feb 25, 2016 at 11:01 AM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
  2. Feb 25, 2016 at 11:03 AM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Shit my bad thought we was still talking CVS haha
  3. Feb 25, 2016 at 1:22 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    What kind of lift are you trying to do?
  4. Feb 25, 2016 at 1:59 PM
    vvmountainvv
    vvmountainvv Well-Known Member
    TN
    14 SR5 4x4
  5. Feb 25, 2016 at 2:17 PM
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    24mm if my memory is right.. and get mt-90 if you can..
    vvmountainvv[QUOTED] likes this.
  6. Feb 25, 2016 at 3:57 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Just to have a welding machine available around the house to tack or repair stuff, is the $130 flux core machine from Northern Tool or Harbor Freight ok?
    Says 80 amp at 115v, 20% duty cycle. I've only got standard 115v outlet available to run one.
  7. Feb 25, 2016 at 4:02 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    I've got a nice ass Miller I'll sell you.
  8. Feb 25, 2016 at 4:05 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    If that nice Miller is also $130. :cool:
  9. Feb 25, 2016 at 4:18 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    . . . Im pretty cheap
    11TRDTX likes this.
  10. Feb 25, 2016 at 4:20 PM
    Skootter14
    Jeremy
    Also, I've decided to go with the 2.5 factory series w/ resi.
    With the TW discount, they go from 1600 to 1360, and the non resi was 1300 reg price (1125 after discount). so I talked heather into 1300ish being acceptable.
    Cant wait to install (hopefully I can just rebuild these as needed and not buy new ones for a while)
    Dave41079 and 11TRDTX like this.
  11. Feb 25, 2016 at 4:27 PM
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Had to have that bling with the resi's? :rolleyes:
    Skootter14, Kerleyfries and rhion82 like this.
  12. Feb 25, 2016 at 5:13 PM
    Kerleyfries
    Zack
    Lebanon
    No, but I'll sell it to you a lot cheaper than it should be. And it's a hell of a lot better ;)
  13. Feb 25, 2016 at 5:39 PM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Nice I had to get Katie to go along with my last truck purchase... Her deal was as long as I finish laying the floor and prep the walls for. Paint she didn't care haha
  14. Feb 25, 2016 at 5:40 PM
    Skootter14
    Jeremy
    every new item seems to be some sorta drug deal scheme haha
    rngr and Utah Off-roader like this.
  15. Feb 25, 2016 at 5:41 PM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Pretty much haha
    Skootter14[QUOTED] likes this.
  16. Feb 25, 2016 at 6:40 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Damn fuckin right he did!! Good job Jeremy. Make sure to get the extended version and get them to custom valve them. Who are you buying through? I know DSMS and SDHQ will both valve for free
  17. Feb 25, 2016 at 6:43 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    That was the first welder I ever bought. Got it when I was 16 along with their hydraulic pipe bender and GSM was born with me and my buddy building a 6 point roll cage in his supra (first drift supra we built). It worked but it didn't last long. I'd say if you actually follow the 20% duty cycle then it may last longer then mine
  18. Feb 25, 2016 at 6:50 PM
    Skootter14
    Jeremy
    I am going through DSMS and they are the extended ones. What is this about valving and how do I get them to do it for me and what settings do I request?
  19. Feb 25, 2016 at 7:07 PM
    Utah Off-roader
    Utah Off-roader Well-Known Member
    Middle TN
    StormTrooper '14 DCSB
    Diff Breather OME full lift kit with 886 coils and dakars sway bar removed 31.5" LED light bar from CaliRaisedLED
    The lift I'm going to get is Bilstein 6112 with 700# springs up front with Toytec's top mount for a true 3" lift and Bilstein 5160 for the rear with dakars. Hoping to order it after my house sells now lol. But the way things are going I'll be lucky to actually be able to order it.
  20. Feb 25, 2016 at 7:36 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Call them when you order. They are smarter then me so I will let them help you. Tell them what you do with your truck. I told them I drive on the street and all my offroading is 20 mph or less on woody, rocky, muddy trails. Tell them how much weight you carry (tube bumper, skids, v6 and they will know what spring rate you have. That info will give them what they need for the right shim stack to get your rebound/compression somewhat right.
