Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Apr 23, 2016 at 6:59 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Recheck that everything is tight. Go back to gateway and show them the weights fell off, and have them redo the alignment if they did indeed leave the lca cam bolts loose. If they're loose, the alignment moved.
  2. Apr 23, 2016 at 7:03 AM
    Strikersteve57
    Strikersteve57 Well-Known Member
    Stephen
    Memphis,Tn
    2013 spruce mica Trd off road Prerunner
    3" Toytec suspension lift, 285/75/16, grill guard
    I'm here now getting the weights back on and getting them to check all of them and I'll check it when I get home cause they didn't do the alignment so Ima come back Monday and get them to do it just to make sure everything is okay
  3. Apr 23, 2016 at 7:31 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Gotcha. Sorry, i miss read :anonymous:
  4. Apr 23, 2016 at 7:35 AM
    Strikersteve57
    Stephen
    Memphis,Tn
    Your good hell half the time what I think I said and what I say if completely different
    11TRDTX[QUOTED] likes this.
  5. Apr 23, 2016 at 7:41 AM
    Strikersteve57
    Stephen
    Memphis,Tn
    Well guys they just told me that they were all out of balance!! But it should be good now
    11TRDTX likes this.
  6. Apr 23, 2016 at 8:16 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    What are you running?
    :worthless:
  7. Apr 23, 2016 at 8:18 AM
    Strikersteve57
    Stephen
    Memphis,Tn
    I got 285/75/16 yoko geolander a/t
  8. Apr 23, 2016 at 9:24 AM
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    Everything came in this morning.
    Utah Off-roader and 11TRDTX like this.
  9. Apr 23, 2016 at 9:50 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Old ones seized up?
  10. Apr 23, 2016 at 10:18 AM
    TacoBurrito07
    Jake
    Arizona
    Yes. Bushings are shot as well. I don't know exactly what's seized up. It might only be one part on either side but I'm just not sure so I figured I would just get new everything, grease it up real good and not have to worry about it anymore. Also I don't want to get everything apart and then realize that I need something.
    11TRDTX likes this.
  11. Apr 23, 2016 at 10:18 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    You go with the OEM parts? What was the price for everything?
  12. Apr 23, 2016 at 10:24 AM
    TacoBurrito07
    Jake
    Arizona
    Yeah OEM. It was not cheap. $245 total for both sides after tax. I think just the cams were like $50 each.
    He even worked out a deal with me. Gave me about $50 off
  13. Apr 23, 2016 at 11:46 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Forgot how annoying it is to remove lights.
    11TRDTX and Strikersteve57 like this.
  14. Apr 23, 2016 at 11:54 AM
    TacoBurrito07
    Jake
    Arizona
    Woah. I did not have to take the bumper off to remove them. I had to contort a good bit to get that screw out but it was doable.
  15. Apr 23, 2016 at 11:59 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I tried that on 1 but couldn't wiggle the light out.
    Much easier with bumper cover out of the way.
  16. Apr 23, 2016 at 12:15 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Leave the bolt out that is hard to get to. That's what I did...
    TacoBurrito07 likes this.
  17. Apr 23, 2016 at 12:51 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    With bumper off now, that bolt is super easy to reach. :D
    11TRDTX and Dave41079 like this.
  18. Apr 23, 2016 at 1:19 PM
    TacoBurrito07
    Jake
    Arizona
    I left it out as well
  19. Apr 23, 2016 at 2:31 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    "truck don't need all that damn shit!"
    totmacher likes this.
  20. Apr 23, 2016 at 3:18 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    None of it.
