Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jun 15, 2016 at 6:57 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Looks like humidity problems to me. I know it was 1000% humidity here today. Temp was 95 and heat index was 114
    lowinhz[QUOTED] and Dave41079 like this.
  2. Jun 15, 2016 at 7:07 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Agree, either humidity or some kind of oil on the surface. Brake cleaner will also work to clean off the surface for paint after you scuff it.
  3. Jun 15, 2016 at 7:10 PM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    What's the difference between the red ones and the black ones? Is it just color or is one better than the other?
  4. Jun 15, 2016 at 7:12 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I just bought MOOG LCA from rockauto and it comes complete with bushings and ball joint for 99.79
  5. Jun 15, 2016 at 7:21 PM
    Skootter14
    Jeremy
    Also, test fit the doors this evening, gritty pic due to street light. paint monday most likely
  6. Jun 16, 2016 at 4:10 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Just color. I bought the red ones cause they were cheaper. Haha
  7. Jun 16, 2016 at 6:05 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    +1 on the brake cleaner before paintings. Keep turning rag to clean area.
    Some spray paints just do that though. Can't always explain it. I've had first coat go fine but 2nd coat from another can of the same paint look bubbled/splotchy.
    Dave41079 likes this.
  8. Jun 16, 2016 at 8:14 AM
    TacoFMS
    Justin
    Louisa County, VA
    I thought the black ones were supposed to be self lubricating or something. Like graphite impregnated or some fancy term like that. And the red ones were just plain poly bushings
  9. Jun 16, 2016 at 8:20 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    @allmotorrex did you put zerk fittings on the lowers when you put the energy bushings in?
  10. Jun 16, 2016 at 10:29 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    And you thought this why? I have no damn clue.
    Nope. Just bushings. It wouldn't be possible. The bushing is pressed in tight and no cavities anywhere for lube
  11. Jun 16, 2016 at 12:11 PM
    TacoFMS
    Justin
    Louisa County, VA
    Partly because others have made mention of it. And also because it says it in the part descriptions. One mentions the graphite and the red does not.
  12. Jun 16, 2016 at 12:59 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah I don't know anything about archilogical graphite nitrate incindiary self moistened plutonium based lca bushings. Sorry :rolleyes:
    11TRDTX likes this.
  13. Jun 16, 2016 at 5:11 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Looks like i need to spray out my radiator and condenser again. My truck is running warm :frusty:
    Edit: with the a/c on. I typically run around with it off unless i have the wife and/or kid.
  14. Jun 16, 2016 at 6:01 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    What's it running at? And I bought a pressure washer ......
    11TRDTX[QUOTED] likes this.
  15. Jun 16, 2016 at 6:07 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    It was at about 3/4 towards hot on the gauge. And its about damn time you bought one! :D
  16. Jun 16, 2016 at 6:08 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Hahaha yeah I know. Driving a fucking hour to a car wash set me over the top.
  17. Jun 16, 2016 at 6:11 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Samesies. I was running 234° (needle was about 3/4) last weekend. AC on, 75mph, 86° out. Think it might be a combination of a little mud in there and the new bumper/splash guards. Runs 204° with AC off, 70mph, 86ish° outside temp.
  18. Jun 16, 2016 at 6:25 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    I haven't really had engine temp issues until now. I have noticed that with the a/c running at idle/stop lights, it will stop blowing cold until i start moving. It did that about a month and a half ago, and i removed my grill and pressure washed it at work, and it worked up until now.
  19. Jun 16, 2016 at 6:30 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Well yall saw what happened to mine. Cleaned the radiator out, flushed the system and a half ass done new water pump and my temps went from 240 on the highway to the hottest I've seen it was 186 on my way back from Turkey bay. My ac doesn't work so I haven't tried that. Haha
    Oh and I'm currently getting a new driveshaft built. Only took me since the AOP trip. Haha
  20. Jun 16, 2016 at 6:35 PM
    beertimecontinuum
    Everett
    11TRDTX and Dave41079 like this.
