Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jul 12, 2016 at 1:35 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I have a 94 single cab with a 22re. Bought it when I was 18
  2. Jul 12, 2016 at 1:41 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Nice. Your 2.7 turns your 35s with 4.88s no problem, yes?
  3. Jul 12, 2016 at 1:55 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yes. Is it fast? Fuck no but I can roll 80 on the highway no problem. I bet same truck but single cab would be prefect as far as power is concerned
    11TRDTX, rngr[QUOTED] and Dave41079 like this.
  4. Jul 13, 2016 at 4:59 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    A little thirstier than I thought this morning at DYF
    Also... offroading is really hard on vehicles. I wish someone had told me that before this morning at the Local stealership parts dept.
    You've been warned!!
    Skootter14 and 11TRDTX like this.
  5. Jul 13, 2016 at 6:48 AM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Say it ain't so!
    beertimecontinuum likes this.
  6. Jul 13, 2016 at 7:37 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    FIFY
  7. Jul 13, 2016 at 7:41 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I said it
  8. Jul 13, 2016 at 9:43 AM
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    Hay anyone had to hook up a brake control box? Is it that big of a pain?
  9. Jul 13, 2016 at 10:48 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    If you have the trailer towing package, it's almost too easy. Wire harness should be in glove box. Color coded hookup to controller, then plug-and-play to harness under dash. I've done 3, all 3 on Tacoma's with towing package. Can't speak to NON-tow package trucks....
  10. Jul 13, 2016 at 10:52 AM
    cllowe24
    Mid Tennessee
    2015 access cab
    That's the thing. Not sure if I have towing. I out drop hitch and lights on myself.
  11. Jul 13, 2016 at 7:29 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    So...... any of you guys remember what your stock front height measurements were? I'm trying to figure out how much lift i actually have. I've never really measured :anonymous:
  12. Jul 13, 2016 at 7:46 PM
    Dave41079
    Dave...
    Nashville, TN
    I think I've read that 21" is supposed to be stock, but I could be off a bit.
    ETA: Hub to fender measurement.
  13. Jul 13, 2016 at 7:54 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    20 front 22 rear for me
  14. Jul 13, 2016 at 7:57 PM
    Dave41079
    Dave...
    Nashville, TN
    Or that...
  15. Jul 13, 2016 at 8:48 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    After looking at my tape measurer which says i only got 2" of lift on my drivers side front and rear (haven't measured the passenger side since my truck is already parked in the garage for the night) I've done the bs math: i have 5100's at 0 with eibach 521600 (2.5" lift) coils, 3/8" poly spacer (that gives 1/2"-5/8" of lift) on both sides, and a 1/4" poly (gives 3/8" of lift) stacked on the 3/8" spacer on the driver's side. So on paper, i should have right at 3 on the passenger side and 3.5 on the driver's side. Taking into account spring settle, my bar on the front (which takes 1/4" away [I've actually measured that]), and my AGM battery (which i imagine weighs 45-50ish lbs); i probably lost about a 1/2 to 5/8" (maybe a bit more on the driver's side) putting it at 2.5- 2.75ish right? I imagine that's about right and my tape measurer is drunk :notsure:
    I'm going to measure the passenger side tomorrow, the measure from the ground to the bottom of the fender, then from the top of the tire to the bottom of the fender just to see how tall it is, and what the gap is. .... you know, that bullshit math stuff :smash:
  16. Jul 13, 2016 at 9:22 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    :boom:
  17. Jul 14, 2016 at 12:08 AM
    tunernewb92
    tunernewb92 Well-Known Member
    Brian
    Houston, TX
    2010 DCSB MGM OR
    Bills 5100 Front and Rear OME 885 Front Sway Delete 33" MTZ TRD FJ Wheels (Plasti - Black) Pioneer 10" Sub Kicker DS series component and speakers Alpine 5 way Amp Pioneer Double Din ImMrYo Mirror Bracket Escort 8100 Radar hung from mirror Waiting at house for install: TRD skid plate Retrofit Waiting on: BruteForce sliders BruteForce front bumper 2x3 6 led spot lights
    it doesn't count if its parked in your friends side yard.
    Kerleyfries likes this.
  18. Jul 14, 2016 at 3:06 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    20-1/2" center of hub to edge of fender opening in front.
    21-1/2" in rear.
    DCSB w/OR suspension prior to any changes.
  19. Jul 14, 2016 at 8:05 AM
    beertimecontinuum
    Everett
    Just dropped her off for alignment, last one was before AOP :D
    11TRDTX likes this.
  20. Jul 14, 2016 at 8:18 AM
    Dave41079
    Dave...
    Nashville, TN
    I'm sitting at Beaman Toyota in Nashville for my 20k service.
    11TRDTX likes this.
