Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jul 20, 2016 at 3:34 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Have you not noticed I dont pay attention to you?
    So I guess it was everything you hoped it could be?
  2. Jul 20, 2016 at 3:36 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Is this the front diff whatever bearing? I've read stuff on it but don't remember what it was. Enlighten me please sir
  3. Jul 20, 2016 at 3:39 PM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Replacing the stock needle bearing on the driver side of the clamshell with a solid bushing. The red case with all the fancy colored things in it is a bearing and race driver set.
    lowinhz likes this.
  4. Jul 20, 2016 at 3:45 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Yep I can take my driver side axle and move it around like sloppy seconds. This bearing replaces the needle bearing that goes out after a while with a lifted truck. The vibration go so bad that I had to do something and it wasn't the tires as they are balanced since I have tried it with two sets. So this is what fixes the vibration.
  5. Jul 20, 2016 at 3:49 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    What does this accomplish?
  6. Jul 20, 2016 at 3:51 PM
    TacoFMS
    Justin
    Louisa County, VA
    Takes out the vibration/growl that you can develop in the front end after lifting. Easiest way to diagnose is if you have a vibration/growl around 50-60 mph and engage 4wd and it goes away that is what it is.
  7. Jul 20, 2016 at 3:54 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Oh ok. I don't guess I've ever noticed this. Of course my truck makes aplenty kinds of noises and shit so I might not know it if it was happening anyway. Haha
    Skootter14 and Robertocritser like this.
  8. Jul 20, 2016 at 4:15 PM
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    Anyone here put a brake control box in a 2nd gen?
  9. Jul 20, 2016 at 4:43 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    You just did pay attention so ha!
  10. Jul 20, 2016 at 4:45 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    FUCK!!!!!! Im busted.
  11. Jul 20, 2016 at 4:48 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    What bushing did you use? Maybe doing this soon as well...
  12. Jul 20, 2016 at 4:56 PM
    lowinhz
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
  13. Jul 20, 2016 at 5:39 PM
    TacoFMS
    Justin
    Louisa County, VA
  14. Jul 20, 2016 at 5:40 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    When I do my regear from ECGS I am planning on having them swap the bushing out so I don't have to do it later.
  15. Jul 20, 2016 at 5:48 PM
    beertimecontinuum
    Everett
  16. Jul 20, 2016 at 6:02 PM
    TacoFMS
    Justin
    Louisa County, VA
    No, unless they install one for you.
  17. Jul 20, 2016 at 6:20 PM
    beertimecontinuum
    Everett
    Was thinking I had read about it before, then the dude in the video on the above ECGS link mentioned "ARB uses a bushing here" when comparing the Toyota and Dana carriers. Thinking I'm going to try and install my own gears when I go 35", may go with the bushing mod OR try and turn my labor savings into an new selectable locker from ARB. Lots of time for me to do more research between now and then though. However, my MTZ 33's are starting to show wear pretty bad and I've been saying I was going to buy another set of 33s before doing 35s. Been on my mind lately though, thinking I may "accidentally" buy 35's
    Robertocritser and 11TRDTX like this.
  18. Jul 20, 2016 at 6:21 PM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Go 35s. No balls!
  19. Jul 20, 2016 at 6:24 PM
    beertimecontinuum
    Everett
    Problem is I'm broke with a baby due in October lol, figured I'm going to need tires soon, at the latest before the 5th annual LBL meet. 33s with no extra work or 35s with a shit ton of work and $$$.
  20. Jul 20, 2016 at 6:38 PM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Save yourself the work and do like I did, just get another vehicle that already has 35s haha. Land Cruisers are kick ass family wheeling rigs anyway!
