Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Sep 20, 2016 at 1:30 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    I do like these better in a 16 though.
  2. Sep 20, 2016 at 1:35 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Wait, those are supposed to be 17x8's hahah. Guess I didn't go far enough down.
    Dave41079[QUOTED] likes this.
  3. Sep 20, 2016 at 3:27 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Those are the wheels I have
  4. Sep 20, 2016 at 6:03 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Dreamed today that I was wheeling some hilly park. Like AOP without the trees. :bored:
    Dave41079 and Bluegrass Taco like this.
  5. Sep 20, 2016 at 6:08 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    They call golf courses without trees "links" courses. Not sure what to call a 4wd park without trees.....Sounds like moon scape....
  6. Sep 20, 2016 at 6:15 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Moab. They call it Moab.
  7. Sep 20, 2016 at 7:51 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Who had the elm adapter hooked up their iPad in here? 'Mine came in today and trying to remember what app you said you used
  8. Sep 20, 2016 at 8:03 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    @Dave41079
    Dave41079 likes this.
  9. Sep 20, 2016 at 8:03 PM
    Dave41079
    Dave...
    Nashville, TN
    That was me. OBD Fusion is what I use on the iPad. Torque is what I use on my anrdoid phone.
  10. Sep 20, 2016 at 8:12 PM
    beertimecontinuum
    Everett
    +1 for Torque
  11. Sep 21, 2016 at 8:44 AM
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    Me. But I think I have a bad bushing. I'm going to stick a go pro under there this weekend to see which one
  12. Sep 21, 2016 at 9:50 AM
    Dave41079
    Dave...
    Nashville, TN
    Prinsu rack is on.
    KRAMERICA and Skootter14 like this.
  13. Sep 21, 2016 at 9:51 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Bolt was starting to seize in one of my cams. Had to hammer it out. That's on a '15 at 30k miles.
    @TravlingmanTN
  14. Sep 21, 2016 at 10:03 AM
    TravlingmanTN
    TravlingmanTN "Nice hooters!"
    Lynchburg, TN
    2003 Double cab off road
    Let me know how that goes. I'm gonna do some research to see how easy if a Fox it is. The dealership quoted me at 380 for new bushings, and an alignment afterwards.
    Do you think it's something you should only replace the faulty one or pull all of them and antiseize the "good ones" ?
  15. Sep 21, 2016 at 10:10 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    The stock bushings can't be replaced with stock bushings. What is the dealership actually quoting you to do? If you are replacing bushings, get polyurethane bushings, otherwise you need to buy new lcas. Also if you can get the cams out without harm to them then just wire brush them, put antiseize on them and reuse them. If not then buy moog ones. None of this is what I would consider hard work but it will take you a few hours to complete
  16. Sep 21, 2016 at 10:10 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    What do you think? .....
  17. Sep 21, 2016 at 10:13 AM
    Dave41079
    Dave...
    Nashville, TN
    Really nice quality product. Haven't been on the interstate yet to see what wind noise is like though.
    tacotim448 and KRAMERICA like this.
  18. Sep 21, 2016 at 10:13 AM
    TravlingmanTN
    Lynchburg, TN
    Thanks for the info. The dealership just said to only replace the bushings. So far I'm thinking it's better to do it yourself. Seems like a lot of people with this problem end up cutting the cam bolts to remove them.
  19. Sep 21, 2016 at 10:18 AM
    TravlingmanTN
    Lynchburg, TN
    Did you end up replacing the bushings ? Yeah mines a 14 with 50k. Seems like a short period of time to have something like this happen
  20. Sep 21, 2016 at 10:21 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Yes. I put in Energy poly bushings.
    Edit: not sure I needed them but I had arms off anyway to weld alignment tabs after they flattened and figured it wouldn't hurt to replace things while they were off.
