Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Oct 19, 2016 at 12:57 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That's a lot of gaah!'s
    That's odd usually Pelfrebilt is pretty good with customer service
  2. Oct 19, 2016 at 1:01 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    So that makes 11...
  3. Oct 19, 2016 at 1:03 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    This time I can say it SUCKS!!! I'm beyond frustrated with them...
  4. Oct 19, 2016 at 1:08 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    They just need to keep in mind that it's not just about swapping out shackles and yay, I got more droop with no subsequent consequences. I've also seen many people talk about how it gets rid of those big stock shackle hangers and now they don't have to worry about getting hung up on them. I have NEVER been hung up on a shackle hanger before. I'm not really sure what you would have to do to make that happen. Same people that worry so much about a gas tank skid, front diff drop, rear diff breather, snorkel for driving through hood high water, open diffs are fine because I already follow the big trucks all the time, I can't fit 35s without building a tube front end, chrome looks good, dick tastes good and my 16 year old daughter isn't sucking off every guy willing to skip 3rd period and hide under the gym bleachers with her. Those people are the ones who none of my posts will ever save. Good luck to your friends .....
  5. Oct 19, 2016 at 1:14 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    It has to happen organically. You can't force chemistry.
  6. Oct 19, 2016 at 1:16 PM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Nah. I'm going to Harlan broseph
  7. Oct 19, 2016 at 1:23 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    I need to hit up Harlan before I move
  8. Oct 19, 2016 at 2:24 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    While I was in my senior year @ Purdue, I fell into a co-op program that also put me on the payroll at Honda, and going after my masters in mechanical engineering at Rose Hulman Institute. Honda funded a program where we did research on suspension linkage used on the rear end of their dirt bikes. It eventually went into production in the mid 80's through the mid 90's. The multi-link suspension had a lot in common with the ratio's used in tuning a leaf suspension via shackle length/angle. We also had data supplied by General Motors on suspension design intended for use on school bus chassis. Long story short, they used a 45 degree baseline for shackle/linkage angle, then altered that to "tune" the suspension to achieve desired results. Also, that angle wasn't measured from the flat plane drawn from front wheel to rear wheel center, but instead, on a plane from center of two pivot points of the leaf spring (bolts ) . In almost all cases, the front pivot would be slightly below the rear pivot. By altering the angle of that plane, the angle of the shackle would be reduced 2 to 2-1/2 degrees per every 1 degree of the front/rear pivot differential. And if that doesn't complicate things enough, the shackle angle would be calculated to be at it's optimal angle with 75% of rated payload in the vehicle at normal position(s) (ie passengers in seats/load in trunk/bed. etc....) Lengthening shackles on a standard leaf spring suspension would effect the plain used to measure correct linkage angle. ie.....longer shackles threw everything out of kilter.
    Honda foot the bill for all my post grad work. I was committed to work for them for 6 years after I received my degree. That ended up as being a suspension tech for their off road racing program.
    As a habit developed in those days, anything that I comment on strictly as a casual observation, rather than a data driven set of scientific facts I regard as anecdotal and NOT based on hard science.
    I use a term for when people do "back yard modifications" to any well engineered design....I call it "accidental engineering". In many cases, there's enough of a margin for error, these shot in the dark changes will still work well enough that the average end user won't see enough difference to KNOW the difference.
    When push comes to shove, I don't like taking wide swings at re-inventing the wheel....Changing well thought out designs brings with it an opportunity to learn, but it also CAN cause issues that go far beyond the average person's pay grade. A simple thing like spring shackles has a far greater effect than what meets the eye.
    It's an engineer thing.....
  9. Oct 19, 2016 at 3:39 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    I approve this message. Probably should have gone with the Chevy 63" mod...
  10. Oct 19, 2016 at 4:02 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Who likes their beer cold!
  11. Oct 19, 2016 at 4:09 PM
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    I prefer to splurge on hookers and bourbon.
    11TRDTX and rngr like this.
  12. Oct 19, 2016 at 6:06 PM
    baileybrandon
    baileybrandon 2016 DCSB OR - MGM -
    Bailey
    Tennessee
    2016 Tacoma TRD Off Road Double Cab
    What are yalls thoughts on these prices for TRD Pro SEMA wheels and tires, TPMS switched over, mounted balanced and aligned
    BFG KO2 $1,950
    Toyo AT2 - $1,750
    From my local dealer
    This is for 4 tires and wheels.
  13. Oct 19, 2016 at 6:57 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I like mine VERY COLD!!! :thumbsup: Have you ever been to Twin Peaks? I Love there 29° draft beer!!:thumbsup::thumbsup:
    cllowe24 likes this.
  14. Oct 19, 2016 at 7:06 PM
    cllowe24
    Mid Tennessee
    2015 access cab
    Twin peaks is my favorite. I love their hangover burger mmmmmmm.
    KRAMERICA likes this.
  15. Oct 19, 2016 at 7:17 PM
    tacotim448
    tacotim448 Well-Known Member
    Tim
    Nashville
    2011 Money Pit
    It never efffing ends.....
    Holy Fük that is a lot of money for wheels and tires.
  16. Oct 19, 2016 at 7:21 PM
    baileybrandon
    Bailey
    Tennessee
    Even with mounting and discounting, balanced and alignment?
  17. Oct 19, 2016 at 7:25 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    What's the breakdown on per tire and wheel cost?
    baileybrandon[QUOTED] likes this.
  18. Oct 19, 2016 at 7:25 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    And what size tire are you looking at?
    baileybrandon likes this.
  19. Oct 19, 2016 at 7:27 PM
    tacotim448
    Tim
    Nashville
    2011 Money Pit
    I was being a bit facetious. $2k for wheels and tires just blows my mind. I'm old though. I can remember when you could buy tires for $70 a piece.
  20. Oct 19, 2016 at 7:28 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Heck anymore tires for Toyota Corolla cost nearly $70...
