Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Nov 10, 2016 at 2:54 PM
    baileybrandon
    baileybrandon 2016 DCSB OR - MGM -
    Bailey
    Tennessee
    2016 Tacoma TRD Off Road Double Cab
    also what is "can of either"
  2. Nov 10, 2016 at 3:02 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Ether it is used to seat the bead on a tire if it ever lost a bead. Loft wheel/tire off the ground. Spray a limited amount of ether in it. Stand off to the side and ignite the ether. The controlled explosion will seat the bear allowing you to quickly inflate the tire.
    baileybrandon[QUOTED] likes this.
  3. Nov 10, 2016 at 3:04 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    ether..... Starting fluid....
  4. Nov 10, 2016 at 3:05 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Here are the tools i bring with me every offroad trip because ive either used them in my garage or on the trail .....
    Socket set with sockets 8mm - 19mm, 21mm, 24mm, 25mm, 26mm, 35mm, 1/4" - 1", 1" 3/8, 10mm allen key socket, numerous extentions
    Open end wrench set from 10mm - 19mm and 3/8" - 1"
    Impact gun
    2, 3/4" shackles
    Toyota bottle jack
    High lift jack
    4"x4"x10" wood block
    Full set of allen keys (metric and standard)
    4" grinder with cut off wheel
    Mini sledge
    18" pipe wrench
    5" channel locks
    2' pry bar
    1' pry bar
    Ball joint separator
    3' breaker bar
    Multimeter
    Assortment of screwdrivers (flat head and phillips head)
    Snap ring pliers
    Wire cutters
    Small channel locks
    Wire strippers
    Razor knife
    Telescoping magnet
    Electrical tape
    Assortment of wire nuts, stak-ons, terminals and butt splices
    #14 wire
    Assortment of clamps
    Wd-40
    PB Blaster
    Either
    Tire plug kit
    High temp grease
    Brake line bender
    Gorilla tape
    Teflon tape
    Assortment of zip ties
    Gorilla glue
    Toyota gasket maker
    Lock tight
    Motor oil
    Gear oil
    Brake fluid
    Fire extinguisher
    Assortment of fuses (mini and full size)
    12v relays
    8 ratchet straps
    Numerous bungee cords
    Numerous lengths of para-cord
    Thats all i can think of. Most of the first half of that i keep in my garage and the second half is always in the truck.
  5. Nov 10, 2016 at 3:06 PM
    baileybrandon
    Bailey
    Tennessee
    Ha I know what that is!
  6. Nov 10, 2016 at 3:07 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    AKA, DYF Tire installer's fluid
  7. Nov 10, 2016 at 3:14 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Go with your gut feeling. You don't seem to be one to make a lot of bad decisions....
    Also, 1 year contract.....How binding on YOUR end? If something better comes along, is there a penalty for leaving early. Although that is usually a bad thing to have early exit on your resume', it would be bad to be locked in if a better offer came along. That said, really GOOD jobs are in relatively short supply now. I can't speak specifically to your career field, but a foot in the door may be a good thing until the business climate picks up a bit. JMHO, but I think things will start rocking and rolling in the next year.....
  8. Nov 10, 2016 at 3:22 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Or "sketchy off camber keep holding the brake I'll be there when I recover myself around this corner first even though I can't open the door because hillside" type recoveries.
    11TRDTX and beertimecontinuum like this.
  9. Nov 10, 2016 at 3:40 PM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Aka "pick the biggest guy in the group and have him sit on the tailgate while Dave gets stuck himself trying to save Gid."
  10. Nov 10, 2016 at 4:17 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Or gas. But be conservative...
    Gotta use what you got when you jump your truck lose a tire and you're 10 miles in the middle of no where Lmao
  11. Nov 10, 2016 at 4:52 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Nope wasn't me.
  12. Nov 10, 2016 at 6:28 PM
    tacotim448
    tacotim448 Well-Known Member
    Tim
    Nashville
    2011 Money Pit
    It never efffing ends.....
    Remind me to always have you along when I off road. ;-)
    Strikersteve57 likes this.
  13. Nov 10, 2016 at 6:37 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    good, SOS is not the way to go
  14. Nov 10, 2016 at 6:38 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    X2 I've got buddies with SOS shit and they all have fronts and they don't line up with the body of the truck. One side has a huge gap the other rubs the fender.
    Kerleyfries likes this.
  15. Nov 10, 2016 at 8:16 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
  16. Nov 10, 2016 at 8:17 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Ask @Kerleyfries and @Newlife about theirs :stirthepot: :popcorn:
  17. Nov 10, 2016 at 8:20 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I didn't even list the spare parts. Haha but yes, I bring my tools
    Dave41079 and tacotim448[QUOTED] like this.
  18. Nov 10, 2016 at 8:21 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah, those are fightin letters in this thread.
    We may have a few first hand experiences .....
    Dave41079 and Kerleyfries like this.
  19. Nov 11, 2016 at 5:39 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Merry Bday Everett!
  20. Nov 11, 2016 at 5:41 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Yanks!! :cheers:
