Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Dec 7, 2016 at 4:22 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Carter, what did you order? Mike, why isn't that shit on your truck yet? Kurt, you can fit a 33, but you need to move the bracket towards the rear of the truck about an inch so the diff doesn't rub the tire on compression. It will still fit with the factory hitch in place.
    baileybrandon and lowinhz like this.
  2. Dec 7, 2016 at 4:23 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Someone is going to have to explain that to me first, cause I don't know how they work either...
  3. Dec 7, 2016 at 4:25 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    They are on my truck, don't you see them ON my tailgate!
    11TRDTX likes this.
  4. Dec 7, 2016 at 4:26 PM
    Dave41079
    Dave...
    Nashville, TN
    Try harder.
    11TRDTX likes this.
  5. Dec 7, 2016 at 4:26 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    I know it's shitty, but all i have is a screen shot.
  6. Dec 7, 2016 at 4:45 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    I have these printed out in my glove box, give them to each tech with the bottom portion about setting LCAs forward. Never works, they still fuck it up. I have since learned how hard it is to get it right. Going to be doing my own alignment again for the third and possibly final time sooon.
    Dave41079 likes this.
  7. Dec 7, 2016 at 5:01 PM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Threw a code this morning. Truck is falling apart. Send help and moneys.
    beertimecontinuum likes this.
  8. Dec 7, 2016 at 5:04 PM
    Dave41079
    Dave...
    Nashville, TN
    I just put some help in the mail. Money will have to come from someone else. What's the code for?
  9. Dec 7, 2016 at 5:08 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Sliders
    This is what I did. Set the ball joint caster adjustment to the neutral (SPC logo facing you if you're looking at the truck) position. This is actually +2* over stock. You do this by rotating the ball joint.
    The camber is adjusted by sliding the ball joint in the groove. Eyeball it as close to center as possible.
    That's what I did And the alignment guy was able to give me 3* caster. 0.2* camber 0* toe only using the LCA adjustments.
  10. Dec 7, 2016 at 5:10 PM
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    P0116.
    Engine Coolant Temperature (ECT) sensor circuit range/performance.
    Only threw it once. This morning while the truck was warming up. Drove around 100 miles today and the ScanGuage didn't alert me again.
    "The ECT (Engine coolant temperature) sensor is a thermistor which changes resistance based on temperature of the coolant in contact with it. The ECT sensor will be located in the block or coolant passage."
  11. Dec 7, 2016 at 6:51 PM
    Dave41079
    Dave...
    Nashville, TN
    Passed my finals, passed my classes, no class until the middle of next month, start the new job on Monday. I'll be in Santa Barbara form the 18th to the 25th. I'm excited about this break.
  12. Dec 7, 2016 at 6:56 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Fan-fucking-tastic. Congrats.
    Dave41079[QUOTED] and 11TRDTX like this.
  13. Dec 7, 2016 at 7:18 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    my pressure control solenoid "B" went out in the xmsn. continuing to fight with warranty company to fix it. probably a losing battle.
    The said my warranty was void because: program chip in engine (I have NEVER tuned my truck nor upgraded any engine chip??? Fight this claim with Toyota to prove I have not done this), after market front and rear bumpers, and "way oversized tires"
    Becuase all these reasons (minus the engine chip which is beyond me) will make an electric solenoid go bad in a xmsn. give me a fuckin break!
  14. Dec 7, 2016 at 7:18 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    What happen to the epic US tour?
  15. Dec 7, 2016 at 7:22 PM
    Dave41079
    Dave...
    Nashville, TN
    That's after graduation.
    lowinhz[QUOTED] likes this.
  16. Dec 7, 2016 at 7:23 PM
    lowinhz
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Time to advise them you are going to get a lawer and file it under the Magnuson-Moss act in which they have to prove that your tire and bumpers truly caused it to break.
  17. Dec 7, 2016 at 7:24 PM
    Dave41079
    Dave...
    Nashville, TN
    They will claim oversized tires made your transmission work harder, therefore fail sooner. You will have to prove that wasn't the case. If you aren't familiar with it already, look up the Magnuson-Moss Warranty Act of 1975.
  18. Dec 7, 2016 at 7:41 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    2 more finals left this semester :fingerscrossed:
    rngr and Dave41079 like this.
  19. Dec 7, 2016 at 7:55 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Then you'll go to work every day and wish you were in college. Ha ha.
    I will say that overall I prefer this side of the diploma hands down.
    11TRDTX, Dave41079 and KRAMERICA like this.
  20. Dec 7, 2016 at 8:04 PM
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Same. The past 6 months have been so nice not stressing about school. Now I get to stress about finding a job. Had an interview today so hopefully I get some good news next week.
