Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Dec 27, 2016 at 10:21 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    The locker replaces the center spider gears and alters the "backlash" so tolerances aren't as tight. You should be able to reach under your truck and slightly twist your driveshaft back and forth because of a slight tolerance between all the different pieces in the 3rd member. The locker just increases those tolerances so back and forth play goes from say 1/4" of play to 1/2" of play and you get some driveshaft noise when in nuetral from it kinda flopping around. You'll see. It's not bad, just different then stock.
    rngr[QUOTED] likes this.
  2. Dec 27, 2016 at 10:23 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    What should I use for starting point adjustments with my LR SPC UCA's?
  3. Dec 27, 2016 at 10:26 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    If you're going with a mild lift, 2-3" just follow the directions on the installation instructions. The "default" setting (centered in the UCA) adds I think 2 degrees caster and is a good place to start.
    Edit - it is position "D" on the install instructions and does in fact add 2 degrees.
    If you're stuffing 33's you might want to add more caster.
    KRAMERICA[QUOTED] likes this.
  4. Dec 27, 2016 at 10:31 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Don't listen to him. Just throw them away and start over. :D
  5. Dec 27, 2016 at 10:32 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
  6. Dec 27, 2016 at 10:32 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Well listening to you is what got me where I am now....
    beertimecontinuum likes this.
  7. Dec 27, 2016 at 10:34 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Well there's your problem :rolleyes:
  8. Dec 27, 2016 at 10:36 AM
    Harry
    Santa Fe NM
    As far as the adjustment on the "Big Effin Nut" there are two schools of thought: (1) pull it all the way forward to its stop; (2) set it midway along its travel.
    (1) makes it harder to align down at the LCA. But if you knock the shit out of the UCA off road you know where to put it back.
    (2) makes alignment easier. I recommend marking the position with a paint marker so when you knock the shit out of it offroad, you know where to put it back. :D
    BTW I lurk in the TN thread because the girl has family there and we'll be making the move in a couple years.
    KRAMERICA and beertimecontinuum like this.
  9. Dec 27, 2016 at 10:40 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Lurk away. Anyone who writes "science, bitches" as the only possible context to judge your character by is just fine with this group of fuck tards.
  10. Dec 27, 2016 at 11:41 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    You're really good at explaining things. Should have been a teacher.
    I set mine to the neutral (+2*) position for caster. Then centered the ball joint in the slide as close as I could. The alignment guy was able to give me 3* caster, 0.5* camber, 0* toe using only the LCA.
  11. Dec 27, 2016 at 11:41 AM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Are you correcting your numbers for oversized tires, or just doing straight math? I get better than 13.8 actual with all the shit on my truck and 35s, and I don't drive easy.
  12. Dec 27, 2016 at 11:55 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    And by "not easy" he means like a bat out of hell.
    Dave41079[QUOTED] likes this.
  13. Dec 27, 2016 at 11:57 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    This is true
    Dave41079 and rngr[QUOTED] like this.
  14. Dec 27, 2016 at 12:21 PM
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    Yeah the ones I linked to are FK stainless. Thanks boo
  15. Dec 27, 2016 at 1:05 PM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    I'd love to have one. Two of my buddies have blue ones though....
    I'll be commuting over 530 miles a week so anything with a 4.0 is out of the question and most likely out of budget.
  16. Dec 27, 2016 at 1:11 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I know the guys who run that car lot. When I see 'em headed out the door, I take off running. They typically overprice everything by 25% to 50%. Did you find out how much they wanted for the FJ? (Sandy wants one and likes THAT one)
  17. Dec 27, 2016 at 1:44 PM
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
  18. Dec 27, 2016 at 2:47 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I was. I taught a class called "Facticious Opinionating". They fired me for failing everyone for always being wrong ....
  19. Dec 27, 2016 at 3:18 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Bought the wifey a new Focus, sometimes I drive it.
    was going to write something smart here but tater nailed it. Welcome @TaterHarry !
  20. Dec 27, 2016 at 3:22 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    They don't have a "blows kiss" emoji
    TacoBurrito07[QUOTED] likes this.
