Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jan 31, 2017 at 9:41 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    What kerleyfries said tacotim. don't get ripped $850
    tacotim448 likes this.
  2. Jan 31, 2017 at 10:07 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I bought the bed and hood light kit from @mattgecko, just waiting for some warmer weather to install them.
  3. Jan 31, 2017 at 10:11 AM
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    I replaced these last year with a lot of help and guidance from @allmotorrex (He may have done a good chunk of it). It was not difficult and totally worth it. I didn't realize that you could get brand new ones from Rock auto for $80-100. That seems like it could be a good way to go as well.
    tacotim448[QUOTED] likes this.
  4. Jan 31, 2017 at 10:23 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    It's 63 here. Perfect weather :cool:
  5. Jan 31, 2017 at 10:24 AM
    Fastbilly5
    Fastbilly5 Well-Known Member
    And sunny
    11TRDTX likes this.
  6. Jan 31, 2017 at 10:27 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    New ones from rock auto are definitely worth it unless you want poly bushings. I'd pay for the poly bushings over getting free new lcas.
    Tim, if you have any mechanical sense, you have to do this yourself. Removing the LCA is 5 bolts: lower coilover mount, 2 bolts at the spindle and 2 cam bolts at the frame. Start to finish I'd give a rookie mechanic 2 hrs.
    If you want to put poly bushings in your current arms, all you need extra is a propane torch. The instructions that come with the Energy Suspension kit are all you need. You will grind down the metal flare holding the washer on then knock it off with a hammer. The stock bushings are glued in so evenly heat up the cup holding the bushing and it will squeeze itself out then scrape the rest of the bushings off the center sleeve and clean it up. Then grease and slide in the new bushings, put that washer back on and mushroom the piece of metal back out and you're done. I think we did Jake's in about 2 hrs.
  7. Jan 31, 2017 at 10:28 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    When you gonna meet some of us?
  8. Jan 31, 2017 at 10:54 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah I hope. I told Sarah last night you weren't coming and she said "Why!? I like Dave. He's fun."
    I wouldn't have thought anything about that comment but then she winked at me and gave me that "let's have dirty, cum on my face, sex" look. Now being super excited about going to bed, I told her to let me finish something real quick and I'd be in there. A few minutes later, I arrived to find her asleep. How could she give me that look and tease me with erotic fantasies and then care so little as to pass out a moment later!? She's never done this before. Maybe she drugged herself or I took longer to get here then I thought or she wanted to go to sleep as soon as possible because she planned on this occurring in the morning. I was truly perplexed. It was then in this silent moment of stupefied ignorance that I realized what had occurred. The comment "he's fun" followed by sexual tension was directly correlated to one another and I was not the one whom it was intended for. Having made this self-mutilating revelation, I sat there in horror thinking of all the terrible things I would do to "Dave" to insure these thoughts never came to fruition. Just as I had devised my ultimate diabolical scheme, I was prematurely distracted by the theme song of "Dexter's Laboratory" and found myself floating off into heavenly cartoon bliss.
    When I awoke this morning, I had completely forgot what my plan was and honestly don't care to re-plan it so you're off the hook. :D
  9. Jan 31, 2017 at 10:54 AM
    tacotim448
    tacotim448 Well-Known Member
    Tim
    Nashville
    2011 Money Pit
    It never efffing ends.....
    Yea, your description sounds similar to the videos I've watched. My dilemma is finding a place to do the work. My brother has a garage but lives several hours away and I live in a condo in downtown Nashville. I'll probably try to plan a weekend with my brother so I can get this done before LBL.
    Should I anticipate or plan to replace anything else while I have all of this apart?
  10. Jan 31, 2017 at 11:03 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    grease your LCA bolts so they don't seize.
    11TRDTX and tacotim448[QUOTED] like this.
  11. Jan 31, 2017 at 11:33 AM
    tacotim448
    Tim
    Nashville
    2011 Money Pit
    @allmotorrex do you use a bottle jack to push out the old bushing? How do you press in the new bushing?
  12. Jan 31, 2017 at 11:42 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    lca bushing basically falls out once hot enough to break adhesive.
    Use Map gas (yellow), not propane (blue).
  13. Jan 31, 2017 at 12:26 PM
    Fastbilly5
    When I'm not working all the time
  14. Jan 31, 2017 at 2:40 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    No. A big enough c clamp works just fine. They press in pretty easy.
  15. Jan 31, 2017 at 5:56 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Whew...I barely escaped that one. Maybe you should get an awesome mustache to wear to bed...
  16. Jan 31, 2017 at 6:14 PM
    Berserker
    Berserker Well-Known Member
    2011 Tacoma Dbl Cab TRD Sport!
    Any body ever around Knoxville?
    I am trying to get a trip out to Nashville this spring and would like to meet some of you fellas,
    But if anyone is ever in knox, I will buy you a beer
  17. Jan 31, 2017 at 6:20 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    I'm always in Knox
    Berserker[QUOTED] likes this.
  18. Jan 31, 2017 at 6:29 PM
    Dave41079
    Dave...
    Nashville, TN
    Liar.
    11TRDTX likes this.
  19. Jan 31, 2017 at 6:36 PM
    Berserker
    @Kerleyfries
    Let's grab a beer some time!
    I'm gone next week though
  20. Jan 31, 2017 at 6:50 PM
    Kerleyfries
    Zack
    Lebanon
    Fuck off traitor.
    Sounds like a plan to me. Maybe we can set something up with the other Knox guys? Pretty sure there's a couple new guys in here. @lowinhz @KnoxTac0713 would y'all be down?
