Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Feb 2, 2017 at 6:42 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Happy Birthday Mike!
    now now, there's enough of me to go around
    KRAMERICA likes this.
  2. Feb 2, 2017 at 7:09 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Try LowrangeOffroad, Wheelers Offroad, headstrong Offroad for a start.
    Edit: SDHQ is another option and I went with LR SPC UCAs because of the price.
  3. Feb 2, 2017 at 7:13 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I enjoyed it.
  4. Feb 2, 2017 at 7:16 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Those wheels tho.
    423 TACO likes this.
  5. Feb 2, 2017 at 7:16 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Do you want ball joints or uniballs? Budget?
  6. Feb 2, 2017 at 7:40 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Camburg, Total Chaos, MCM fab, Icon, Dirt King, Allpro ...... all high quality uniball ucas. The best of the best is a uca using a 1.25" fk stainless uniball with 3 to 4 degrees of added caster, fully gusseted bushings cups and poly bushings. Next best is the same setup but using a 1" uniball. Next best is same setup using a ball joint.
    The thing that is important to most people is added caster and travel range. Any high quality uca should have that 3 to 4 degrees of added caster built in. If it has no added caster, it's completely useless. An aftermarket ball joint uca is going to be stronger and have more range of motion then the stock ball joint uca. A 1" uniball uca will be stronger and have more range of motion then an aftermarket ball joint uca. And obviously a 1.25" will follow that same pattern.
    Upsides of a uniball uca over a ball joint uca are strength, range of motion and ease of replacing the uniball.
    Downsides are more pertinent maintaince, more noise (race car parts) and decreased longevity.
    If you get a uca with a mild steel uniball, it will rust and wear out the teflon lining very fast so be sure it's a fk stainless steel uniball.
    If price is a concern then more then likely a ball joint arm like Camburg will suit you just fine. If you get/have extended coilovers, it's a better idea to get at least some 1" uniball ucas for the increased range of motion and added strength if the uca becomes the limiter to down travel. If you just like the best stuff out there, a high quality built 1.25" fk stainless uniball uca (example: Camburg) is what you want.
    Breezy and tacotim448[QUOTED] like this.
  7. Feb 2, 2017 at 7:49 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    New wheels are coming up on the list quick. I just can't decide what wheel I want
  8. Feb 2, 2017 at 8:20 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Thanks all for the Birthday wishes! As my Papa was so kind to point out to me, I'm now over the hump and on the downslope... :crapstorm: o_O
    Berserker likes this.
  9. Feb 2, 2017 at 9:16 PM
    tacotim448
    tacotim448 Well-Known Member
    Tim
    Nashville
    2011 Money Pit
    It never efffing ends.....
    Thank you sir. I appreciate the extended explanation. I was leaning toward the SPC ball joint, but am going to order the Camburg 1.25 uniball UCA now and separately the energy suspension bushings for the LCA, along with new cam bolts. Now, how long will it take my amateur ass to install?
    TacoBurrito07 likes this.
  10. Feb 2, 2017 at 9:21 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    4-6 hours would probably be a realistic amount of time to set aside. You may not take that long, but it only takes one hiccup to cause you an extra hour of work. I swapped both of my UCAs in less than an hour, but I had zero hiccups, and had already done my wife's on her 4Runner. It's all simple work and should be a good place to start if you aren't familiar or comfortable working on a vehicle.
    tacotim448[QUOTED] likes this.
  11. Feb 3, 2017 at 6:57 AM
    The Taco Bear
    The Taco Bear Well-Known Member
    Franklin, Tennessee
    2018 4Runner TRD Off-Road
    2018 4Runner Off Road TRD SEMA Wheels TRD Skid Plate Prinsu Full Roof Rack RCI Skids Icon 2.5 ext front with resi Icon 2.0 ext rear T13 rear coils Camburg UCA RSG Sliders C4 LoPro 2011 Tacoma TX Pro — Sold Pelfreybilt hybrid bumper Icon 2.5 ext. Non Resi Icon 2.0 Rear with Resi Icon AAL Total Chaos UCAs CaliRaised LED Ditch Lights TRD Exhaust & Intake System TRD Fake Bead Lock Wheels BAMF Sliders Uniden Comm System w/ 4ft fire stick JBL Audio Future Mods: UBolt flip kit with bump stops. Dakars Skids Bed Rack
    Man @tacotim448 I 'm happy you pulled the trigger... @allmotorrex would be pissed at me cause i've asked this question like 2 times now... I'm stuck on ordering Tube Icon UCA's or TCs... Reading this fourm makes me skeptical of parts haha. It took me forever to buy my lift. Now I'm stuck on this...:frusty:
  12. Feb 3, 2017 at 7:48 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    TC or camburg
  13. Feb 3, 2017 at 7:55 AM
    The Taco Bear
    Franklin, Tennessee
    I've heard hit and miss on Camburg but also the same on TC. Does one out perform the other or is it basically just the finish on them? I get what Allmotorexx has said about stainless steel uniballs, uniball sizes, zerk fittings ect. He lectured me on that concept.
  14. Feb 3, 2017 at 7:58 AM
    beertimecontinuum
    Everett
    If one of you guys gets buyers remorse with your unisex balls I will trade you straight up for my SPC LR With new UBJs :D ..Might even install them for you
  15. Feb 3, 2017 at 8:11 AM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    No bueno on ball joints for you? I had been leaning toward Camburg with ball joints, but now I'm second guessing too haha
  16. Feb 3, 2017 at 8:12 AM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Thanks buddy, it's a work in progress. Sometimes I wish I would've left it stock, but I have had way too much fun with it
    The Taco Bear[QUOTED] likes this.
  17. Feb 3, 2017 at 8:13 AM
    The Taco Bear
    Franklin, Tennessee
    Best Deal Ever :poking:
    I was looking at those too for less maintenance but after reading I really Just don't know anymore.. TW does things to you.. plays with your mind..
  18. Feb 3, 2017 at 8:16 AM
    beertimecontinuum
    Everett
    Meh, they're fine once I learned to DIY alignment. My prob is I'm cranked down to almost 4" and trying to hyperextend them. They now have grease fittings which solved my other complaint.
  19. Feb 3, 2017 at 8:23 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    This is long but hopefully will help you .....
    100% agree with Dave. The ucas are very easy. Getting the long bolt out at the shock tower is a little tricky. They put it in at the factory from the front of the truck and it appears before they set the body on so you have to pull it out into the engine bay. As you start to pull the bolt out you will find it hits the engine bay. Take some pliers and bend that piece of metal into the wheel well slightly and the bolt slides out much easier. When you reinstall it, put the bolt in from the cab towards the engine bay instead. The instructions are clear that come with the arms. Be sure not to cross thread the grease nipple when screwing it into the arm and make sure you put the right arm on the right side. They are labeled but you know how guys are about reading directions. :rolleyes: Use the grease packet that is provided to you and grease everything. Grease inside the bushing and push the sleeve in then grease inside the cup and push the bushing in. Once you have the uca back on, tighten the bolt all the way up then back it off a turn or two so it's not just flopping around. Grease the nipple BEFORE you torque that bolt down. Grease it until you see the bushing start to slightly mushroom, stop, then tighten the bolt up. No need to apply anything to the uniball but you will eventually want to apply some Dry Teflon Lube such as Tri Flow brand to keep the uniball lining healthy.
    The LCA bushings will take longer then the ucas but still not hard work. As Daniel mentioned earlier, (if you dont already have this) buy a torch from Home Depot, Lowe's, etc .... with a yellow bottle of gas. I can take a pic of the torch I used because if you dont get one that gets hot enough, those bushings take a LONG time to get out. With the right torch they remove themselves in a few mins. Once again, the instructions are very clear so just follow them.
    Easiest way to disassemble, the ucas are held on by 2 17mm bolts to the bottom of the spindle, 1 17mm bolt at the shock mount and your 2 cam bolts. Remove the bolts in that order. That takes off any pressure the strut is applying to the LCA. Pay attention to how the cam pieces are orientated. The front and back uses 2 different bolts and both slide in towards eachother. Now that the LCA is removed from the spindle, you should be able to move the spindle/hub/axle assembly up and down with the ucas. Put a block or jack under it to keep tension off the uca bolt then remove the uca from the spindle and let that whole assembly just hang there.
    Use anti-seize on everything! It will make your life so much easier working on your truck next time. Wait until all the pieces are back together before you torque everything. Do a bullshit alignment just to get you to the shop and you're done! Woohoo!!!
  20. Feb 3, 2017 at 8:28 AM
    beertimecontinuum
    Everett
