Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jun 7, 2017 at 11:49 AM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Yes down 40. I'll send you a text when we getting close. My buddy that's with me probably wouldn't be against seeing the FR-S if you're in it.
  2. Jun 7, 2017 at 1:00 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Aight bet
    Dave41079[QUOTED] likes this.
  3. Jun 7, 2017 at 2:45 PM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Any Knoxville guys want two Rhino Rack crossbars for their 2nd gen roof?
    These came with my truck and I don't want them, make an offer. Or will trade for Tacoma stuff
  4. Jun 7, 2017 at 3:02 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I think your snorkel is backwards :notsure:
    Dave41079, rhion82 and Mr.Bl0nde like this.
  5. Jun 7, 2017 at 3:51 PM
    Dave41079
    Dave...
    Nashville, TN
    Nope, snorkel is right. Head is backwards though, looks like someone broke it's neck. Good way to starve the engine of air at highway speeds.
    Mr.Bl0nde likes this.
  6. Jun 7, 2017 at 4:05 PM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Yup, snorkel head is backwards. Hit an enormous amount of rain coming back home the other day.
    It will not starve the motor of air. But thanks for your input
  7. Jun 7, 2017 at 4:09 PM
    Dave41079
    Dave...
    Nashville, TN
    Good luck with that.
    beertimecontinuum likes this.
  8. Jun 7, 2017 at 4:23 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Let's not turn this into a dorkel measuring contest. Obviously both are long and black.
    Skootter14, 11TRDTX, tacabode and 8 others like this.
  9. Jun 8, 2017 at 6:19 AM
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    I second Jason at Rock your 4x4 in knoxville. I've known that dude for a good minute. He's helped me with stuff I couldn't get to when it needed done.
  10. Jun 8, 2017 at 8:37 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Is it luck or is it science? I wonder if any wind tunnel experiments have been done to see if a backwards turned head on a snorkel creates a high pressure area or not. Comparing things like AFR, AIT and MAF would certainly tell you something. Got a ultragauge/scan gauge? Find out for yourself ....
  11. Jun 8, 2017 at 8:38 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    SCIENCE!!!
    11TRDTX and dirty deeds like this.
  12. Jun 8, 2017 at 9:02 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I would expect both CFD simulations and physical tunnel testing were used.
    The Airflow ram has vanes that create a vortex to fling out debris. Without that, the engine pulls more junk to the filter.
    Airflow and Safari differ in their statements a little about rotating the scoop.
    One Airflow document says "The air ram should only be turned backward in very heavy weather/dust conditions. In this case, vehicle speed should not exceed 25 km/h or 15 M/h as it may damage the engine".
    My Airflow instructions say "Do not turn the air ram away from the direction of travel because it will lessen the positive pressure necessary for proper operation. In extreme situations, at speeds above 15 mph a vacuum may be generated causing irreversible engine damage."
  13. Jun 8, 2017 at 11:42 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    That very last sentence is the biggest issue here. Basically a snorkel head turned backwards at high enough speed will create a high pressure point on its face while creating drag on its opening. It's essentially doing the exact same thing the rear of a car is doing. Air turbulence would dictate where that air is moved to at that point, either down the tube or out away from the tube but I bet we can definitively conclude that no where near the same volume of air is entering the motor with the head backwards. At the very least, you will lose power and burn more fuel due to excessive engine heat and an oxygen difficiency.
    Dave41079 likes this.
  14. Jun 8, 2017 at 12:59 PM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    I have a set of mud terrains I need wheels for. Anybody have a set of steel wheels laying around? Or really anything for that matter.
  15. Jun 8, 2017 at 1:04 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Not sure what your time line looks like, but I will have a set of second GEN 16 inch alloy's available at some point
  16. Jun 8, 2017 at 1:16 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I have a set of oem 17" trd sport wheels that i painted. Can make you a deal. Have set of 1" wheel spacers too. Think there are still pics on my build page.
    edit. Also have nearly new set of oem wheel locks.
  17. Jun 8, 2017 at 3:21 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    well I ran a piece of foil clothes dryer tubing from my exhaust back to my intake to help force more air into the engine...its practically a Kentucky Turbo. got HUGE gains from it
    ....because RACETRUCK!
  18. Jun 8, 2017 at 4:21 PM
    The Taco Bear
    The Taco Bear Well-Known Member
    Franklin, Tennessee
    2018 4Runner TRD Off-Road
    2018 4Runner Off Road TRD SEMA Wheels TRD Skid Plate Prinsu Full Roof Rack RCI Skids Icon 2.5 ext front with resi Icon 2.0 ext rear T13 rear coils Camburg UCA RSG Sliders C4 LoPro 2011 Tacoma TX Pro — Sold Pelfreybilt hybrid bumper Icon 2.5 ext. Non Resi Icon 2.0 Rear with Resi Icon AAL Total Chaos UCAs CaliRaised LED Ditch Lights TRD Exhaust & Intake System TRD Fake Bead Lock Wheels BAMF Sliders Uniden Comm System w/ 4ft fire stick JBL Audio Future Mods: UBolt flip kit with bump stops. Dakars Skids Bed Rack
    Anyone got time and/or wanna help put leds and a bumper on this weekend? Got the call today
  19. Jun 8, 2017 at 5:43 PM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Will the LBL Radiator Saga ever subside?
  20. Jun 8, 2017 at 5:57 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Forever cursed
