Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Aug 7, 2017 at 1:31 PM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Either way, I was fairly certain we're nearly all within a few years age of one another. Mostly
  2. Aug 7, 2017 at 1:34 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Most of the others are late 20's to late 30's. Gid and myself are very early 30's
    lowinhz and dirty deeds[QUOTED] like this.
  3. Aug 7, 2017 at 1:34 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Complete opposite, yes. Terrible .... I trust my opinion over all others, he may not but he asked.
    Dave41079 and beertimecontinuum like this.
  4. Aug 7, 2017 at 1:36 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    VERY early. Haha
    11TRDTX[QUOTED] and dirty deeds like this.
  5. Aug 7, 2017 at 2:30 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    hahahah...but I trust my opinion over all others. . .
    tacotim448 and Dave41079 like this.
  6. Aug 7, 2017 at 3:06 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Its my birthday tomorrow
  7. Aug 7, 2017 at 3:11 PM
    dirty deeds
    Nick
    Eastern KY
    Is that so?
    Happy early birthday
  8. Aug 7, 2017 at 3:13 PM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
    Happy early birthday!
  9. Aug 7, 2017 at 3:52 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    My dad can beat up your dad :mad:
    Dave41079 likes this.
  10. Aug 7, 2017 at 4:01 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Just got back from doing my pre-hire paperwork in SC. Finallyyyyy have my orientation date.
  11. Aug 7, 2017 at 4:07 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Woohoo I'm a youngin!
    tacabode and 11TRDTX[QUOTED] like this.
  12. Aug 7, 2017 at 4:14 PM
    Skootter14
    Jeremy
    NAHHHHHUHHHHHHHHH!
    11TRDTX likes this.
  13. Aug 7, 2017 at 4:31 PM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    TL;DR: Does a grounding bolt need to contact the inner diameter of the mourning hole to get a solid ground or is the unpainted surface sandwiched against a wire terminal sufficient?
    Is 16ga wire too small to run the length of the truck, in regards to voltage drop, and not fire the light?
    Tried to wire up some aux reverse lights yesterday and was using an existing harness that I was running for the front of the truck. Extended the trigger wire (87) and ran it to the rear or the truck. Grounded lights to the frame, took paint off with Dremel, lights don't work.
    Tried three different lights and none of them worked. Tested the lights and they all lit up separate of the harness so lights are for sure good. Trying to ground to the frame but the bolt I'm trying to use is smaller than the ID of the hole in the frame. Relay is good, will engage via the switch so it has to be the ground right? Twisted wire connections together and used wire nuts respectively when troubleshooting :annoyed::frusty:
  14. Aug 7, 2017 at 4:39 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Run a seperate jumper wire outside the truck from battery ground post and use to ground light. That will eliminate chassis ground and tell you if you need a better ground at the light
    dirty deeds likes this.
  15. Aug 7, 2017 at 4:43 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    NAHHHHHUHHHHHHHHH ^^^^ what he said...:anonymous:
    11TRDTX likes this.
  16. Aug 7, 2017 at 4:45 PM
    lowinhz
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Check voltage off the relay with a test light. 16 gauge should be fine for some sux lights. I would not recommend wire nuts for connectors on a truck. They are meant for a house or non movable structure imo. Check the light right off the relay and ground them really good That's key.
  17. Aug 7, 2017 at 5:20 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    I said most :boink: :D
  18. Aug 7, 2017 at 5:21 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Y'all youngin's.
    11TRDTX likes this.
  19. Aug 7, 2017 at 5:25 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Shit. I suffer from sciatica and possibly tennis elbow
  20. Aug 7, 2017 at 5:30 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    A prostate the size of a baseball, post cancer.
    Kidney on watch list after cancer.
    Early stage Parkinsons
    Pulmonary fibrosis.
    Nerve damage in right foot.
    25% hearing in my good ear.
    20/250 vision.
    I could go on....
    Wanna trade
    11TRDTX[QUOTED] likes this.
