Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Aug 11, 2017 at 8:56 AM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Also doesn't look like I'll make Wooly's tomorrow. I'm not going to have time to get an alignment done today.
  2. Aug 11, 2017 at 9:07 AM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
    You can get cat 6 shielded and not.
  3. Aug 11, 2017 at 9:38 AM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    How are you attaching them?
  4. Aug 11, 2017 at 9:39 AM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    ...debatable
  5. Aug 11, 2017 at 10:40 AM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    For when I play around AC lines.
    beertimecontinuum likes this.
  6. Aug 11, 2017 at 10:41 AM
    Skootter14
    Jeremy
    Welp, the S/C has arrived
  7. Aug 11, 2017 at 10:50 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    You might be able to find 5e shielded, definitely 6, 6a, and now CAT 7. You can get individual pair shielding, all 4 pair shielding, with stiffener, without stiffener, etc. We sometimes have to use POE (power over ethernet) injectors to run our APs (access points) since we buy them without power adapters. This matetrs when you're buying $600 APs. Those injectors are usually 24 or 48v, low amperage though.
    Point is, don't use CAT anything to run power to anything other than a switch into a relay.
    I won't be using CAT cable for anything on my truck, no matter how much of it I can get for free from work.
    tacabode and Mr.Bl0nde[QUOTED] like this.
  8. Aug 11, 2017 at 11:03 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    bolt to underside of roofrack
    edit: if they're low profile enough to fit there. Single row combo beam bars.
  9. Aug 11, 2017 at 11:11 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    can the power to switches be daisy chained or do i need a seperate fused line off battery to each switch?
    Like can I run single wire + fuse from battery to first switch, then jump it to each additional switch at the mounting panel?
    (and of course each switch has its own line out to its own relay for each light)
  10. Aug 11, 2017 at 11:30 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Chain.
  11. Aug 11, 2017 at 11:45 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    sweet.
    simplifying things in my plotting for future mods.
    Want to plan ahead and bundle wires in braided sleeves to just run it all at once instead of having to route more lines later.
    Last thing, i think...
    Do I need a breaker in line between battery and the aux fuse box that I plan to add for all this?
  12. Aug 11, 2017 at 11:52 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    ^^ good point.
  13. Aug 11, 2017 at 6:08 PM
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    Agreed. I've used cat5 or cat6 for switches on temporary setups, but wouldn't use it on my truck. It's meant to have a specific connector on the end and when you're soldering it onto switches it's going to make it brittle. Too likely to fail for my tastes
    dirty deeds[QUOTED] likes this.
  14. Aug 11, 2017 at 11:43 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I have developed this horrible "don't you know what the fuck you're doing" attitude. Makes me a raging wanker sometimes. And when I don't, I ask. That doesn't happen much around here though, cause...ya know...
    Spent my life in Cars and now Electricty. 2 things people are deathly afraid of fucking with. And the idea of not using the appropriate part/wire/whatever is simply never an option. I despise "make it work", no, there's a right way.
    I just usually try and stay out of the "whats wrong with this/how do I do this" topics. I do not have said truck in front of me.
    For simple vehicle lighting....From battery, to fuse (or junction block, IE: Blue Sea's fuse box), to load (lights), to frame. Done. Always ground to the actual frame/chassis. It completes your circuit. Your battery negative is bolted to the frame, so the frame is always grounded.
    I always "Start Stupid". I hotwire anything first. Any lights I hook directly to battery. Use Gator clips to attach to battery power and ground. You can move the ground around anywhere and the lights should come on, everytime. Then throw in a switch and a fuse and you get cool shit. Use anti-seize on any ground connection.
    dirty deeds and 11TRDTX like this.
  15. Aug 12, 2017 at 7:48 AM
    dirty deeds
    Nick
    Eastern KY
    This guy gets it
  16. Aug 12, 2017 at 8:00 AM
    Dave41079
    Dave...
    Nashville, TN
    Oh relay?
  17. Aug 12, 2017 at 10:40 AM
    dirty deeds
    Nick
    Eastern KY
    I see what you did there. Cheeky bastard lol
    11TRDTX and Dave41079[QUOTED] like this.
  18. Aug 12, 2017 at 11:03 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I've got a spool of 22ga twisted copper wire. Could use that for switches to relays but it's all the same color and would use up more of my braided sleeve stuff...
    I'll cut open some CAT6 and see how big the wire looks.
    Did just order 7 spools of different color 16 ga wire, 5 relays, and some other stuff though
    11TRDTX, dirty deeds and Dave41079 like this.
  19. Aug 12, 2017 at 12:24 PM
    dirty deeds
    Nick
    Eastern KY
    I don't think you'll easily find CAT cable above 22ga without special order. Most of 5, 5e, 6, and 6a are gonna be 24-22ga conductors
  20. Aug 12, 2017 at 2:06 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    All my shit are the same colors. Red, black, and green :cookiemonster:
