Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Aug 31, 2017 at 7:13 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    bearing in middle getting more sloppy. I don't think the amount of movement has changed but it moves more easily than it use to.
  2. Aug 31, 2017 at 7:14 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    so don't do it on 70 mi per day daily driver...
  3. Aug 31, 2017 at 7:15 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    i just want vibrations gone. Had them gone/tolerable for a while. Back now.
    edit: Tom Woods site says they will make up to 75".
    beertimecontinuum likes this.
  4. Aug 31, 2017 at 7:32 AM
    The Taco Bear
    The Taco Bear Well-Known Member
    Franklin, Tennessee
    2018 4Runner TRD Off-Road
    2018 4Runner Off Road TRD SEMA Wheels TRD Skid Plate Prinsu Full Roof Rack RCI Skids Icon 2.5 ext front with resi Icon 2.0 ext rear T13 rear coils Camburg UCA RSG Sliders C4 LoPro 2011 Tacoma TX Pro — Sold Pelfreybilt hybrid bumper Icon 2.5 ext. Non Resi Icon 2.0 Rear with Resi Icon AAL Total Chaos UCAs CaliRaised LED Ditch Lights TRD Exhaust & Intake System TRD Fake Bead Lock Wheels BAMF Sliders Uniden Comm System w/ 4ft fire stick JBL Audio Future Mods: UBolt flip kit with bump stops. Dakars Skids Bed Rack
    Please enlighten me. I'm curious how :anonymous:
  5. Aug 31, 2017 at 8:24 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Tom Woods is a high end driveshaft specialist shop. We got a $600 quote for them for an aluminum 1 piece for the supra. If you buy one from them, I would trust it to be safe. But if you plan on running an aluminum driveshaft on your truck and offroading it the way we do, you are hustling backwards real quick. Building a trac bar doubling as a skid bar will help protect it but it's still gonna get hit. Hell just the rocks your front tires throw up on a gravel road will probably damage it.
    Keep in mind Levi also shortened his wheelbase ...
    Skootter14 likes this.
  6. Aug 31, 2017 at 8:25 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Send me your number and I'll tell you
  7. Aug 31, 2017 at 8:26 AM
    The Taco Bear
    Franklin, Tennessee
    I'm scared.
    dirty deeds and totmacher like this.
  8. Aug 31, 2017 at 8:27 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    You should be
  9. Aug 31, 2017 at 8:46 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Don't be shy little buddy. We all get fucked at some point in life.
  10. Aug 31, 2017 at 8:47 AM
    Kerleyfries
    Zack
    Lebanon
    Do you have mini h1's or D2S in your truck? I want HIDs again and know these are way easier to build than FXR's.
    Dave41079 likes this.
  11. Aug 31, 2017 at 9:07 AM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    I drive on the interstate quite often with mine.
    Very true however I'm only a inch or two shorter than a short bed. Pinion angle has a lot to do with it as well.
  12. Aug 31, 2017 at 9:30 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    depending on weather, i might mess with that again tonight in hope of short term improvement.
  13. Aug 31, 2017 at 11:06 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    If your carrier bearing it giving out, there's not much you can do to fix vibrations besides get a new one. It makes a huge difference. Go OEM though. Dorman is junk.
  14. Aug 31, 2017 at 11:06 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    D2S
  15. Aug 31, 2017 at 11:10 AM
    Kerleyfries
    Zack
    Lebanon
    This has been discussed. Thank you
  16. Aug 31, 2017 at 11:21 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    i'll either go 1-piece shaft or get the poly Ford Ranger bearing. On 2 tacomas, the oem hasn't impressed me.
  17. Aug 31, 2017 at 11:24 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    It's a stock part made for a stock truck. You shouldn't be impressed
    dirty deeds likes this.
  18. Aug 31, 2017 at 11:42 AM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
    please tell me more about this ranger bearing. :anonymous:
  19. Aug 31, 2017 at 12:03 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    1993 Ranger had 2 pc shaft. Bearing inner diameter was 30mm (1.1811"), same as 2nd gen tacoma.
    Inland Empire Driveline makes poly for Ranger.
    iedls.com
    item # 211590-1XS
    there was a tw group rate in past. Don't know if still active.
    edit: there is an option on Rockauto for $6.83 for ranger bearing. lol
  20. Aug 31, 2017 at 12:10 PM
    Red Demon
    Red Demon Well-Known Member
    Vinnie
    Kennett Missouri
    07 SR5 4x4
    Tinted windows Upgrade to New 2014 radio Weather Tech Front Lift:2.5 ICON Extended Travel Coilover Shocks Icon Uni Ball Tubular UCA Rear Lift: Icon 1.5" AAL ICON 2.0 Aluminum Series Rear Shock Relentless Front Bumper Relentless Rear Bumper SOS Sliders and skid plate
    Its not active ...its 125.00 you can find it on sale every once in a while
    https://www.iedls.com/#Search_Results
