Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Oct 9, 2017 at 9:48 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Also, you need at least 4.0 back spacing to keep them off the frame with a 255/85. Maybe more for 285/75
  2. Oct 9, 2017 at 9:52 AM
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Really? That's interesting. Haven't heard of anyone needing spacers or offset wheels for 255/85. What does your lift measure out to? I was planning on getting 255 bighorn next set but didn't think I'd need spacers
  3. Oct 9, 2017 at 9:57 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    No idea how much lift. Maybe 1.5-2"??? Wouldnt change anything.
  4. Oct 9, 2017 at 10:04 AM
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Might affect how the widest part of the tire contacts the frame.. idk I'll just have to see for myself I guess. Thanks, I'll reference your build thread when I get the money to upgrade probably
    rngr[QUOTED] likes this.
  5. Oct 9, 2017 at 10:09 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I found that out too, if you don't know what trails you are on you'll be surprised that you ran a few blues without noticing it.
    I still rub 33's fully cranked driver and fully cranked passenger :anonymous:
  6. Oct 9, 2017 at 10:20 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    And that's with 285 and 3.5 bs, yes?
    @Justinogo look, see ^^^
    Justinogo likes this.
  7. Oct 9, 2017 at 10:22 AM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    No rubbing on front for me with 33x10.5.
    Trim a little plastic and hammer the pinch weld and was good to go.
    11TRDTX and Justinogo like this.
  8. Oct 9, 2017 at 10:23 AM
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    haha yeah I'm staying away from 285. Seem harder to fit, and the weight/wider tire would probably destroy MPG and highway driving with 4.10s
  9. Oct 9, 2017 at 10:25 AM
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    This is more what I have heard from others with 33x10.5 or 255/85. Your wheel BS might help a little too
  10. Oct 9, 2017 at 10:26 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    That's so odd. 255/85 must be considably larger, regardless of the fact that they "should" be the same size.
  11. Oct 9, 2017 at 10:28 AM
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    In the expo west article you linked in your build, it shows the 255 to be 1.3" taller than 33x10.5
  12. Oct 9, 2017 at 10:29 AM
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    I can measure my newest one I bought after LBL and see what it measures out to. I've read them being up to 34" from the factory but I think that would be on a 7" wheels. I'm running 8" wheels. I would be shocked if mine are more than 33".
    Edit:
    That article is probably where I got that info from above. Pertains to the 255/85s not the 33x10.50s I guess.
  13. Oct 9, 2017 at 10:31 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    No 285 with 4.0 bs
  14. Oct 9, 2017 at 11:04 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Thought I'd throw this out there; 285/75r16 Cooper STT PROs. 885 OME coils with 1/2" spacers, stock UCAs. Bilstein 5100s. Stock TRD OR wheels.. Bora 1" spacers. Pelfreybilt aluminum bumper, Warn VR12s winch, synthetic line. 3pc Pelfreybilt aluminum skids. AllPro sliders. Sway bar in garage attic. Net lift ends up being 2-5/8" above where it was stock. DYF cmc. Routine plastic trim. Nothing too radical. You cannot make em rub. Lock to lock...forward or reverse. Stuffed to the bump stops (superbumps) STT PROs measured 32.7/8" new (center tread) on these wheels. Closest the tire comes to rubbing is a full inch. And that's plastic that could be cut more if needed. With lift I have alignment is good. (2.2 degees + caster) on stock UCAs at current ride height.
    Wheel spacers....mild lift...don't go nuts adding weight....It's all good. 42+ years driver experience...It goes where I want it to go. May not be BIGFOOT, but it gets me around. YMMV
  15. Oct 9, 2017 at 11:09 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Are y'all talking specifically about km2s? Because if not then there is gonna be a wide variance in your baseline.
    dirty deeds likes this.
  16. Oct 9, 2017 at 11:09 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    With you? No. Sounds boring ...
  17. Oct 9, 2017 at 11:12 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    But.... 1st gen.
    Brent and I, yes. Josh and I, no. And Justin is talking about mythical tires in the future. Science.
  18. Oct 9, 2017 at 11:14 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I've got STT Pros FWIW :notsure:
    Bluegrass Taco likes this.
  19. Oct 9, 2017 at 11:17 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Can't be held responsible for your mistakes
  20. Oct 9, 2017 at 11:53 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Carter beat me to it, I see.
    Our 2nd gens can't be expected to have the same fitment issue pros/cons as a first or third gen truck. Hell, not all 2nd gens are gonna be the same, according to TW :rolleyes:
