Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Oct 12, 2017 at 9:03 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Wait, what happened? I missed it
  2. Oct 12, 2017 at 9:08 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    wtf
    how many miles you drive it in that time period?
    I went 2 years on greens in my last truck and didn't see much wear on the pads.
  3. Oct 12, 2017 at 9:11 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    The yellows just aren't worth the money. Do they stop better? I'm sure but how often are you stopping that fast to need to see a difference in a few feet off your 60-0 times? I can't tell you I see a difference because I just don't slam on my breaks, ever. They create more dust, wear out faster and cost twice as much. I just don't use them for what they are intended for.
    Now the reason I switched was because I was thinking I don't drive my truck but maybe 5k miles a year so longevity over time should be fine so why not get "the best" and enjoy the benefits when I do drive. But once again, I never brake hard enough to enjoy them anyway so now, it makes no sense to me.
    Buy them if you think on a daily basis your truck just doesn't stop fast enough. Based on how I drive, I found the dimpled/slotted rotors to make a noticeable difference. I found the yellow pads to not.
  4. Oct 12, 2017 at 9:20 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Stock shackles fit dakars, just have to get the correct bushings. Or you can spend $50 or whatever and get the greasable shackles, which work perfectly with Dakars
    Justinogo likes this.
  5. Oct 12, 2017 at 9:32 AM
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    Anyone have any luck with Toyota OEM reman axels?
    I just about don’t have any other option really.
  6. Oct 12, 2017 at 9:35 AM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I do have the yellow pads (came with the stage 5, got during huge discount also). I like them with the weight of the truck offroad on steep hillsides. I cant vouch that they are "required" by any means. BUT after I wear these out (they've been on the truck for about 2 years) I may try the green, that way I will have had both and can pick which one I like best.
  7. Oct 12, 2017 at 9:49 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Just an FYI the green pads are a little dusty after a while
  8. Oct 12, 2017 at 9:52 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I'll be testing the PowerStop ceramic pads when I get time to install them.
    11TRDTX likes this.
  9. Oct 12, 2017 at 9:53 AM
    dirty deeds
    Nick
    Eastern KY
  10. Oct 12, 2017 at 9:54 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    30k on the odo, so maybe 35k. I brake hard though. Tailgating and shit
  11. Oct 12, 2017 at 9:56 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    driver mod
  12. Oct 12, 2017 at 9:57 AM
    Kerleyfries
    Zack
    Lebanon
    Ehh, driver seems to work so far. Not concerned with modding.
    totmacher[QUOTED] likes this.
  13. Oct 12, 2017 at 10:27 AM
    SouthernYoder
    Knoxvegas, TN
    So the re man ones are still pretty decent? That’s whats im understanding at least
  14. Oct 12, 2017 at 10:55 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I have no experience with running them. Just bought it last night. Ha ha. This is what I can tell you.
    When someone tears a boot and buys a new axle, Toyota gives a $75 core refund in exchange for the damaged axle. They take that axle, strip it down, and rebuild it with new OEM parts.
    Mine looks like this. Literally looks brand new.
    I turned in and old axle I had laying around, so the $275 reman cost me $200 plus tax.
    I don't think there is any advantage to buying this over rebuilding your own with OE boots. I did it because I wanted to keep my current leaking one and rebuild it for a spare. If you don't want a spare, you could rebuild your own and have the same thing I bought for $33 plus whatever the grease costs.
    Pick one
    • spend $200, turn in your old one for the core, and skip the messy work of rebuilding
    • spend $33 plus grease and rebuild yourself
    • Spend $275 for the reman and keep your current one to rebuild for a spare
    BYJOSHCOOK likes this.
  15. Oct 12, 2017 at 11:20 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    So what happened? I missed it.
    And yes, I'll ask you again ...
  16. Oct 12, 2017 at 11:21 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
  17. Oct 12, 2017 at 11:23 AM
    dirty deeds
    Nick
    Eastern KY
    Buying a house. I'm poor right now.
    And I looked at drilled/slotted and was afraid of mud buildup. Considered dimpled rotors, but cost beat them out.
  18. Oct 12, 2017 at 11:27 AM
    Kerleyfries
    Zack
    Lebanon
    Green it is
  19. Oct 12, 2017 at 11:35 AM
    SouthernYoder
    Knoxvegas, TN
    Just getting everyone’s opinion on re man axels.
    @rngr i plan on re building mine for future use as well.
    rngr likes this.
  20. Oct 12, 2017 at 11:50 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Oh ok. You mentioned it like you fucked something up and everyone had been helping you up to this point. Just didn't recall any of that. I have no advice then. Carry on. :D
