Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Oct 22, 2017 at 7:59 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    https://www.youtube.com/watch?v=fUCoI1bwfTg
    Knoxdavid34[QUOTED] likes this.
  2. Oct 23, 2017 at 6:10 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Cut them fenders too
  3. Oct 23, 2017 at 6:29 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    It's a combination of both axle and driver skill. It's hard to coach through text so I won't even try but the weak axle did not help your situation. OEM is much stronger. When you read "OEM spec" it's just a certain parameter they met that falls within the range Toyota says is ok. Something to equate it to that people are more familiar with: alignment. Ever get an alignment print out and see where it says something like " Ok camber range: -1.0 through +1.0"? That's a huge range but OEM spec says anywhere in there is fine. Put your alignment at +1° camber 6° caster and +.1° toe and see how hard it is not to crash into every car you pass. Haha
    That Autozone axle is fine for 99.9999% of Tacoma owners who have no intentions of every offroading their trucks, let alone driving over rocks or through ditches big enough to high center on. You just happen to fall in that .0001% that need something stronger. Toyota makes stronger axles because if people in stock Tacomas are breaking axles driving down their gravel driveway, they go under as a company from reputation, lost sales and free parts replacements. People that buy parts from Autozone will always buy parts from Autozone because "this is what I expect from something that cost half as much. I'll just buy another one and still save money."
  4. Oct 23, 2017 at 2:54 PM
    tacotim448
    tacotim448 Well-Known Member
    Tim
    Nashville
    2011 Money Pit
    It never efffing ends.....
    They’re next. I really want a bit more ground clearance and Dave convinced me 35’s make more sense than 285’s. That, or he is really really sadistic and likes to see people chop on their truck.
  5. Oct 23, 2017 at 5:09 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    He mutilates living people's bodies as a self chosen job. You really think he convinced you because "it made more sense"!?
  6. Oct 23, 2017 at 7:10 PM
    tacotim448
    Tim
    Nashville
    2011 Money Pit
    You make a very valid point.
  7. Oct 23, 2017 at 9:36 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Why can't it be both?
  8. Oct 24, 2017 at 7:21 AM
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    4X1IKAvBK3F_Yc7HHxg5r6bw4JyRCZhYddW_cAs-_8a7943cb3e842d06aac0e528b23f58193df09bd5.jpg
    Dat spacer... F150 on campus
  9. Oct 24, 2017 at 7:23 AM
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    :eek: That’s awesome
    Justinogo[QUOTED] likes this.
  10. Oct 24, 2017 at 7:41 AM
    TN_TacoSupreme
    TN_TacoSupreme The Yota Peddler
    Allen
    Springfield, TN
    2014 Silver Tacoma TRD Sport
    As much as I can til' my wife blocks my Amazon account...
  11. Oct 24, 2017 at 7:54 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    :facepalm:
  12. Oct 24, 2017 at 8:54 AM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
  13. Oct 24, 2017 at 9:01 AM
    Knoxdavid34
    Knoxdavid34 Stranger with candy
    David
    Nashville
    02 Prerunner 4x4
    TRD Off Road sticker. Not the whole package, just the sticker.
  14. Oct 24, 2017 at 9:18 AM
    Knoxdavid34
    David
    Nashville
    02 Prerunner 4x4
    That makes since. I always just assumed that "build to oem specs" meant the same strength. But you know what they say about assuming. Called cool springs toyota and they can get me a set of remanufactured for a lil under $400 and can have them in a week. I'll be putting the autozone axle in till I can get my hands on those.
  15. Oct 24, 2017 at 3:03 PM
    JBTacoma
    Jeff
    Cullman Alabama
    I usually hit mine 2 or 3 times and they pop out
  16. Oct 24, 2017 at 5:24 PM
    Knoxdavid34
    David
    Nashville
    02 Prerunner 4x4
    I didn't film it but found a way to get the stuck ones out easier. Used a rotary hammer in the hammer only mode. Used my grinder to cut a 5/8 masonry bit in half so it had a flat face. Put that on the stud, pulled the trigger, and out came the cone washer.
  17. Oct 24, 2017 at 5:36 PM
    JBTacoma
    Jeff
    Cullman Alabama
    https://www.youtube.com/watch?v=dbTpKa7Phkg
  18. Oct 24, 2017 at 6:02 PM
    Knoxdavid34
    David
    Nashville
    02 Prerunner 4x4
  19. Oct 24, 2017 at 6:07 PM
    tacotim448
    Tim
    Nashville
    2011 Money Pit
    You’re buying wheels, what brand and style do you go with and why?
    Asking for a friend.:anonymous:
    Dave41079 likes this.
  20. Oct 24, 2017 at 6:11 PM
    Dave41079
    Dave...
    Nashville, TN
    You saw my answer Sunday.
    tacotim448[QUOTED] likes this.
