Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Nov 30, 2017 at 10:38 AM
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    That is correct. Still wouldn't own one
    Ridgelines drive quite nice on the road for a pilot/odyssey with the back chopped off...
    This guy gets it
    Justinogo[QUOTED] likes this.
  2. Nov 30, 2017 at 11:01 AM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Anyone local to me have any interest in factory rubber floor mats for the front?
  3. Nov 30, 2017 at 11:19 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    We actually prefer to be referred to as Oregonese
    tacotim448, 14Tacos4me and 11TRDTX like this.
  4. Nov 30, 2017 at 11:21 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    It made a huge difference in my rear diff as far as any locker noises go and a huge difference in my transmission where I was 100% sure my second gear was going out where it grinded every single time I shifted into it no matter how soft or hard and I switched from Mobil One to Amsoil and it immediately made it better to where it only grinds if I don't engage the clutch all the way which I do on occasion. I didn't think it would be that noticeable of a difference between 2 full synthetic oils but I witness it every time I drive my truck.
    dirty deeds[QUOTED] likes this.
  5. Nov 30, 2017 at 11:26 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    What about Oregans? I kinda like that with a emphasis on the "an" spoke in your native tongue. Like a man sound. But an an sound. Real twangy like. Oregan man. Say it out loud and I'll tell you if you're saying it right.
    tacotim448 and 11TRDTX like this.
  6. Nov 30, 2017 at 11:28 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Knowledge bomb :boom:
    Thanks man!
    I'm due for a change at 30k intervals and real close to 60k at next erl change. I'll do diffs, t case, and trans then too.
  7. Nov 30, 2017 at 11:57 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I don't want to answer this right now. Fuck science.
    Just to give you something ..... a coil spring and a shock doesn't create a big enough surface area for load distribution. Keep in mind, your shock is solely designed for dampening (how the weight is moved around) and your spring is solely designed to carry that weight. Let's speak with the idea of just front to back of the bed. Ideally your load would be placed directly over a 90° vertical shock/spring. That would give you the best dampening capabilities and the most load capacity.
    In this example, all variables are identical except for the spring type and your bed is 72" long:
    Place a single shock and coil spring at 36". The spring diameter is 5". Set your weight directly over that 5" spot and you have ideal conditions for both the shock and spring. That leaves 67" of space for unideal conditions. Now place a single shock and a leaf spring at 36". The spring length is 48". Set your weight directly over that and you have ideal conditions for both shock and spring. That leaves 24" of space for unideal conditions. On paper, which would you prefer?
    Now there's a vast amount of other variables that come into play including how when the weight is moved to different areas of the length of the spring it creates leverage which creates differening dampening characteristics and load capacities and that it's much easier to precisely tune a coilover or shock/coil spring setup then a leaf spring setup because of how directly focused that 5" spot is making it so much more consistent. Blah blah blah BLAH!! FUCK!!!!
    I'm done. You made me talk more then I wanted to.
  8. Nov 30, 2017 at 12:06 PM
    TN_TacoSupreme
    TN_TacoSupreme The Yota Peddler
    Allen
    Springfield, TN
    2014 Silver Tacoma TRD Sport
    As much as I can til' my wife blocks my Amazon account...
  9. Nov 30, 2017 at 12:20 PM
    Dave41079
    Dave...
    Nashville, TN
    Is that why semis that carry heavy loads long distances have leaf springs that span half of the trailer? More ball busting...I love it.
  10. Nov 30, 2017 at 12:25 PM
    dirty deeds
    Nick
    Eastern KY
    So many "thens" and not enough "thans" :annoyed:
    Justinogo likes this.
  11. Nov 30, 2017 at 12:27 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Well than, calm down. Theirs more then enough to go around.
  12. Nov 30, 2017 at 12:28 PM
    dirty deeds
    Nick
    Eastern KY
    You won't get to use my iron skillet for duck fajitas
    rngr[QUOTED] likes this.
  13. Nov 30, 2017 at 1:45 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    You talking to me? I counted 1. Come up with better criticism you geriatric examitory fuck.
  14. Nov 30, 2017 at 1:48 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    It would clearly be much smarter if they used coils, like a bed spring matress, and strategically placed them in specifically marked locations where varying loads were placed. Who designs this crap!?
    Dave41079[QUOTED] likes this.
  15. Nov 30, 2017 at 2:02 PM
    dirty deeds
    Nick
    Eastern KY
    You did it in the LBL thread too. Why your panties so bound up right now?
  16. Nov 30, 2017 at 2:06 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    That time of the month
  17. Nov 30, 2017 at 2:17 PM
    Dave41079
    Dave...
    Nashville, TN
    Tempurpedic. Coil springs in beds is old technology.
  18. Nov 30, 2017 at 3:36 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Haha sorry. Dave made me wanna talk some shit. I apologize sir.
  19. Nov 30, 2017 at 3:36 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Hahaha that was good
  20. Nov 30, 2017 at 3:54 PM
    dirty deeds
    Nick
    Eastern KY
    I'll settle for one pee pee touch or a cool tandem drift pic with our black and white trucks
