Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Dec 20, 2017 at 11:14 AM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
    You don’t need the spacer. And there is no needle bearing on the passenger side.
    14Tacos4me[QUOTED] likes this.
  2. Dec 20, 2017 at 11:27 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Why are you in the clamshell to install a lift? ...
  3. Dec 20, 2017 at 11:33 AM
    14Tacos4me
    14Tacos4me Well-Known Member
    Daniel
    Hendersonville, TN
    2014 Blue Ribbon DCSB TRD OR 4x4
    -Fox 3 inch lift -SOS Streamline front bumper with Smittybilt x20 winch -Mobtown sliders -Mobtown IFS & Trans skids -DV8 Rear bumper - Look at the build thread
    To be honest I wondered the same thing, but I've seen a couple posts that say this is when they've swapped the bearings. More than likely it's just because they're already in the area and removed the wheel anyway.
    I only know enough about this to know that I'm stupid. :anonymous:
    Justinogo likes this.
  4. Dec 20, 2017 at 12:06 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I mean, who the hell drys papers for a living!?
    If you are swapping out the coilover and ucas, that's about half way to getting to where the needle bearing is. You then need to remove the hub center cap, axle nut and lca to knuckle bolts to swing the knuckle out of the way. Then you can pull the axle out where you will find the needle bearing. Driver side only though. If you pull the pass side you will find ball bearings. Reason for this is the construction of the front diff puts the center of the pumpkin off the the driver side leaving a hollow shaft on the pass side and creating a leverage point.The ball bearings are much stronger then the needle bearings so use the needle bearing on the short side.
    The problem that occurs is when you lift your truck it puts the axles at a more obtuse angle and ends up putting more pressure on those bearings. The ball bearings hold up, the needle bearings don't. So you ask, why didn't they just use the ball bearings on the driver side too? Idk how to answer that but they built it to be just fine on an OEM truck with stock degree axle shafts. Haha
  5. Dec 20, 2017 at 12:18 PM
    TN_TacoSupreme
    TN_TacoSupreme The Yota Peddler
    Allen
    Springfield, TN
    2014 Silver Tacoma TRD Sport
    As much as I can til' my wife blocks my Amazon account...
  6. Dec 20, 2017 at 6:56 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    KO2’s or ST MAX’s?
    Dave41079 likes this.
  7. Dec 20, 2017 at 7:06 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
  8. Dec 20, 2017 at 11:17 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    maxx or go home
    The Taco Bear and Dave41079 like this.
  9. Dec 21, 2017 at 4:55 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
  10. Dec 21, 2017 at 5:13 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    General Grabbers if you're wanting a basic bitch AT tire. Studdable, and I don't think the Kbro2 is
  11. Dec 21, 2017 at 7:17 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    too far south. tires don't need studs.
  12. Dec 21, 2017 at 7:35 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Studs? We don't even do that up here in snow country.
    11TRDTX and dirty deeds like this.
  13. Dec 21, 2017 at 7:48 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    I think he meant zombie studs. Like for driving through a crowd of post-apocalyptic folk who want to steal your milk and bread.
    11TRDTX, ThunderOne, slander and 2 others like this.
  14. Dec 21, 2017 at 7:54 AM
    TN_TacoSupreme
    Allen
    Springfield, TN
    & BEER
  15. Dec 21, 2017 at 8:06 AM
    dirty deeds
    Nick
    Eastern KY
    I just mean they'll draw in the dudes :anonymous:
    14Tacos4me and beertimecontinuum like this.
  16. Dec 21, 2017 at 8:14 AM
    beertimecontinuum
    Everett
    Going to build my Taco and turn gay FTW!!
  17. Dec 21, 2017 at 8:18 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    have any of you ever put seafoam, amsoil cleaner, or some other additive into your motor oil? Think it did anything?
  18. Dec 21, 2017 at 8:27 AM
    slander
    Hickory, NC
    Quoted for truth
  19. Dec 21, 2017 at 9:09 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    did seafoam once. Not really sure it did anything.
  20. Dec 21, 2017 at 9:35 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I did seafoam through my throttle body and fuck, it shot out all kinds of shit through the exhaust. Take a look at your throttle body. If it's dirty on top or around the butterfly door then you know it's dirty inside the motor as well. That shit will clean it out. Also some kind of fuel additive will work the same with cleaning the injectors out.
    When you do it, it shouldn't be a noticeable difference. If you've let the engine get that bad then your main concern should be with being better about regular maintenance. I run a bottle of something with a tank of gas about once a year just because. But there's not much of an argument to the science behind certain chemicals cleaning out fuel deposits and oil sludge
    TN_TacoSupreme and 11TRDTX like this.
