Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jan 23, 2018 at 7:34 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Toyota used Red stuff, I used gray high temp Permatex
    tacotim448 likes this.
  2. Jan 23, 2018 at 7:50 PM
    tacotim448
    tacotim448 Well-Known Member
    Tim
    Nashville
    2011 Money Pit
    It never efffing ends.....
    Me too....thanks to Mikes home supply.
  3. Jan 23, 2018 at 7:53 PM
    tacotim448
    Tim
    Nashville
    2011 Money Pit
    I’ve got a “lightly” used set of 255 75R17 STT Pros for sale if you go that route. They only have about 10k miles on them.
    dirty deeds likes this.
  4. Jan 23, 2018 at 7:59 PM
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    The stock air box is not sealed... any water high enough to get to the air box, would kill the engine unless you've gone through great measure to make it perfectly sealed. Moving helps.... I feel like we've been over this a half dozen times in as many threads. Is the horse dead yet?
    Cut head of old bolt. Install new bolt upside down. No, it won't slide out if torqued properly - other vehicles have it installed that way. This is how I did mine. I've had it installed for ~25k miles, I've checked the torque, it hasn't budged. You could even install a 2nd nut to lock it if that makes you feel safe (there's enough space on the bolt to do so)
    14Tacos4me and dirty deeds like this.
  5. Jan 23, 2018 at 8:03 PM
    MowHawk
    MowHawk Well-Known Member
    ClarksVegas (Middle TN)
    '16 Black Taco TRD Sport 4WD
    Thanks, definitely interested. PM me what your asking. Wonder if they would fit the oem rims?
  6. Jan 24, 2018 at 4:36 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I'm sure they would. A 255 is more tall skinny. Tim is a good dude and will give you a fair deal.
    Also, other people have said this and I mirror it .... do your lift yourself. I know you say you don't have the means to do it but other people do and are willing to help for much less then what a shop would charge. We aren't all master mechanics but most of us are very familiar with our trucks. This forum is a fantastic place to find help for these exact things to keep someone like you from having to pay a bunch of money for something that you CAN do yourself. Just ask. It may surprise you ;)
  7. Jan 24, 2018 at 4:39 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    This. A bunch!!
  8. Jan 24, 2018 at 5:14 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I’d even be willing to help.
    Mr.Bl0nde, Kerleyfries and tacotim448 like this.
  9. Jan 24, 2018 at 5:15 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Am I missing something?
    My 3rd member seems to be one with my axle housing. All of the nuts are removed holding it to the housing. Axles are out. Should it be really hard to separate?
    Red Demon and beertimecontinuum like this.
  10. Jan 24, 2018 at 5:21 AM
    beertimecontinuum
    Everett
    IF it's the first time it's been out it still has the orange RTV, which is like concrete lol. I'm assuming you have disengaged the axles from the diff....
    rngr[QUOTED] likes this.
  11. Jan 24, 2018 at 5:22 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Yes it should. Put a floor jack under the pinion, apply some pressure, and when you make a gap between the 3rd and the axle get a big ass pry bar in there to start working it loose. It's "stuck" on there via the gasket.
    Watch out that 3rd is crazy heavy!
  12. Jan 24, 2018 at 5:22 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Scratch that. BFH prevails, as usual.
  13. Jan 24, 2018 at 5:23 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    BFC (big f$&@in chisel) with the assist.
  14. Jan 24, 2018 at 5:49 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Just always listen to Dave. "Stop being a little bitch Carter."
  15. Jan 24, 2018 at 5:51 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Was that before or after our swim?
  16. Jan 24, 2018 at 5:53 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Ermahgerddd, derfs
  17. Jan 24, 2018 at 5:57 AM
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    You gonna run with 5.29s and 255/85 for a while or order your Dirty Fives right away?
  18. Jan 24, 2018 at 5:58 AM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
    This^^
  19. Jan 24, 2018 at 5:58 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Keeping these for a while. :turtleride:
  20. Jan 24, 2018 at 6:00 AM
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Dat torque with 5.29s :burnrubber::bikewheelie:
    beertimecontinuum likes this.
