Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Mar 25, 2018 at 3:58 PM
    TN_TacoSupreme
    TN_TacoSupreme The Yota Peddler
    Allen
    Springfield, TN
    2014 Silver Tacoma TRD Sport
    As much as I can til' my wife blocks my Amazon account...
    Cool. If you decide to come you can either hook up at the camp area or Saturday morning on the way through Knox. Let me know and I’ll keep you in the loop if you wanna roll with us. :fistbump:
  2. Mar 25, 2018 at 4:07 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Sounds good!
  3. Mar 26, 2018 at 5:36 AM
    TN_TacoSupreme
    Allen
    Springfield, TN
    Anyone happen to have an OEM trailer plug setup for a 2nd gen they’d consider parting with? Mine got smooshed at LBL
  4. Mar 26, 2018 at 2:16 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    I have one I'd part with. It's priced a little high, but comes with a free truck.
  5. Mar 26, 2018 at 3:02 PM
    TN_TacoSupreme
    Allen
    Springfield, TN
    Let me think about that for a moment.....
  6. Mar 26, 2018 at 6:35 PM
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    What’d I miss? Why are you trying to sell your truck?
  7. Mar 27, 2018 at 12:35 AM
    Dave41079
    Dave...
    Nashville, TN
    Wife wants something different so I'm selling the truck and taking over the 4runner.
    tacabode[QUOTED] likes this.
  8. Mar 27, 2018 at 1:29 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Does she like Tacomas?
  9. Mar 27, 2018 at 8:31 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I'm still washing mud out from underneath my truck. Maybe today I'll have the chance to actually wash the outside part.
  10. Mar 27, 2018 at 10:57 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Went to dealer again about intermittent drop in power.
    Again it drove perfectly on test drive with tech. Anything we think it might be, should cause a CEL. I get no light and not even any "pending" codes.
    I'm at the point where i either don't worry and continue waiting for obvious catastrophic failure or throw money away replacing any possibly suspect parts.
    On the plus side, if the motor blows, @beertimecontinuum can guide me through a V8 swap.
    :p
  11. Mar 27, 2018 at 11:08 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    weak fuel pump? Fuel filter clogged? Dirty injectors? Checked fuel pressure regulator?
    Skootter14 likes this.
  12. Mar 27, 2018 at 11:14 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    don't know.
    Timing retards significantly during moderate-hard accelleration sometimes. Random and intermittent. No pattern to it.
    Idles good, cruises fine. No stumbling or stuttering. Just won't rev or put much power to the wheels and pings badly. No clue what makes timing drop though.
  13. Mar 27, 2018 at 11:36 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    hmm... I'm still leaning towards fuel issue. I would check all of the above that I mentioned. You could have them check the FPR pressure, replace the fuel filter. Also, most places can run your injectors through a cleaning system. The fuel pump would be the last thing I would check, just because of the labor involved.
    The pinging and timing retardation makes me think the ECU is compensating for lack of fuel delivery. Hence the ping and subsequent timing retard.
  14. Mar 27, 2018 at 12:37 PM
    tacabode
    Ohio
    '14 MGM DCSB TRD OR
    My civic “hiccups” under hard acceleration and occasionally throw a code for the o2 sensors. I’ve been putting it off, I don’t like that car anyway...
    It makes sense that it would be fuel delivery but there’s a number of gremlins that could be causing it. I hope you get it sorted out!
  15. Mar 27, 2018 at 12:51 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    my understanding is 2nd gen = no fuel filter. Has pickup screen on pump in the tank. Not easy to check or clean in my opinion.
    Without more to go on and being intermittent, dealer wasn't interested in chasing it down for me. Especially since I said it's warranty item. First went in about it while still in the 36k standard warranty period.
    I'm at 59,900 miles now. First time it happened was under 30,000. Hasn't gotten worse or better. So totally random when it happens. That lack of any pattern is what makes it so frustrating.
    I imagine it almost as if there could be a chunk of something floating in my gas tank or oil that just randomly swirls up to cause a blockage sometimes. But I also assume that so many oil changes should have flushed it out by now if it was in oil. And if in gas tank, I should notice issues more when tank has less gas in it since that would concentrate the crud but nope. Before or after oil change, full gas or low, seem to not be a pattern either.
    Or some small moving piece that got slightly sticky somehow and just happens to drag once in a while.
    :boom:
  16. Mar 27, 2018 at 1:22 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Have you tried different fuel grades?
  17. Mar 27, 2018 at 1:29 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    yes. been running 93 for over a month. still happens randomly but at least pinging sounds less severe when it does happen.
  18. Mar 27, 2018 at 1:54 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Sell it buy a first gen, build the piss out of it. Problem solved :D
    totmacher, Justinogo and ThunderOne like this.
  19. Mar 27, 2018 at 2:09 PM
    Dave41079
    Dave...
    Nashville, TN
    You said that wrong. You could guide him through the swap. At the rate things are going, cars will be flying before he's done. :D
    KRAMERICA likes this.
  20. Mar 27, 2018 at 2:36 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    that to me means you have a fuel problem. Not sure where, but there are only a few things to check within the system. I would start by checking the FPR and maybe running some B12 chemtool or Techron Concentrate through there. I run a full dose on a half a tank, I like my cleaning concoction to be strong. Put it in on empty, fill up with about 6-7 gallons of gas.
    I agree though, problems at 36k miles is kinda ridiculous..
