Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Apr 4, 2018 at 6:35 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Go to your link. Scroll down. Click the drop down for specifications. See “approved wheel width”
    jgill21[QUOTED] likes this.
  2. Apr 4, 2018 at 6:36 PM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    forgive me for I am blind
  3. Apr 4, 2018 at 6:57 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Running a narrower wheel will help keep the bead on when you air down
    Dave41079, Justinogo and jgill21 like this.
  4. Apr 4, 2018 at 6:58 PM
    jgill21
    Jake
    Nashville
    How low do you guys air down to?
  5. Apr 4, 2018 at 7:01 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Like 8...
    But I was on 37x12.5/r15’s on 8” steel wheels. Never did lose a bead
  6. Apr 4, 2018 at 7:13 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    18-22 has been ok for me.
  7. Apr 4, 2018 at 7:14 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    15
  8. Apr 4, 2018 at 7:32 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    52
    Minus 37 :D
  9. Apr 5, 2018 at 1:01 AM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    8-12, also a 12.50 on an 8 inch wheel.
    jgill21 likes this.
  10. Apr 5, 2018 at 4:05 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    5 to 10 for me (beadlocks)
  11. Apr 5, 2018 at 4:45 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Usually 15 for me
  12. Apr 5, 2018 at 4:47 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Weren't you there on my first AOP trip a like 3 years ago or whatever when I had my white A/C sport?
  13. Apr 5, 2018 at 6:46 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I can't recall for certain, but I don't think so. My first trip to AOP was two years ago.
    mosquitoTaco[QUOTED] likes this.
  14. Apr 5, 2018 at 7:32 PM
    mosquitoTaco
    Anthony
    SouthTennessee
    Gotcha, I wasn't sure if it was you or not, guess I'll meet you on this next one :cheers:
  15. Apr 5, 2018 at 7:41 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    We have met before.:hattip: You stopped in at the AOP meet I was the OP for last fall. :cheers:
  16. Apr 6, 2018 at 9:43 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I had a few hundred miles of awesome/normal performance from the truck, then yesterday about 5 minutes of oddness, then back to normal. The Seafoam trifecta (in oil, gas, & TB) that I did last weekend didn't make any difference.
    But I did notice something new. Don't know if it's always happened or if it's totally new symptom. Can only see 4 things at a time on the Scangauge and I had some different displays up from what is usually on it so who knows.
    First, a recap:
    truck always runs smooth, no rough idle or lurching or anything else odd. Very randomly and intermittently, it simply doesn't put much power to the wheels under moderate-hard acceleration and has pinging during that time. Takes forever to get up to 40+ MPH. If I let off the gas to accelerate slowly, everything sounds & feels fine, just going slow. Shift to N and rev, it revs smooth and quick like it should. During such events, the timing retards to near or below 0. Sometimes lasts a few seconds or few minutes but always corrects itself as I continue on. No CEL or pending codes. Normal maintenance stuff has never made a difference. Spark plugs, TB cleaning, MAF cleaning, fuel system cleaners, PCV valve, oil change, ATF change, etc. When it happens is totally random and unpredictable. No common threads that I can figure out. Full tank of gas, near empty tank, cold engine, hot engine, weather, grade of gas, source of gas, use of fuel additives, color of my underwear, direction the sparrow flies at noon... none of it seems to matter.
    Newly noticed:
    When I noticed the power loss and timing drop yesterday, also saw the truck had switched to open loop at under 2k RPM as I tried to accelerate from a stop. I normally don't see open loop until around 4k. Also, the AFR dropped to 11.9 which is typical for open loop. AFR is generally around 14 in closed loop.
    Thinking more:
    Might not be related, but maybe it is, sometimes the transmission hangs and doesn't upshift to overdrive at cruising speed after accelerating.
    So, the question for you guys:
    Could it be as simple as a coolant temp sensor or upstream O2 sensor that spazzes for some reason once in a while? Seems like either of those could affect all of the things I've seen and maybe be not quite bad enough to trigger the CEL.
    How can I test for a condition that is intermittent and unpredictable anyway? It's been going on for over 30k miles and nothing has blown up yet but I really want to figure this out. Service techs don't care and don't know what to do since the computer isn't giving any codes.
    @beertimecontinuum what are you doing with your 4.0 engine? Could I borrow parts off it maybe to help me troubleshoot so I don't spend $hundreds on a bunch of parts I don't need?
    mosquitoTaco likes this.
  17. Apr 6, 2018 at 9:58 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    Well fixed my stupid wiper blade arm, No more hitting the A pillar.
  18. Apr 6, 2018 at 1:24 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    You can have/borrow anything you need, I am planning on saving the 4.0 and possibly repairing at a later date. Me and @dirty deeds are playing trucks tomorrow if you want to come up :cheers:
    dirty deeds likes this.
  19. Apr 6, 2018 at 2:18 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    wish i could but I'm taking the kids to their running class thing tomorrow. I'll figure out what I want and work something out around the RRG trip timeframe.
  20. Apr 6, 2018 at 4:05 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Figured it was high time to replace my leaky, uncomfortable 5 year old boots with some new ones.
    KRAMERICA likes this.
