Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Sep 25, 2018 at 12:11 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    In general if it's just trail riding/mud riding through the woods, you're looking for a psi for comfort. Depending on the tire, and on a non beadlock wheel, anything from 14 - 20 is a good, safe area to be in (the higher the load range of the tire, the lower in that area you should be). There will be a point in airing down where your tire goes from "looking a little low on air" to "looking flat". There is no reason to be low enough in psi to "look flat" when just trail riding.
    In general, for rocks, you want to be as low as possible within reason of the tire and wheel combo. For most people with "fancy" cast or aluminum wheels and radial offroad tires, that number will never go below 12. Anything below that really seems to be a game of "when will you debead, not if". At that psi level, you can get a soft tire, like a KM2, to completely fold over on itself while still staying on the wheel. For a stiffer tire, like a Trail Grappler, it will take a lower psi to create the same fold but that probably wont be enough psi to hold the bead. Keeping the tire on the wheel becomes the more important thing here. Once again, you will reach a point where the tire "looks flat". This is fine for rocks as you want the tire to wrap around them as much as possible but you will also reach a point of diminishing returns. Your tire will only wrap around a rock so much. Once its low enough to fold over on itself, mission accomplished. There's no reason to run lower psi than that. You will also start to lose a considerable amount of ground clearance when going from "looking low" to "looking flat". At that point you're making a compromise for traction over ground clearance. But once again, 1 psi doesnt mean better traction even if the tire stays on the wheel. Picking a happy medium in there is key and in general is not gonna require sub 10 psi levels anyway.
    Play with your tire setup and see for yourself what it does. Once you go below 15 psi, you can physically tell differences in performance per psi you drop. The difference in 14 and 12 psi is huge. A complete game changer in instances. You just gotta try it for yourself.
    Now beadlocks and bias tires is a whole different set of rules but I'm assuming you aren't running either.
  2. Sep 25, 2018 at 2:33 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    good info. I usually run 16-18psi cause I don't trust my non-beadlock wheels. They still "squish" around stuff, but don't do it so much that I am waiting for it to bust loose.
  3. Sep 25, 2018 at 3:04 PM
    tacotim448
    tacotim448 Well-Known Member
    Tim
    Nashville
    2011 Money Pit
    It never efffing ends.....
    That’s all great info.
    My problem has been these cheap ass Discount Tire wheels. They are shit. I have 5 de-beads to prove it.
    Now, it hasn’t been the tire/wheel setups fault each time. I’m always pushing the limits that @allmotorrex mentioned. The last time I de-beaded I was running 8 psi. Which in hindsight was to low for the situation...LBL. But, I ran a ton of trails in MOAB at 8 psi with no issue.
    I’m hoping to have beadlocks before AOP {fingers crossed}. If I do, anyone want these crap wheels? They’d make good crappie bed weights.
    11TRDTX and Dave41079 like this.
  4. Sep 25, 2018 at 3:17 PM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
    17s?
    How much?
  5. Sep 25, 2018 at 4:02 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Damn. Tough sell. Hard to say no to that!
  6. Sep 25, 2018 at 4:14 PM
    tacotim448
    Tim
    Nashville
    2011 Money Pit
    17’s yes. If the beadlocks come through you can have them. Set of 5.
    Mr.Bl0nde[QUOTED] likes this.
  7. Sep 25, 2018 at 4:50 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  8. Sep 25, 2018 at 5:00 PM
    tacotim448
    Tim
    Nashville
    2011 Money Pit
  9. Sep 25, 2018 at 5:04 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    2psi
    When I didn't have beadlocks it was 10
  10. Sep 25, 2018 at 6:00 PM
    beertimecontinuum
    Everett
    The DIY ring kit is from jester fab, the wheels are forged steel 17x9 -38 proChump series 97 but I would not recommend this wheel. I had to clearance the dimples of the wheel and my calipers to get clearance even with a 1/4" spacer and extended lug bolts. Don't recall the weight except heavy duty, price was good for what you get but dont recall exactly .... 1000$ish I guess. For ease of build I'd say just make sure you get forged steel instead of cast to make them easier to weld/repair. Think I committed more time than skill to the total project :cheers:
    https://www.instagram.com/p/BUvDHLwjIaS/?utm_source=ig_share_sheet&igshid=1cj0alxb168fi
    https://www.instagram.com/p/BUxpg0FDCxK/?utm_source=ig_share_sheet&igshid=15ejc4iabamaa
    https://www.instagram.com/p/BU0eYTxDz9Z/?utm_source=ig_share_sheet&igshid=t2mqogj4w0z
  11. Sep 25, 2018 at 6:03 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Loved my cheapie Jegs branded steel wheels. Never lost a bead at 8 psi and no beadlocks.
    8 without beadlocks 5-6 with beadlocks and broken in tires
    tacotim448 likes this.
  12. Sep 25, 2018 at 6:41 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Gideon and mine are both roughly 56ish pounds per a wheel, hardware, and outer ring.
  13. Sep 25, 2018 at 7:51 PM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
  14. Sep 25, 2018 at 7:52 PM
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    AOP got you motivated?
  15. Sep 25, 2018 at 7:54 PM
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Yeah just really like going camping and hanging out with you douchebags and having the truck makes it way easier.
  16. Sep 25, 2018 at 7:55 PM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Finally!
    You're much stronger than me, don't take 4 days to do it lol
  17. Sep 25, 2018 at 7:58 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    You go guuurl
  18. Sep 25, 2018 at 8:10 PM
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    I had 2 other mechanically inclined sets of hands to help me. Turns out it makes life a lot easier to have help and the right tools.
    Gotta get the flywheel resurfaced then we'll start throwing stuff back together.
  19. Sep 25, 2018 at 9:55 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
  20. Sep 26, 2018 at 5:13 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Return to Black Mountain.
    End of October.
    Kenstaroni and Dave41079 like this.
