Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jan 22, 2019 at 5:23 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Take it off and test it out then you can put it back on. Tie that sucker up and put some pool noodles on the ends if you want. It’s just a suggestion to see if that isolates the noise.
    PopeHodge[QUOTED] likes this.
  2. Jan 22, 2019 at 6:28 PM
    PopeHodge
    PopeHodge Well-Known Member
    High Country, Colorado
    23 TRD OR DCLB
    Oh no, that's a great suggestion. I'm definitely willing to take it off to see if that's what the issue is. I'm just not going to leave it off long term.
  3. Jan 22, 2019 at 8:22 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I thought much the same thing and fused to take it off for a long time. But once I finally removed mine, I have to say I don't miss it! :popcorn:
    BigMacMcCoy, dirty deeds and 11TRDTX like this.
  4. Jan 23, 2019 at 6:20 AM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
    Told ya!
  5. Jan 23, 2019 at 6:26 AM
    Knoxdavid34
    Knoxdavid34 Stranger with candy
    David
    Nashville
    02 Prerunner 4x4
    TRD Off Road sticker. Not the whole package, just the sticker.
    What are ya'lls thoughts on auto zone u joint. Should I stick with toyota oem or are autozone ok. Getting ready to change mine in the next couple weeks. I learned my lesson on the cv asked they sell but does that apply to all drive line parts?
    11TRDTX likes this.
  6. Jan 23, 2019 at 7:05 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    That applies to all vatozone parts.
    Justinogo likes this.
  7. Jan 23, 2019 at 8:47 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Just buy Spicer
    Mr.Bl0nde, Justinogo and Dave41079 like this.
  8. Jan 23, 2019 at 8:59 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    ^ this.
    Even though i used Moog on my last 2 Tacomas.
    RockAuto had good prices for both Moog and Dana/Spicer options when i was looking.
  9. Jan 23, 2019 at 9:12 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Can't believe no one asked you when its clunking ..... I'll do it ....
    So when are you getting the clunk? Suspension compression, suspension rebound, in forward, in reverse, over small bumps at slow speeds, over speed bumps at slow speeds, over small bumps at fast speeds, over every bump in the road regardless of speed, while turning slightly, while turning full lock, while swerving back and forth, when on the brakes, when on the brakes hard ...... I may have forgot something.
    My first few thoughts, assuming all you did was pull out the stock strut and put in the coilover, is ....
    1. it's the shock topping out internally on full rebound
    2. its using poly bushings or derlin bushings and uniballs instead of oem rubber bushing
    3. now since your static ride height has changed significantly, worn lca bushing or inner tie rod bushings are being shown
    4. it's a shitty coilover and has plotted against you and plans on exploding just as you start a turn around a canyon road with a 1000' vertical rock face leading to a diverse pit of jagged rocks and thriving cacti where, after barely surviving the terrifying fall and scorching inferno you used to call your truck, you will inevitably kill yourself from sleep deprivation having spent your remaining days thinking about how if only you had taken the 4th guess on this list seriously, you wouldn't be looking forward to spending the rest of eternity playing cowboys and Indians with Hitler
  10. Jan 23, 2019 at 9:15 AM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    Same. Also clunking.
    Same. Wasn't worried until this thread.
    That's my plan with the larger tires, I was curious to see if the clunking would stop.
  11. Jan 23, 2019 at 9:37 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    My daily is my truck, 42 miles to and from work. Fuck that sway bar. Ain't flopped over yet! I'll catch enough hell for the armor if I get into an accident.
    Animals and people that I may have to swerve around, you say? Why else did I put the cheap ebay bumper on then?
    11TRDTX and ThunderOne like this.
  12. Jan 23, 2019 at 10:57 AM
    PopeHodge
    23 TRD OR DCLB
    I like this post. Thank you for it.
    Clunk is only, noticeably, happening at speeds under 20 MPH going forward (though I haven't driven in reverse over a speed bump lately). Happens when the wheel is straight, slightly turned, or full lock. Both during braking and non-braking.
    I replaced the UCA's as well. Other than that, yes all I did was pull out the stock strut.
    1) I guess it could be, but I'd be very surprised. Especially with an Extended travel coil-over. Full rebound on a small bump into a driveway?
    2) No idea.
    3) Possibly.
    4) 100% this has to be it.
  13. Jan 23, 2019 at 11:02 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    When’re we cutting your truck up? And what’s the deal on the highlander?
  14. Jan 23, 2019 at 11:19 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    My 2nd gen had a clunk from worn LCA bushings. Video is a FJ, but you get the idea. Pretty easy to tape your phone in there and get a video.
    https://youtu.be/aawh9ko8cDU
    BigMacMcCoy likes this.
  15. Jan 23, 2019 at 11:34 AM
    BigMacMcCoy
    Braedon
    Vienna, VA
    No word on the Highlander yet. Supposedly they are still tearing it apart and getting me a quote? I was going to call them today and check in.
    Once I'm not daily-ing the truck anymore I'm down to cut it and fit these new tires on. Still need to buy some TPMS/normal valve stems and then get one of them mounted up. Not sure if I want to go TPMS or if I even can on these wheels.
  16. Jan 23, 2019 at 11:39 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    What's a sway bar?
    11TRDTX, dirty deeds and BigMacMcCoy like this.
  17. Jan 23, 2019 at 11:43 AM
    dirty deeds
    Nick
    Eastern KY
    Right.
    Run trails with it on. Then take it off and run those same trails. It will stay off. I'm sure my 885s keep mine from rolling too much as well
  18. Jan 23, 2019 at 11:43 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You only drive 5 minutes to work, you would be better off DDing your tank. That way if you get hit you can say "oh, looks fine here... ooooh :( .. sorry about your car. Have a nice day" and drive off. Also people generally will give you more space.
  19. Jan 23, 2019 at 11:44 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I think I threw my sway bar away about a decade ago.
    With stock squishy suspension, sure, use it. But with a lift and tighter coils/shocks doing all the work, there's hardly a need for it.
    I will say @PopeHodge to take a pic of your CV angles, something tells me you have too much front lift and the suspension is constantly topping out on the rebound stroke. Speaking from experience.
  20. Jan 23, 2019 at 11:57 AM
    BigMacMcCoy
    Braedon
    Vienna, VA
    You're probably right, but I'd also be a whole lot more sad if I got into an accident in my truck than in a beater.
    I've got 600lbs coils, and I'd probably run without a swaybar. I'd be even more comfortable with 650s or 700s though. Especially if you're not DDing it.
