Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Feb 6, 2019 at 8:10 AM
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Honestly thought it would be worse haha
  2. Feb 6, 2019 at 8:11 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    yes but @Knoxdavid34 put the fear of God into me haha
  3. Feb 6, 2019 at 8:19 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    It’s basically a 140amp hot glue gun for metal. Pull the trigger, turn the dials till your making bacon and start sticking stuff together. @slander didnt even own a welder when he cut his frame off lol
  4. Feb 6, 2019 at 8:38 AM
    Knoxdavid34
    Knoxdavid34 Stranger with candy
    David
    Nashville
    02 Prerunner 4x4
    TRD Off Road sticker. Not the whole package, just the sticker.
    Dont be scared. Again it's not anything hard. Just weld the bolt 1/4 inch at I time. I just didnt want you guys to just run a weld around the whole nut in one pass and get pissed when the bolt wont go in. Even if you mess up, grind it off and try again. Nuts and welding wire cost pennies
  5. Feb 6, 2019 at 8:43 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    what type of welder? Don't you have to get some kind of special gas too?
    Bluegrass Taco likes this.
  6. Feb 6, 2019 at 8:44 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    that's true I guess. I think maybe 3-4 tack welds would be more than enough to hold it on.
  7. Feb 6, 2019 at 8:51 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Either use flux core wire, or, argon "shielding gas". Argon weld quality is arguably better....but flux core is one less "consumable" (cost) Argon shielded welding doesn't do so well if you weld out doors where wind blows the argon away from point of weld. Flux core welding requires cleaner steel from my (limited) experience. (Tends to splatter if there's dirt/rust present.) Either will work. Prettiest welds come via argon and proper conditions.
  8. Feb 6, 2019 at 10:24 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    so for a DIYer, flux core since it doesn't require gas?
  9. Feb 6, 2019 at 10:24 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Maybe I'll finally do the tack weld on my steering column too while I've got Zack's help
    BigMacMcCoy likes this.
  10. Feb 6, 2019 at 10:32 AM
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Flux core is great for the kind of stuff we do. Not as pretty but can still look good with a quick flap disk pass, and you save all that gas money. Plus you don't have to worry quite as much about how clean you get the metal beforehand
  11. Feb 6, 2019 at 10:32 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Learn to weld with flux core and upgrade equipment as you get better and/or have more money to invest.
    Or else plant a money tree....
    Lincoln (as well as other brands) sells kits that include argon tank and lines with the welder itself. That's what I have. Did the "buy once/cry once" thingy...
    Also worth mentioning; Welding classes take some of the arc out of the learning curve (pardon the welding pun) It's not impossible to learn by doing, but there's a lot of secrets you can pick up from an experienced instructor. I was able to take mine through local adult education classes at the high school nearby.
    ThunderOne[QUOTED] likes this.
  12. Feb 6, 2019 at 11:13 AM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    I use a Hobart Handler 140. Gas shielded wire is way cheaper than flux cored wire so the cost is offset. I just prefer flux core for working in the garage or driveway so that I am not fighting the wind, dirty metal, etc. 75/25 is typical MIG gas...I have a bottle around for like when I built my exo and wanted to cut down on the splatter that I had to protect the body/windows from.
    https://www.northerntool.com/shop/tools/product_200471413_200471413
  13. Feb 6, 2019 at 12:32 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Can confirm that welding in driveway on a windy day wastes gas. But it makes pretty weld if no wind.
  14. Feb 6, 2019 at 12:40 PM
    marco221
    marco221 Member
    Marco
    Nashville, TN
    2018 Black Tacoma TRDOR
    Anyone familiar with a smaller shop that can do some aluminum welding in the Nashville area? Looking to fabricate a tube frame
    Appreciate the feedback!
  15. Feb 6, 2019 at 12:50 PM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    beertimecontinuum and 14Tacos4me like this.
  16. Feb 6, 2019 at 1:07 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Not sure what you’re looking for as for a “tube frame” but maybe message @Thirty8special and see if it’s something they’d be interested in.
  17. Feb 6, 2019 at 1:11 PM
    Kerleyfries
    Zack
    Lebanon
    If I fuck it up, I’ll buy ya some new bolts. Lmao.
    I wouldn’t try that anyways. I’d be afraid of melting through the bed.
    Can be done.
    The most expensive part is buying the bottle. Refills are dirt cheap. I think a refill for the 80cu bottle I have is like $25 and it was enough gas to build my trailer ground up. Plus you get much prettier welds.
  18. Feb 6, 2019 at 1:31 PM
    Kerleyfries
    Zack
    Lebanon
    I have lots and lots of questions....
    Starting with: why are my pants moving?
    Jokes aside; if this works out as great as It looks, it’s a huge game changer. I’d be interested to see the price though. I’m thinking it’ll be near 1x,xxx range for the whole shabang with the rack and new spindles, etc...
    Dave41079 and BigMacMcCoy like this.
  19. Feb 6, 2019 at 1:33 PM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Yeah it's dope. I bet it's at least $10k.
  20. Feb 6, 2019 at 1:34 PM
    Kerleyfries
    Zack
    Lebanon
    I was editing as you posted lmao.
