Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jul 9, 2019 at 7:03 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  2. Jul 9, 2019 at 12:21 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    If the air conditioner on a car is not dripping condensation, is that always a sign of low freon or do some cars just not drip much?
  3. Jul 9, 2019 at 12:44 PM
    SemperHouse
    SemperHouse Well-Known Member
    Eric
    Nashville, TN
    2015 Tacoma TRD Pro
    Is it blowing cold? If not, and not making other horrible noises, usual low on coolant. If it's not making noises and still blowing cold, it'll probably be fine
  4. Jul 9, 2019 at 1:11 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Cold but i suspect it should be better. Just odd not having a puddle under it. My Highlander and 4R always have water dripping when AC runs. Not a drop from car though.
  5. Jul 9, 2019 at 1:23 PM
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Is there condensation on the condenser? Could just be collecting in the splash guard or something. Or maybe that particular condenser doesn't collect condensation as quickly as some others do and won't drip? Not all AC systems are the same. Either way, don't think its a sign of anything. If you are worried about freon levels, stick a gauge on it. You can loan one from autozone
  6. Jul 9, 2019 at 1:28 PM
    SemperHouse
    Eric
    Nashville, TN
    2015 Tacoma TRD Pro
    I'd recommend getting it checked, grab that gauge from autozone or take it somewhere, any shop can do that so a cheap one you trust is the call there. No water under it at all doesn't sound right.
  7. Jul 9, 2019 at 1:29 PM
    dbbowen2
    dbbowen2 Former Rock Crawler.
    TN
    2017 TRD OR Taco/2001 Land Cruiser/ 1976 FJ40
    too many to list
    Would anyone be interested in buying a full set of RCI Powdercoated Steel Skids? I just put them on a few weeks ago. Tossed my OEM TRD OR skids.
    Here is the kicker, Im in Memphis, TN. I need your old skids. Can give you a deal on the RCI skids for the hassle of needing your old skids and mounting bolts. All RCI hardware will be included.
    Was planning on lifting and wheeling my tacoma, but am going to go with a solid axle mini truck instead. Can work out a good deal for someone looking to upgrade their taco.
  8. Jul 9, 2019 at 1:38 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Make sure it's not dripping into the car.... clogged evaporator drains or a misaligned drain will cause a leak into the car..... the footwell carpet on either side will be wet.
  9. Jul 9, 2019 at 1:40 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Interior dry.
  10. Jul 9, 2019 at 1:41 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Good. That's a problem you don't want.
  11. Jul 9, 2019 at 1:50 PM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    What else ya got?
  12. Jul 9, 2019 at 2:07 PM
    dbbowen2
    TN
    too many to list
    4 TRD Pro 4runner Sema wheels unopened in the box still
    BigMacMcCoy likes this.
  13. Jul 9, 2019 at 2:59 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Another one sees the light... :D
  14. Jul 9, 2019 at 3:09 PM
    dbbowen2
    TN
    too many to list
    haha hey I had a pretty baller first gen 4runner like 3 cars ago! hahahahaha
  15. Jul 9, 2019 at 6:38 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
  16. Jul 10, 2019 at 6:06 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Mini is def cheaper and will be a better wheeler. I think most folks go Tacoma or 4runner and can't go backwards in luxury, space and just daily use in general.
    Side note, I've seen like 20 fucking people on here who live in Memphis and have met like 5. Not that I go out much but seems odd we can't at least get a group to go to an offroad meet together. After typing this though, I obviously don't care that much otherwise I would try and make that happen. Hmmmmmm, ok good talk. :hattip:
  17. Jul 10, 2019 at 6:14 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Want to cut me another deal like last time? Could probably have my friend bring them to me in two weeks when he travels over here
  18. Jul 10, 2019 at 7:29 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    your evaporator drain could be clogged, though I would suspect you would know by now because your carpets would be wet.
    If your AC is only cold when you are moving, that's probably because of the limitations of the condenser not getting enough air flow when idling in the summer heat.
    My mom would complain about this when driving my dad's 2001 Eclipse. Even though it has a electric fans, the "grill" on an 01 Eclipse is basically nonexistent. But boy does that AC get ICE COLD when you are doing at least 40 mph.
    Oops.. beat me to it.
    11TRDTX[QUOTED] likes this.
  19. Jul 10, 2019 at 7:32 AM
    dbbowen2
    TN
    too many to list
    Yeah I built a firstgen 4runner to the teeth. E lockers, duals, RCVs and all, but I daily drove it and needed a more comfortable DD. Thats why I got the tacoma. Now that I am moving into a bigger house a trail only truck just makes sense, and I can drive the taco to work. ha
    Shoot me a PM. Figure we can get a price that works for both of us, they were installed a month ago, havent even hit a gravel road in my truck since.
  20. Jul 10, 2019 at 8:35 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Even if you had, if a negotiating tactic for paying less for skid plates, sliders, bumpers, etc .... is they are scratched, you're a real fuck stick. Seeing as the whole point of them is to scratch them instead of your truck, kinda ruins any argument of "well I'll have to repaint them so I'll pay you half price." How bout noooooooooo.
    Now if they look like my ifs skid looks and every time I unbolt it I have to redrill new mounting holes and only get 3 out of 6 bolts back in, then negotiating paying the price of scrap steel makes perfect sense.
