Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Dec 26, 2012 at 3:06 PM
    #6221
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    That's awesome Gideon I just pulled a jeep out of a ditch filled with water today :) no pics though :(
  2. Dec 26, 2012 at 3:22 PM
    #6222
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Welcome man! Where do u stay at!? Im in Raleigh.
  3. Dec 26, 2012 at 3:25 PM
    #6223
    TacoSkeet
    TacoSkeet 'MERICA
    Steven
    Memphis, TN
    03 DC Tacoma
    Thanks, I live in Collierville, but I go to school at Mississippi State so most of my time is spend in Starkville, MS.
  4. Dec 26, 2012 at 3:35 PM
    #6224
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Ur dead!? NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!
    And they were Arab. U tell me!?
    No pics? I don't believe u then :D
  5. Dec 26, 2012 at 3:36 PM
    #6225
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    welcome!
    and great more people from memphis. :crazy:
  6. Dec 26, 2012 at 3:38 PM
    #6226
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Oh ok, a buddy of mine went there for a year. He partied too much so he came back! Lol so u just back for Christmas break?
  7. Dec 26, 2012 at 3:39 PM
    #6227
    TacoSkeet
    TacoSkeet 'MERICA
    Steven
    Memphis, TN
    03 DC Tacoma
    yerp, home until January 5th
  8. Dec 26, 2012 at 3:41 PM
    #6228
    TuFerLife
    TuFerLife 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    2011 Ford Raptor (I'm a traitor)
    The sloppy steering is a steering rack problem, but he said if I get a new one its just a temporary fix because of the large tires. So, not much I can do there... He is saying I need to replace the timing cover because that leaks on the alternator and can cause it to go bad... So I'm trying to find out what a mechanic will charge me...
  9. Dec 26, 2012 at 3:52 PM
    #6229
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Nice dude
  10. Dec 26, 2012 at 3:53 PM
    #6230
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    U shut ur mouth when ur talkin about us
  11. Dec 26, 2012 at 3:57 PM
    #6231
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    make me you man eater!
  12. Dec 26, 2012 at 3:57 PM
    #6232
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Well the good thing about the timing chain cover gasket is it won't cause any more problems with the motor. Might do what he said but I'm not sure on that. If water can repeatedly get on an alternator from u driving around then I don't see why a lil oil couldn't. These steering racks are known for being weak but u shouldnt be just destroying that thing from putting 35s on it
  13. Dec 26, 2012 at 3:59 PM
    #6233
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Come over and ill make u eat my meat! That should shut u up! Bring Weston while ur at it, he needs to practice more.
  14. Dec 26, 2012 at 6:25 PM
    #6234
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    cab mount chop is in but the alignment fixed my rubbing issue so im going to hold off on it till my first willing trip to see if i rub when i flex :)
  15. Dec 26, 2012 at 6:30 PM
    #6235
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Uh huh .... Don't wanna listen to me
  16. Dec 26, 2012 at 6:31 PM
    #6236
    TuFerLife
    Taylor
    Chattanooga, TN
    Gideon,
    Can you just give me a little clarification on timing chain cover gasket and valve cover gasket? I mean are those major problems? The seller is saying they are small leaks, but not enough to damage anything... He said he just changed the oil every 5k and was good to go...
  17. Dec 26, 2012 at 6:31 PM
    #6237
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    :) why dont you go post pics of some boobs :rolleyes:
  18. Dec 26, 2012 at 7:02 PM
    #6238
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    U just had to say somethin ....
  19. Dec 26, 2012 at 7:14 PM
    #6239
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    ok so the best part about damn near any gasket oil leak is . . . that is all it is . . . . an oil leak. U lose a lil oil, u put a lil oil back in. Unless u literally run the motor dry, its gonna hurt nothing to be leaking oil. I know because ive needed to replace my timing chain cover gasket for about 10,000 miles now and ive actually only added oil once and its a pretty good looking oil leak, meaning the underside of the motor is covered in oil. So cosmetically it looks like hell but mechanically it is doing absolutely no damage. Unless u are pouring oil at such an extreme rate to where u put oil in it and by the time u check it, it has already run out, then u are gonna be fine my friend. Its just a tiny rubber gasket that is worn or cracked that is causing the leak. If u dont want to tear the engine apart to replace it, u can literally put silicone over where its leaking from and that should fix it.
    Hope this makes u feel better. Trust me when i say i take care of my truck and if it was a big deal, i wouldve fixed mine by now! haha
  20. Dec 26, 2012 at 7:16 PM
    #6240
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Damn tennessee guys got me again
