Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Apr 29, 2020 at 3:14 AM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Invest in a multimeter.
    Justinogo and dirty deeds like this.
  2. Apr 29, 2020 at 3:16 AM
    tpp4
    tpp4 Well-Known Member
    Memphis
    2018 DCSB SR
    Do you have any recommendations for a budget one that's not a POS?
  3. Apr 29, 2020 at 7:21 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I did. Had to run a harness and all, as well. My 2014 didn't come pre-wired.
    I ran them anytime on, though. Did not use any original OEM fuse block or anything at first, just the supplied inline relay and fuse holder. When I added the aux fuse block/breaker, I ran them to it. I got a factory switch and factory switch connector and it works at it should (i.e. illuminates when the lights are on, off when lights are off)
    A free/cheap one from Harbor Freight will get you by. But I can't complain about my Milwaukee I've had for 10+ years.
    JKU3000 likes this.
  4. Apr 29, 2020 at 7:23 AM
    dirty deeds
    Nick
    Eastern KY
    Also, didn't get an alert for this tag.
    Shit's broke teedub
  5. Apr 29, 2020 at 8:43 AM
    tpp4
    Memphis
    2018 DCSB SR
    I will try to get around to a HF here soon. Nearest one is in collierville, and I just don't get out that way hardly ever anymore.
  6. Apr 29, 2020 at 10:00 AM
    dirty deeds
    Nick
    Eastern KY
    I wouldn't make that my only choice lol
  7. Apr 29, 2020 at 10:05 AM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    Details on my setup:
    I'm using the square natika 720p camera with the black and red power unused, and the trigger from the red D/C connector soldered to the red trigger from the yellow video wire at the camera end. White wire has been cut, and ends have been separated as to not cause a short. On the other end, I used the supplied connector to connect the red trigger from the yellow video wire to the 12+ out from the CS harness. The red wire seemed super small for the connector, so I doubled it on itself, twisted it shut, shoved it in, and then crimped the connector. After a tug, it didn't give any slack, so I assume it's a solid connection. My truck is an SR, so only the two larger connectors of the CS harness were used. I don't have a connection for the small connector.
    Does anyone have any insight wherein lies the issue? I'm assuming it's a controller problem due to no camera functionality, front or rear, but that's just my best guess.
    Any help on any of these issues would be much appreciated.[/QUOTE]
    Show me the controller you are using for the camera anytime mod. Is it this one? https://www.amazon.com/dp/B07DKH6J4W
  8. Apr 29, 2020 at 10:21 AM
    dirty deeds
    Nick
    Eastern KY
    Is your truck wired for a rear camera? Already come with one?
    Most straight forward way to see if pre-wired, there will be wire loom running from the bed into the tailgate.
    Y'all just need to get off Amazon and TW for these hack wiring jobs and use Crutchfield. Made my life so much easier when I upgraded over the plain stock HU, retained all my factory functionality.
    Newlife likes this.
  9. Apr 29, 2020 at 10:44 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Agreed when I installed my maestro unit I’d had much rather had crutchfield do the wiring vs me again. Way way worth the 10.00
    JKU3000 and dirty deeds[QUOTED] like this.
  10. Apr 29, 2020 at 11:29 AM
    dirty deeds
    Nick
    Eastern KY
    100% worth any extra expenses, and you get to talk on the phone to a real person! Ran into some issues on mine, tech wouldn't let me off the phone for 3 hours til he made it right.
    JKU3000, honda50r and Newlife[QUOTED] like this.
  11. Apr 30, 2020 at 12:21 AM
    tpp4
    Memphis
    2018 DCSB SR
    Show me the controller you are using for the camera anytime mod. Is it this one? https://www.amazon.com/dp/B07DKH6J4W[/QUOTE]
    YES, it is the RFCC TTG2 controller purchased through TACO GARAGE. I read through the CS anytime thread and found several posts by owners of SRs that have successfully completed it. I'm going to try reaching out to them about it as well.
    I already have a rear backup camera; it's factory.
    dirty deeds[QUOTED] likes this.
  12. Apr 30, 2020 at 5:53 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Ecgs recommends 80/140 right ? And is that also the same for break in or done to buy some break in oil as well ? My gears should be here next week.
  13. Apr 30, 2020 at 5:54 AM
    svermilyea
    Scott
    East Tennessee
    If all harnesses from the controller are connected to your vehicle harness, you should have a blue light on the controller, just above where the harnesses connect into it, when ACC power is applied. If there is no blue light, that means the controller is not powered. Without the controller powered, you will have no backup camera.
    If the small harness is not connected (no place to connect it to your vehicle harness), that is the power harness. Clip the wiring (red & black) where it enters the harness. Jumper that to ACC power and ground. The blue light on the controller will come on and the mod will work as designed.
  14. Apr 30, 2020 at 6:26 AM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 - BUILT FOR GO
    I think I'm gonna pass this time, thanks though.
    Any idea what the difference is between the 4Runner arms and Tacoma arms are?
  15. Apr 30, 2020 at 6:29 AM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    85W-140 Non-Synthetic Lucas is what they recommend.
    Newlife[QUOTED] likes this.
  16. Apr 30, 2020 at 6:32 AM
    dirty deeds
    Nick
    Eastern KY
    What day did you order? I'm still waiting, for anything, ordered on the 16th this month.
    I know, be patient :blahblah:
  17. Apr 30, 2020 at 6:42 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Two weeks ago so about the same time. And they haven’t said mine are going to be here next week. I’m just going off what they said when I paid for them and asked about what time I could expect the new ones.
  18. Apr 30, 2020 at 6:47 AM
    dirty deeds
    Nick
    Eastern KY
    Last week, I called to make sure they got my returned parts, guesstimated 2-3 weeks at that time. I also just ordered the Lucas 85-140 to prepare. 10qts for $85 on Amazon since NO ONE has enough in stock without paying tax at 8 individual stores to get 1 or 2 bottles.
    Individual qts comes out to be cheaper than gallons, FYI.
    Edit: I'm also going to put new in the front diff, that's why so many.
  19. Apr 30, 2020 at 7:09 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Yeah I saw that deal on Amazon and was wondering if that’s what most were doing since I’m doing front and rear. But didn’t know if they want 85/140 for the initial break in or actual break in oil
  20. Apr 30, 2020 at 7:13 AM
    tacomaccountant
    tacomaccountant Well-Known Member
    Florida
    2019 Metallic Grey SR5 4WD
    Does anyone know of a good shop to do a regear and install airlockers in TN? I haven't been able to find anything.
