Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Apr 30, 2020 at 7:17 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Where in TN?
    I think these guys all do their own.
    But they may know shops.
    East Coast Gear Supply will ship you preassembled parts and you ship your old one back to them for core.
    JKU3000 likes this.
  2. Apr 30, 2020 at 7:21 AM
    tacomaccountant
    tacomaccountant Well-Known Member
    Florida
    2019 Metallic Grey SR5 4WD
    I am in Memphis and am not mechanically inclined enough to touch the gears on my 3rd gen lol. Maybe someday. My wife and I have a tentative road trip planned to Colorado in the spring for fun. I am actually considering getting on the schedule of one of the gear and axle shops out there that does this a lot. We can just get a rental for a day or two and go skiing while its being worked on. That's the plan if I can't find anything nearby.
  3. Apr 30, 2020 at 7:24 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Take nuts/bolts out. Remove stock stuff. Replace with beef. Put nuts/bolts back in.
    Don't forget to drain and fill fluids :)
    JKU3000 likes this.
  4. Apr 30, 2020 at 7:25 AM
    dirty deeds
    Nick
    Eastern KY
  5. Apr 30, 2020 at 7:56 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Swapping the 3rd is way easier than setting up the gears. If you’ve ever changed a cv axle then you’ve done 90% of the work to swap the front diff from ECGS. Rear is as simple as 4 bolts on either hub, sliding the axles shafts out and then swapping the 3rd.
    It’s beyond easy.
  6. Apr 30, 2020 at 7:59 AM
    Kerleyfries
    Zack
    Lebanon
    I ordered mine on the 24th. Called Tuesday just to check timeline and he said they’d ship the week of the 18th.
  7. Apr 30, 2020 at 8:26 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Sounds like a gear swap day in middle TN byob. It would just suck for the break in lol
  8. Apr 30, 2020 at 8:30 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Beyond easy is rotating tires. Swapping diffs is slightly easier than pulling a trans or motor and theres nothing "harder" than that on our trucks. Your overconfidence scares me .....
    Robertocritser and dirty deeds like this.
  9. Apr 30, 2020 at 8:34 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    dirty deeds[QUOTED] likes this.
  10. Apr 30, 2020 at 8:39 AM
    dirty deeds
    Nick
    Eastern KY
    Eh, I figure play it more to the book this time since I'm getting brand new everything now. Your old set did me fine, it was my driving that broke the 3rd lol!
    So no more wally's cheap Supertech going in. They also suggested to use additive iirc, in an email or phone conversation at some point in the past, purely for the sake of the Lock Right.
  11. Apr 30, 2020 at 9:08 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    You must really like pulling transmissions and engines! I'd rather pull a third 10 times over before puling a motor or dropping a trans once.
  12. Apr 30, 2020 at 9:43 AM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Dropping and putting back the transfer case 5 times in a day was enough for me.
  13. Apr 30, 2020 at 11:01 AM
    tpp4
    tpp4 Well-Known Member
    Memphis
    2018 DCSB SR
    I don't see a blue power light anywhere on here if it's exposed on the exterior of the case. Wtf
    Unless they moved it to the other side?
  14. Apr 30, 2020 at 11:31 AM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    turn the box over in your first pic. When powered, you will see it above the connector.
  15. Apr 30, 2020 at 12:01 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I agree. I said pulling a diff is slightly easier. The rear doesn't count. I'm referring to the front. We're also specifically talking about a 2nd/3rd gen Tacoma. I've never put a stop watch on it before but from start to finish (truck sitting on the ground and driveable), I bet I can swap out my trans as fast, if not faster than my front diff. I don't have to put the truck on jackstands and remove the wheels then reverse that process and I don't have to drain the oil then fill it back up. Just those 2 things alone, time wise, make that front diff take longer. I could be wrong but I've pulled my trans maybe 6 times (3 new clutches and 3 new TOB) and it seems easier every time than the 2 times the front diff has come out. Haha
    JKU3000 likes this.
  16. Apr 30, 2020 at 12:11 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Ha, I forgot that IFS clamshell's suck so much to pull...too used to just yanking regular thirds out of axles.
  17. Apr 30, 2020 at 12:13 PM
    dirty deeds
    Nick
    Eastern KY
    I have to agree here. It was my eff up that I messed up my clutch to trans alignment on the first try. That front diff can eat a bag o dicks.
  18. Apr 30, 2020 at 12:56 PM
    Kerleyfries
    Zack
    Lebanon
    4Runner has a thicker shaft on the bj. You can run 4runner arms on a taco if you reem out the spindle, but not vice versa.
  19. Apr 30, 2020 at 12:59 PM
    Kerleyfries
    Zack
    Lebanon
    That’s fair. Lol. Maybe not easy, but in my mind it seems super straight forward and simplistic.
    that said, It’s a day easy and you don’t want to do it alone.
  20. Apr 30, 2020 at 3:16 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Haha yeah I figured that's what you were thinking about.
