Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jun 26, 2020 at 11:47 AM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    I haven't used the Red Arc setup, do you have a link to it? I think whichever switching solenoid type system you will be in conjunction with a solar controller. I don't think there is a way around that.
  2. Jun 26, 2020 at 12:40 PM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    I might be able to help here, as I have a few solar panels, have built some modular battery systems, have experience with RedArc and CTEK, Lithium and AGM.
    The Redarc, which I'm assuming you are referring to the BCDC25A or BDDC40A has a built in solar MPPT controller. Also, you need to wire it appropriately for Lithium or Lead profiles to ensure you don't apply float volts or the wrong voltage to charge certain battery types. Its pretty easy. A good place to start is YouTube, look up DIY solar with Will Prowse, you'll get lots of info there, and at his forms.
    Redarc makes good stuff, consider the 40A model will need some pretty large battery cables, especially if you run them to the rear of the vehicle like I did with my modular stuff.
    I also own a Jackery E1000, Dokio 200W folding panel, and installed a 100W ridgid panel on the roof of the 4Runner.
    Important note. Don't run the Solar Panel hardwired into the RedArc without having a constant battery attached. Solar controllers can be damaged by not having a battery load connected, as the high open circuit voltage from the panel might overvolt the controller with no load.
    Aardvark13 likes this.
  3. Jun 26, 2020 at 12:53 PM
    FirstGenTundra
    FirstGenTundra Well-Known Member
    Knoxville, TN
    2002 Tundra
    ICON suspension, SCS Ray 10's, Brute Force Fab bumper,
    Thanks for whoever recommended ABJ coating. They did a great job. If someone wants to help me mount this I'll bring over whatever beer you like. It's too heavy to do alone. My wife about died helping me get it out of the bed.
    honda50r and KnoxTac0713 like this.
  4. Jun 26, 2020 at 12:58 PM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    So whats the advantage over something like a smart solenoid, if you already have a solar controller?
  5. Jun 26, 2020 at 1:09 PM
    KnoxTac0713
    KnoxTac0713 Well-Known Member
    Justin
    Knoxville, TN
    13 DCSB SR5 4x4 Barcelona Red
    Bilstein 6112, rear 2.0 Icon VS shocks, TRD Black SEMA wheels, 255/80/17 Cooper ST Maxx, SOS Rear bumper, SOS bolt on sliders,TRD skid plate, derped badges, 15% tint, color matched oem grille, lamin-x amber fog covers, TRD cat-back exhaust, Tacoma bed mat, Tonno-pro trifold, Depo black tail lights, front tow hook w/ D shackle, Wheeler's Superbumps rear, Wheeler's 1 inch block rear, Custom Car Grills mesh grill insert, light bar in lower valence
    they did a really good job on my rear bumper too. I don’t mind to lend a little muscle to help out. I am not sure you want me doing much more to your truck Than that though. Any hazy IPA will do, ha.
  6. Jun 26, 2020 at 1:13 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Where in Knox are you? It’s honestly not bad of an install. I did my two front bumpers alone.
  7. Jun 26, 2020 at 1:17 PM
    FirstGenTundra
    Knoxville, TN
    2002 Tundra
    I may try it with my floor jack first. In watching videos online it looks super easy with two guys. I live near downtown but I don't mind driving to someone's house.
    These guys were able to set it in place fairly easy.
  8. Jun 26, 2020 at 1:21 PM
    KnoxTac0713
    Justin
    Knoxville, TN
    but, beer
  9. Jun 26, 2020 at 2:56 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    I’m sure beer is still in play for words of encouragement
  10. Jun 26, 2020 at 5:26 PM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    There's a few different things, all different but produce a similar result, supply charge to a second battery.
    The main benefit over this device if you already have a solar charge controller is that it's all in one and works seamless with your alternator/panels to deliver power in a combined package.
    VSR (voltage sensitive relay) / Smart solenoid:
    Least expensive, rudimentary at best. It supplies the same 13.6 volts the alternator is generating to the secondary battery. The problem is, 13.6v will never complete an absorption charge on a lead acid battery, leaving it at 80%. Other issue, Lead/AGM/Gel batteries should only be discharged to 50% of their rated AH capacity to avoid deep discharing and damaging them, resulting in 30% of it's total AH as usable capacity (80% to 50% before damage occurs).
    DC to DC Charger:
    Something like a DC - DC charger (Redarc, CTEK, Renogy) do a few things:
    1. They typically have a MPPT solar controller so you can hook up a solar panel.
    2. They, like a VSR, allow voltage to flow only from the secondary battery as not to drain your cranking battery.
    3. They can handle 3 to 4 stages of smart charging (bulk, absorption, float, desulfate)
    4. They have voltage boost to get your charge volts to 14.4v, therefore getting your second battery to 100% (and you can use 50% of total capacity...100% to 50% safely).
    5. They can also use the solar panel to charge the cranking battery if the secondary battery is full.
    So in a nutshell, a VSR or solenoid is a very basic device to get some juice in a secondary battery. A DC DC charger is a full on battery charger with a solar controller so you can run both (even at the same time), and seamlessly leave them both hooked up so you can draw from either or a combo to keep your secondary battery going, and keeping that fridge powered longer.
    lowinhz likes this.
  11. Jun 26, 2020 at 6:20 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    September and October and November....
  12. Jun 26, 2020 at 7:28 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Yes!
    slander and Aardvark13 like this.
  13. Jun 26, 2020 at 9:47 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Windrock, I still haven't been...
    14Tacos4me, slander and Aardvark13 like this.
  14. Jun 27, 2020 at 4:02 AM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    I'm ok with that. Also aop in the fall?
    14Tacos4me and slander like this.
  15. Jun 27, 2020 at 5:12 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Yes and yes
  16. Jun 27, 2020 at 5:13 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    @tacotim448 has to get some redemption on school bus. ;)
    Robertocritser and slander like this.
  17. Jun 27, 2020 at 6:16 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    If y’all do windrock I may come due to blue trails with you :rofl:
  18. Jun 27, 2020 at 6:36 AM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    I see. Very cool.
  19. Jun 27, 2020 at 9:22 AM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    im in now that i got the clunk out of my front end. Time to make a new one right?
  20. Jun 27, 2020 at 11:36 AM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    I hate that trail but ill give it the college try. Also hit walden's ridge as well. That is a good solid day trail.
    rngr[QUOTED] and slander like this.
