Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. May 7, 2021 at 2:36 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Who knows salamanders?
    Didn't have phone to get a pic but found a salamander in the yard yesterday when i was ripping out some thick layers of ivy vines and leaf debris.
    Dark smoky gray color.
    Had very small/fine light color specks, whitish or silver maybe. No big spots.
    About 4 inches long nose to tail as best I could tell.
    More of a slender build, not fat.
    Can't figure it out from pics on TWRA site. Way over here is out of the known habitats for some of the ones I thought looked like it.
  2. May 7, 2021 at 4:06 PM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    This one? [​IMG]
  3. May 7, 2021 at 9:25 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Sounds more like a skink than a salamander. How about this guy?
    https://www.tn.gov/twra/wildlife/reptiles/lizards/little-brown-skink.html
    Ask @rngr he's the wildlife identifier fella.
  4. May 10, 2021 at 7:48 PM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    Howdy folks, been a while!
    Dave41079 and Justinogo like this.
  5. May 12, 2021 at 8:38 AM
    FirstGenTundra
    FirstGenTundra Well-Known Member
    Knoxville, TN
    2002 Tundra
    ICON suspension, SCS Ray 10's, Brute Force Fab bumper,
    Anyone around Knoxville have access to Toyota Tech Stream? I have tried everything to get a firm brake pedal since replacing my calipers and I can't seem to make it happen. Apparently you can use Tech Stream to tell the ABS to purge the system. I'm running out of idea and this mushy pedal has sucked the joy out of driving my truck.
  6. May 12, 2021 at 2:14 PM
    svermilyea
    Scott
    East Tennessee
    ECU TSB Update | Tacoma World If you have the computer, the link provided will get you 14.20 up and running which should work for you.
    I have it loaded, but I have not played with it on my current laptop.
  7. May 12, 2021 at 6:29 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Isn't there some trick about using a steep incline to burp the bubbles to the top or something? Maybe that's for the a-trac module or something. Don't remember for sure. Someone in here did something odd bleeding a 2nd gen taco.
  8. May 13, 2021 at 1:47 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    I let my master cylinder run almost dry (it was below the reservoir) when I had a failed rear brake line. Bled and bled with clear liquid through an 8ft hose to be sure. Ended up on TW/google and found that air was behind the plunger/piston of the master cylinder and should be towed to a dealer. Eff that. Look up "bench bleed" of the master cylinder. In my research I saw no need to remove it from the truck as the only part of "bench bleed" was the nose-high angle of the master cylinder while you performed the bleed. On your bench. Bench not needed, DYF FTMFW :cheers:
  9. May 13, 2021 at 9:17 AM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    A rare sighting of this truck in operating condition :D
  10. May 14, 2021 at 6:30 AM
    FirstGenTundra
    Knoxville, TN
    2002 Tundra
    I've heard of this trick, but it was for burping the cooling system after you do a coolant flush. Never heard of anyone doing it for brake lines. I found an answer to my own question though. TechStream doesn't work on my truck.
  11. May 14, 2021 at 6:48 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Yeah, burping wasn't the right word. It was beertime that I was thinking of, he posted above.
  12. May 14, 2021 at 7:19 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    good times
    i miss that mf :pout:
  13. May 14, 2021 at 9:38 AM
    beertimecontinuum
    Everett
    Soon.
  14. May 17, 2021 at 5:23 AM
    Fastbilly5
    Fastbilly5 Well-Known Member
  15. May 17, 2021 at 9:41 AM
    john8899
    john8899 Well-Known Member
    Chattanooga
    2019 T4R TRDOR
    Anyone have a recommendation on who I should go to near Chattanooga for a body mount chop on my 4runner?
  16. May 20, 2021 at 9:19 PM
    Brandon_Vines
    Brandon_Vines Member
    Brandon
    2010 Magnetic Grey TRD Off Road
    CBI Bed Bard Prinsu Universal Rack Wheels and BFG KO2
    How much would you guys list this 2010 TRD Off Road for? I have ideas but just want some other opinions!
    -CBI Bed Bars
    -Prinsu Roof Rack with mounted case
    -Cali Raised LED pod lights
    -factory bed mat
    -apple carplay
    -upgraded speakers
    -170,000 miles
  17. May 21, 2021 at 4:05 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    If it has no exterior damage or significant interior wear, ~$17K.
    I'd remove all that stuff in the back, and sell in the TN or SE BST thread. I doubt it's going to add much in the way of value in resale with the truck.
  18. May 21, 2021 at 6:59 PM
    Brandon_Vines
    Brandon
  19. May 27, 2021 at 2:32 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Fwiw I sold mine for 19,500 2010 pre runner converted to 4wd on 35’s with 4:88’s with 205k+ . I left cap, suspension , tires, racks, lights, bumpers and winch on when I sold it. Everything else got pulled. Radio, comms (left the ham and gmrs antennas so it didn’t leave holes), ram mounts, rtt, cargo glide, fridge, dual battery )
    that was last year in September.
  20. May 27, 2021 at 6:36 PM
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    Your truck was a beast!
    Newlife[QUOTED] likes this.
