Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Mar 16, 2023 at 8:57 PM
    All Visible Hues 14
    All Visible Hues 14 Well-Known Member
    Lynn
    East Tennessee
    2014 dcsb TRD off road
    I don’t live in that area but I’ve worked up there off and on for the last fifteen years or so. Lots of nice people there. Kind of a laid back place.
  2. Mar 22, 2023 at 9:00 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
  3. Mar 31, 2023 at 4:24 AM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Sorry Josh just noticed this. Hope aop is fun. It was wild a few weeks back.
    @Mr.Bl0nde can help with bars
    BYJOSHCOOK[QUOTED] likes this.
  4. Apr 7, 2023 at 3:24 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Here’s my yearly post hoping someone will get these. Haha. I can’t bring myself to throw them away.
    1st Gen. OE cv rebuilt with OE boots
    1st gen half doors.
  5. Apr 7, 2023 at 3:42 PM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    Hey Lynn, you still have these?
  6. Apr 7, 2023 at 6:50 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Who are you? Are you one of those recent imports from Oregon?
  7. Apr 7, 2023 at 6:51 PM
    All Visible Hues 14
    Lynn
    East Tennessee
    No, sorry they are gone already.
  8. Apr 7, 2023 at 10:17 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    If the half doors need a good home…I know a place
  9. Apr 8, 2023 at 5:09 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    We need some beers and a campfire...
    Taco22trdor and 5 Lug Fury like this.
  10. Apr 8, 2023 at 6:36 PM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    @ThunderOne @Knoxdavid34
  11. Apr 19, 2023 at 4:11 PM
    CoalTrainTaco
    CoalTrainTaco Welker
    Aiden
    Nashville, TN
    2017 Super White SR5
    Fox 2.0 Coilovers MaxTrac Spindles TC Lighting Headlights Red Rock Roof Rack
    New to TN, y’all have a Nashville and/or TN classifieds forum?
    KRAMERICA likes this.
  12. Apr 19, 2023 at 4:20 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    CoalTrainTaco[QUOTED] likes this.
  13. Apr 19, 2023 at 4:36 PM
    CoalTrainTaco
    Aiden
    Nashville, TN
  14. May 6, 2023 at 5:28 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Anyone interested in a deal on set of Yokohama Geolandar MT G003?
    295/70-18.
    About 7,000 miles on them. They run bit over 34" tall. I'm going to have to drive more for work than I was a year ago when I got them so I want to swap to some A/Ts.
    Related, I also have a set of OEM Tundra 18" wheels with sensors and tires mounted. These tires are 285/70-18 Firestone A/T with some life left but not a lot. Measured about 7 or 8 32nd of tread.
  15. May 6, 2023 at 5:43 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    Any of you guys have ideas on why the AC works sometimes and not others? I can press the button and sometimes it lights up and other times it doesn’t. When it doesn’t I can hit the control panel a time or two and it will work. Also fan speed doesn’t seam to work like it should.
    Considering I can hit the panel and get it to work better, I think that’s the problem. Also anyone know where I can get one? Would like to avoid the dealer if I can.
  16. May 6, 2023 at 6:18 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    If it's like my 05 taco did, pull the panel that has the 3 knobs and carefully pull apart the fan speed dial. Mine had debris that was causing poor contact on the copper rail as the knob was turned. Clean well with rubbing alcohol on a q-tip then smear a layer of electrical grease on the copper rail. Careful not to lose the plastic ball and spring from the knob. This is what makes it feel like it clicks into place at each setting. Also be very careful not to pry tabs too far that they break during disassembly. If tabs break, you lose pressure on the copper contacts.
    Basic issue is bad contact of fan knob makes system not know if fan is on or off. You can try jiggling fan knob next time to see if it makes a difference before you do the work I described above.
  17. May 6, 2023 at 7:08 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    Ok I’ll try thank, Thanks! It’s an ‘07 so likely could be same problem.
    Edit: considering smacking or hitting the controls usually fixes the problem for a bit. I don’t think it’s another part of the system. But I guess it could be?:notsure:
  18. May 8, 2023 at 5:02 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    @totmacher you may be on to something man! Noticed this as soon as I pulled it out and the parts of the tabs fell in my hand before I even unplugged it. Going to take it about to clean it and see if it helps any. I circled where they broke off from.
  19. May 8, 2023 at 6:08 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    Well it doesn’t work at all now…
    anyone have an idea where I can get one? Didn’t see one on rock auto.
  20. May 8, 2023 at 11:07 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    If you hold the pieces together where the tabs broke so internal parts have pressure, does it work then?
    Junkyard, pullapart, lkq, etc may have one.
