Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jul 24, 2013 at 7:41 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    adam you get my text? or you to busy texting Taylor?
  2. Jul 24, 2013 at 7:54 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    I didn't get a text from you
  3. Jul 24, 2013 at 7:58 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    ok.
    I was seeing when a good time for you to meet and get the mud flaps is.
    you may get it later to night. seams like i text some people and some times they get it a few hours later...
  4. Jul 24, 2013 at 8:08 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    oh ok. Well I can probably meet up Friday after work?
  5. Jul 24, 2013 at 8:38 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    sounds good to me. about what time? want to meet at emery or some around their?
  6. Jul 24, 2013 at 8:56 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    I get off around 6 so anytime around there.
  7. Jul 24, 2013 at 10:42 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    ok cool, just text me.
  8. Jul 25, 2013 at 3:46 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    Well could not sleep, and was not even tired at 2am, so i took the rhino a part and cleaned the mud/dirt out of the oil cooler and radiator. got done at 6am.
    won’t sleep today, got to mow some, also going out to cotton eyed joe tonight for a concert with my brother and some of his friends.
  9. Jul 25, 2013 at 3:55 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Drink a few beers. You will pass out eventually
  10. Jul 25, 2013 at 4:00 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    i had a few when i was working on the rhino. :D and can’t go to sleep got shit that need to be done. few trees need to be trimmed, back field needs to be mowed. need to do a test run on the rhino and check the bolts agin. had the hood off, the air box out, oil cooler off, took the shocks off to help get oil cooler and radiator lose, and radiator fan lose. stared at 2am and parked the rhino and shut garage at 6am. little rest get some food and get started on stuff for the day.
    going to royal blue this weekend with neighbor and maybe get some other people. taking the rhino, maybe the dirt bike idk yet.
  11. Jul 25, 2013 at 6:06 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Well don't invite me cause I WONT be there. Haha
  12. Jul 25, 2013 at 6:18 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    X2
  13. Jul 25, 2013 at 7:44 PM
    SilMonDrop
    SilMonDrop Well-Known Member
    Doug
    Clarksville TN
    13 Tundra SR5 Crew Max
    LED Dome Lights
    Been driving on the lift this week. Only thing I have noticed is a slight vibration between 5-10mph. Is this ok? Other than that it is really stiff. Rides good but stiff. Did get out to LBL on Tuesday and drove some of the unimproved roads. Felt pretty good on the light stuff I encountered.
  14. Jul 25, 2013 at 7:49 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Your vibration is coming from ds angle being off. A 1/4" -1/2" shim on the carrier housing should fix that.
    I'll see if I can find the thread for you.
  15. Jul 25, 2013 at 8:04 PM
    thegreatwall23
    thegreatwall23 Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    Yep, exactly what he said. Toytec has a little spacer for sale or you can just make one for yourself. If you get an angle finder and get the drive shaft as close to the same thing and you should be able to fix it. Mine was a little worse and it didn't fix it, but mine was coming from the rear different, so I had to use a 3 degree axle shim to correct mine. There a very good thread on how to check everything and line it up correctly, but I am on my phone and out of town. If you don't see it by Monday, remind me and I will get it to you.
  16. Jul 25, 2013 at 8:05 PM
    TuFerLife
    TuFerLife 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    2011 Ford Raptor (I'm a traitor)
    Gawd I just got back from warped tour down in Atlanta... Today was a good day!
  17. Jul 26, 2013 at 3:42 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    What lift did you put on? And like Danny said, make a cb drop. I took a 1/4" thick flat bracket with 3/8"s holes and cut it in half and used them as spacers. Washers would also work. Should be able to spend $3-$4 at home depot and get whatever you need
  18. Jul 26, 2013 at 3:42 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Who was in it?
  19. Jul 26, 2013 at 4:27 AM
    SilMonDrop
    Doug
    Clarksville TN
    LED Dome Lights
    I put the OME 3" on it. AAL in the rear. It came with the dif drop but I have read and been told it is not a good thing to put on.
  20. Jul 26, 2013 at 6:23 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    People have had some bad things happen but at the same time, a lot of people run them with no problems. I discovered about 6 months ago that I've been running them since I've had my truck. Lol I put a spacer lift on 5 years ago when I first got it and about 2 1/2 years ago when I went to a mid travel setup, I just never paid attention and left the spacers there. Well when I changed my front diff out, I noticed them. Moral of the story, I've run a diff drop for 94k miles and a spacer lift for half those miles and although I've gotten smarter about wheeling, I used to beat the shit outta my truck and I've never had a problem with either. Of coarse I agree that it may not be worth the risk but I'm living proof that you can run both of those and NOT fuck anything up. (Knock on wood real quick) :D
    So what # spring are you running with the kit? New shocks all the way around? Are the back shocks longer then stock? AAL will always ride stiffer then the right spring pack but you can help that ride by having the right shock, tune, and weight
