[Official] Valley Tuning Thread
Discussion in 'Performance and Tuning' started by TermLimits, Mar 22, 2021.
  1. Jul 15, 2021 at 5:54 AM
    #521
    TermLimits
    TermLimits [OP] Owner of Valley Tuning
    Jeff
    Cleveland, Ohio
    2016 QuickSand Tacoma TRD OR
    ValleyTune.com Current Tunes: Valley Runner
    Once complete I will be updating through the website.
    Essentially when I change/upload new files to the product, the download permissions for all users will be refreshed. This in turn will provide access to C21 for all those currently running C20.
    katoomer360[QUOTED] likes this.
  2. Jul 15, 2021 at 5:55 AM
    #522
    TermLimits
    Jeff
    Cleveland, Ohio
    Could you send me your ECU ID off the 4R and the year? I’m trying to pinpoint what ones are for each year truck.
    Thanks!
    C41n likes this.
  3. Jul 15, 2021 at 6:22 AM
    #523
    Moots34
    Moots34 Well-Known Member
    Tyetus
    2016 Silver Tacoma TRD OR DCSB MT
    PM sent
  4. Jul 15, 2021 at 2:55 PM
    #524
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    So it is possible to go up from 04c20 to 0c421 on a 2021 ? mine was built in 4/21 and didn't know/bother to check what I had before I fed the tune to it (had no idea wtf I was doing when I did it - 1st timer :confused:), but the gear hunting and throttle response Defiantly improved with the Valley Runner 2.0.3 tune!
  5. Jul 15, 2021 at 3:07 PM
    #525
    TermLimits
    Jeff
    Cleveland, Ohio
    If you already bought the tune and flashed it, odds are you have 04C20.
    You can update to C21 whenever you feel like it through a Techstream TSB update. There should be a thread on the forums describing the process. A 2021 truck will need the most updated techstream software direct from Toyota. A two day pass to use it is around $60 I believe.
    I will advise against updating until I have finalized the C21 files and update all the purchased customers download links. This way you are able to reflash VR to your truck once you complete the C21 transition.
    I’ll post here once we complete the C21 updates on ValleyTune.com
  6. Jul 15, 2021 at 3:09 PM
    #526
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    Ok great, thanks for the info. I'll defiantly wait to update then
  7. Jul 16, 2021 at 4:40 AM
    #527
    katoomer360
    katoomer360 Member
    Joe
    North Eastern PA
    2021 Barcelona Red TRD OR DCSB
    I believe you can update with the new version of VF Tuner? I haven’t tried it yet, but will when your update file is available.
  8. Jul 16, 2021 at 5:09 AM
    #528
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    Just to clarify - As far as I know, you can update TSBs with the old Techstream. You only need the latest version to actually tweak settings within Techstream (i.e. door chimes, seatbelt lights, etc).
    But as @katoomer360 mentioned, you should be able to update the ECU through vFtuner and skip the Techstream software altogether.
  9. Jul 16, 2021 at 7:49 AM
    #529
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    You need at least version V15.30.026 to update 2021 Tacomas via techstream. V14.20.019 works for 2020s.
    More info here:
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
    TermLimits[OP] likes this.
  10. Jul 16, 2021 at 7:54 AM
    #530
    TermLimits
    Jeff
    Cleveland, Ohio
    I would still try through VF before dropping money on a two day pass for TS. HOWEVER, I have yet to get an ECU in that needs to be updated, so I haven't tested the VF software CUW files.
    I'm waiting on a substantial order of ECUs to arrive, one of those is bound to need an update.
  11. Jul 16, 2021 at 8:29 AM
    #531
    C41n
    Anthony
    Portland, OR
    2020 DCSB OR MT
    I have not tried VF, and if that works it would be great. You can get TS 15, or 16 registered though mhhauto forum. It's a bit of a process and will cost $25 to register for the forum. Once there, you can ask for the codes. There are other ways floating about, but I know that way works, as that is what I did.
  12. Jul 16, 2021 at 8:38 AM
    #532
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Subbed.
  13. Jul 16, 2021 at 8:47 AM
    #533
    TermLimits
    Jeff
    Cleveland, Ohio
    I would sub back but this isn't youtube :D
    Glad to have you aboard the information train
  14. Jul 16, 2021 at 8:58 AM
    #534
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    So... in the store, there is choices for 31-35 inch tires. For a stock truck, I'd be looking at the 31 inch tune right?
  15. Jul 16, 2021 at 10:25 AM
    #535
    TermLimits
    Jeff
    Cleveland, Ohio
    Punch your tire size from the side wall into google with “in inches”. TRD ORs have come with 31-32” tires depending on the dealer. Mine had 31.5 when purchased.
  16. Jul 16, 2021 at 3:04 PM
    #536
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    I don't have enough time on this tune to give a review of it. But customer service is top notch, questions, help & advice answered & given quickly. Thanks
    C41n and TermLimits[OP] like this.
  17. Jul 16, 2021 at 3:27 PM
    #537
    TermLimits
    Jeff
    Cleveland, Ohio
    I may have a few extras left over
  18. Jul 16, 2021 at 4:30 PM
    #538
    t.a.c.o
    t.a.c.o New Member
    2020 Cement Tacoma DCLB TRD Sport Premium
    Detailed Solutions: Full Nano Coating, Xpel Ultimate on high impact areas, Tint. Black Badge Overlay. Black Tailgate Inlay
    Will these be on the site shop soon? or how can I get a couple!?
    Been running the VR standard tune for a bit over a week and have enjoyed my truck more than ever. Still have yet to do some longer Highway trips, but I’m excited to load up with gear and feel the difference.
    Thanks Jeff.
  19. Jul 16, 2021 at 4:47 PM
    #539
    TermLimits
    Jeff
    Cleveland, Ohio
    They’ll be posted on the website in the next day or so. The stickers are roughly 3.5” x 4”
    Perfect for fitting in with any other stickers you may have along with being placed on water bottles/laptops. You can also cut off the words if you want logo only.
    They’re automotive stickers designed to not damage paint or leave spots on windows should you ever remove it
  20. Jul 16, 2021 at 4:54 PM
    #540
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    do we need to update to newest vf tuner ? Do you recommend? @TermLimits
