OFFICIAL XB LED HEADLIGHTS THREAD 16+
Discussion in 'Lighting' started by eledobleu, Feb 20, 2019.
  1. May 28, 2020 at 7:04 PM
    #2481
    Cement baw
    Cement baw Well-Known Member
    2020 Cement SR5 Double Cab
    So am I going to mess my headlights up running the amber in DRL?
  2. May 28, 2020 at 8:39 PM
    #2482
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    If you have Tacoma SR5, you can as long as you have fuse tap wires that came with the package.
  3. May 28, 2020 at 8:51 PM
    #2483
    Thorian
    Thorian Well-Known Member
    Marco
    Los Angeles, CA
    2017 4x4 White Tacoma
    Kings 2.5 Front and Rear, Baja Kit UCAs, Dakar Medium Leaf Pack, SSO Slimline Bumper
    Well idk what the reasoning is but they say running Amber is bad. So basically I can’t turn my stalk to the drl or parking light position. Without risking “damaging” the lights.
    I’ll turn them once in a while for pics. But don’t run them in that position because I don’t want to “damage” them. I’m still not sure what the risk damage is and it is unfortunate I cannot use the other positions on my stalk because that means I cannot run my fogs without also running the headlights
  4. May 28, 2020 at 9:00 PM
    #2484
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    I believe I read somewhere that the amber LEDs were intended for turn signals and have resistors to prevent hyper flashing and running them steady for extended periods could over heat the resistors.
  5. May 29, 2020 at 6:04 AM
    #2485
    Cement baw
    Well that sucks
  6. May 29, 2020 at 7:42 PM
    #2486
    AllGen
    AllGen Active Member
    Shawn
    Texas
    2016 Blue Tacoma Limited 4x4
    Hidden front bumper 32" LED light bar HID headlights Morimoto XB fog lights Pop and Lock for tailgate Metal oil filter housing Bed extender OE bed mat OE bed front rail for sliding hold downs Toyota first aid kit Bed cubby hole block offs Door seal protectors with aluminum inserts OE LED bed light pods and Matt Gecko LED strips OE TRD Pro grill Ceramic tint MESO gasshole and coin holder 1/2" Toytec front shock/strut spacer (leveling kit) 1/2" Toytec rear leaf spring shims with 7.5" u-bolts (leveling kit-IMO) Anytime front and rear camera Shapeway's drivers side cubby switch insert (anytime camera switch location)
    No, I have not.
  7. Jun 1, 2020 at 8:38 AM
    #2487
    Cement baw
    Has this been confirmed with Morimoto?
  8. Jun 1, 2020 at 8:50 AM
    #2488
    Tacospike
    Two Trucks
    Looks like it worked one page back
  9. Jun 1, 2020 at 9:33 AM
    #2489
    Cement baw
    Mine work and I ran them like that until I read those posts. Now I am hesitant to run them in amber unless I get confirmation from Morimoto that it won't burn them up.
  10. Jun 1, 2020 at 9:34 AM
    #2490
    Tacospike
    Two Trucks
    Gotcha, I would feel the same way.
  11. Jun 1, 2020 at 10:30 AM
    #2491
    TAZMINATOR
    2017 Tacoma
    I haven't tried the fuse tap on mine since my truck isn't SR5.
    I posted about the amber feature about awhile back... that Matt discussed it with Andrew.
    See the screenshot in the post in the link I provide you:
    https://www.tacomaworld.com/threads...ights-thread-16.594520/page-124#post-23448193
    If TRS think it's issue, then why the amber DRL is on there that is on. Not making sense.
    I am with Matt on this one. So if you have SR5, feel free to use it.
    I haven't call or email to Morimoto yet for confirmation. You can ask.
    Tacospike likes this.
  12. Jun 1, 2020 at 10:41 AM
    #2492
    Cement baw
    Thanks. I emailed them. Will post the reply back for anyone interested.
    TAZMINATOR[QUOTED] likes this.
  13. Jun 1, 2020 at 11:10 PM
    #2493
    trucknoobFL
    trucknoobFL Member
    Just Got these installed on my sr5 and they look amazing.
    I can also confirm that on the sr5 your white DRLs will always be on when you have the lights set to off (fine by me). They show as Amber in the 1st and 2nd light mode and switch back to white DRLs when you have all the lights on.
    One small issue: my DRLs randomly turned on in the middle of the night. It's my 1st night with them. Has this happened to anyone? It lit up the while street. I confirmed that pulling door handles etc does not turn on the lights so nobody was breaking in.
  14. Jun 1, 2020 at 11:49 PM
    #2494
    Thorian
    Marco
    Los Angeles, CA
    Yeah happens all the time it’s a thing lol
  15. Jun 2, 2020 at 3:14 AM
    #2495
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Sorry for the confusion with the amber DRLs folks! Spoke to Matt a bit more in depth this morning, as well as consulted the factory for confirmation so we're all on the same page:
    Put simply: There is nothing wrong with it in regards to the LED's and their own reliability...the only downside is that power is constantly passing through the resistors for the turn signal circuit, so it will get hot....likely fail prematurely. This ultimately may cause damage to the back of the headlight since its mounted to the plastic... whereas in a normal turn signal scenario it barely heats up. So if you remove the resistor and/or don't care if you have to replace it sometime...not really a huge deal.
    Hope this helps clarify for all (myself included!)
    For whatever reason, some trucks turn on their ECUs randomly even with no key in the ignition (status checks?). When this happens, since we use the same fuse, boom the DRLs come on. If you use a voltmeter/multimeter, you may be able to find another fuse to tap into for the ignition-on circuit instead, or ultimately run it to a manual switch inside so there's 0% chance of it recurring.
  16. Jun 2, 2020 at 6:17 AM
    #2496
    Cement baw
    Thanks for this. So the resistors are necessary for turn signal hyper flash, correct? Also, can they be easily removed or would I have to dismantle and reseal the light? Just want to see if it is worth it since I really like the amber look.
  17. Jun 2, 2020 at 9:51 AM
    #2497
    TRSAndrew
    ATL
    They are necessary for the turn signal, that's correct. They should be just a couple screws on the back of the housing holding them on--nothing requiring opening the housings.
  18. Jun 2, 2020 at 10:29 AM
    #2498
    Cement baw
    Cool. Just 2 more dumb questions: By removing the resistors you mean mounting them to something other than the back of the unit? Letting them hang? About how much are they to replace?
  19. Jun 2, 2020 at 11:05 AM
    #2499
    TRSAndrew
    ATL
    Removing them, not relocating them. Yes you would then have hyperflash.
    If outside of warranty probably $10/ea. Otherwise the warranty will cover it.
    Cement baw[QUOTED] likes this.
  20. Jun 2, 2020 at 11:13 AM
    #2500
    Cement baw
    Appreciate it, Andrew. Now I am curious what hyper flashing sequentials look like. :anonymous:
    Ol'gray mare likes this.
