OFFICIAL XB LED HEADLIGHTS THREAD 16+
Discussion in 'Lighting' started by eledobleu, Feb 20, 2019.
  1. Jun 10, 2022 at 9:23 PM
    #2801
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    Got it. The thing I posted looks like it's for native drl strip halogen headlights, which mine aren't. I don't know if they sell a harness for OEM LED to Morimoto xb headlights.
    I'd reach out to @daveeasa for his input, this is more his wheelhouse
  2. Jun 11, 2022 at 1:39 AM
    #2802
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I don’t make a headlight conversion harness for trucks which came with OEM LED headlights.
  3. Jun 14, 2022 at 2:14 PM
    #2803
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    Did the morimoto xb gen 2 headlights have the option of ordering with the clear side marker? or was it only for the gen 1?
  4. Jun 23, 2022 at 12:59 PM
    #2804
    AM_Taco
    AM_Taco Well-Known Member
    2020 Tacoma TRD Off-Road
    I dont know if this has been answered already in this thread but do you think its possible to use the morimoto DRL in the 2020 LEDs? I just ordered a pair of the LEDs but like the sequential turn signal on the morimotos better than the LEDs. Just a thought. Would still have to source the DRLs somehow.
  5. Jun 29, 2022 at 9:28 PM
    #2805
    Action135
    Action135 New Member
    2020 TRD Offroad
    Got my set of XB headlights the other day, and they look terrific! Trouble I'm having is that when I went toadjust the headlights, two of the adjusters are not there. In their place are just some smooth round plastic pieces. I plan to contact morimoto tomorrow, but was curious if anyone else had run into this or if im just a moron missing something. Thanks!
  6. Jul 10, 2022 at 6:02 PM
    #2806
    rorgan
    rorgan Well-Known Member
    2022 tacoma TRDOR 4wd
    none yet
    I'm getting a new TDOR, but it does not come with the LED light package. I was looking at these as an option but from the post I see here it seems that they are not reliable? Will these be Plug and Play or do I have to tap into additional power to get the full functionality? I admit these things look really good but I don't want to spend 15 to $1,600 on something that's not going to last a long time. How do they compare to the factory LED headlights?
  7. Jul 10, 2022 at 7:11 PM
    #2807
    Integerdy
    Eric
    So-Lame, Oregon
    I have had mine for a year and have had zero issues with them. 100% plug and play. There is a fuse tap for sr5/sr models that don't have built in LED DRL's. Shouldn't need it on trd models. The fuse tap also powers the light dance start up sequence iirc. Not a difficult or invasive thing to install
  8. Jul 10, 2022 at 8:15 PM
    #2808
    rorgan
    none yet
    Are they a lot brighter than the stock LED headlights? Pictures I've seen they look great
  9. Jul 10, 2022 at 11:10 PM
    #2809
    Integerdy
    Eric
    So-Lame, Oregon
    The low and high beams are brighter but they have a sharper cut off line compared to OEM Leds.
  10. Jul 11, 2022 at 4:44 AM
    #2810
    rorgan
    none yet
    So it's a more concentrated beam? Would you say that's a good thing or a bad thing?
  11. Jul 11, 2022 at 10:17 AM
    #2811
    Integerdy
    Eric
    So-Lame, Oregon
    Oem vs morimoto is a choice to be made. Both pros and cons. I've never driven a taco with oems but I was going to go that route originally until I found a good deal on some xbs from a local TW Member.
    I know you want a definitive answer but you gotta go with your own gut on this purchase. Oems will require a custom harness from @Puppypunter or @daveeasa. Morimotos are good to go out of the box. Morimotos have amber drl options and non reflector leds and a brighter color temp, but oems have a better up light vs morimotos sharper cutoff line. Both gonna cost you between $1200-$1500 in the end
    Concrete_taco likes this.
  12. Jul 15, 2022 at 5:47 PM
    #2812
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    Anyone get a ton of RF interference when running DRL with the XB's? I've got a HAM radio in my truck and I expect to get a little noise from the LED's but If I leave the DRL lights on, it totally wipes out my reception. I've tried ferrite chokes and they had no effect at all. If I run with headlights on it cuts the interference by about 3/4 but not as good as everything off. It doesn't make a difference if the radio is wired direct to battery. In grill 30" light bar works great and has no effect at all on the radio. Any suggestions?
  13. Aug 6, 2022 at 4:08 PM
    #2813
    ViktorBreezeway
    ViktorBreezeway Brown Coat
    2017 Quicksand TRD OR DCSB
    I just received a set and had this issue as well with the high beams. Did you ever hear back?
  14. Aug 8, 2022 at 1:08 PM
    #2814
    Tacoma204
    Tacoma204 Active Member
    On the Gen2's, they are bi-LEDs so low and high are in the same projectors. I'm guessing when you adjust the low, the high just moves with it at a pre-defined offset. I just ordered an amber DRL set plus 4Banger HXB wide yellows (on the free 4Banger promo) so don't have them yet but I'm guessing that's how they work. If anyone confirms, please post so I'm not scratching my head as well when I install.
  15. Aug 8, 2022 at 1:24 PM
    #2815
    ViktorBreezeway
    I ordered the same setup. I was curious if that's how they worked. Not sure why they don't update their image for adjustment points to reflect the change.
    I got my order within 2 or 3 days so you shouldn't have to wait long.
  16. Aug 9, 2022 at 9:55 AM
    #2816
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Integerdy likes this.
  17. Aug 10, 2022 at 10:17 PM
    #2817
    Integerdy
    Eric
    So-Lame, Oregon
  18. Aug 18, 2022 at 11:06 PM
    #2818
    Taco & Salsa
    Taco & Salsa Well-Known Member
    Marcus
    San Antonio, TX
    2017 Black SR5 DCSB 4x4
    Just installed my Morimotos today. The light output is great but the cutoff is way too low and it seems on of the lights is too wide.
    does anyone know the proper procedure/process to adjust these?
  19. Aug 19, 2022 at 6:45 AM
    #2819
    tclavell
    Troy
    Phoenix, AZ
    G70
  20. Aug 19, 2022 at 8:47 AM
    #2820
    Taco & Salsa
    Marcus
    San Antonio, TX
    I did see that picture from their website. I was asking more about the process of alignment. Is is just trial and error, or are there dimensions/metrics that can be used to make sure the headlights are aligned properly?
