OFFICIAL XB LED HEADLIGHTS THREAD 16+
Discussion in 'Lighting' started by eledobleu, Feb 20, 2019.
  1. Dec 5, 2022 at 6:54 PM
    #2861
    hodo_taco
    hodo_taco Well-Known Member
    Colorado Springs, CO
    '16 SW Tacoma DCSBTRDOR
    Lot's o' plastidip.
    They're not. Also installed the Morimoto sequential mirror lights tonight at the same time. And my tail lights are OEM housing with Diode Dynamic LED bulbs.
    Also, fwiw they only hyper flash when using the turn signal stalk. If I press the hazards everything blinks normally.
  2. Dec 5, 2022 at 8:38 PM
    #2862
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    You probably need a resistor on the tails
    NightHawkTaco420 and hodo_taco like this.
  3. Dec 5, 2022 at 8:39 PM
    #2863
    hodo_taco
    Lot's o' plastidip.
    I'll give that a shot, appreciate it.
  4. Dec 5, 2022 at 11:55 PM
    #2864
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    Also dont use turn signals in reverse, this causes hyperflash with mine for some odd reason
    hodo_taco[QUOTED] likes this.
  5. Dec 6, 2022 at 7:19 PM
    #2865
    Mabel
    Mabel Well-Known Member
    Carlos
    Central Oregon
    2017 MGM Tacoma DCLB TRD Off Road
    I believe a resistor will solve this issue also.
  6. Dec 7, 2022 at 7:52 AM
    #2866
    Integerdy
    Eric
    So-Lame, Oregon
    Ya my stage 1 meso tails didn't come with connectors for them (older model? Idk)
    But I have only triggered the hyperflashing once intentionally testing, it hasn't happened naturally yet
    Mabel[QUOTED] likes this.
  7. Dec 8, 2022 at 10:19 AM
    #2867
    Mabel
    Carlos
    Central Oregon
    I noticed the same thing after I installed my MESO Stage 1 Tails also. I haven't contacted him, but I understand he'll send you the resistors if you ask. I have recreated this scenario only a couple random times 'in the wild', but it didn't bother me enough yet to do anything about it. :D
  8. Dec 8, 2022 at 4:44 PM
    #2868
    Integerdy
    Eric
    So-Lame, Oregon
    I bought mine 2nd hand from a fellow tw member. So I dunno if he will send em to me because of where I got them. But ya I've only managed to trigger it when intentionally trying to make them hyperflash lol
  9. Dec 13, 2022 at 10:30 AM
    #2869
    hodo_taco
    Lot's o' plastidip.
    This ended up correcting my issue. Thanks again!
    Mabel likes this.
  10. Dec 23, 2022 at 12:21 PM
    #2870
    2kolay
    2kolay Member
    Tony
    Arlington, VA
    2023 SR5 Trail Edition
    Just installed the morimoto v2 Amber drls on my 23 sr5 that had stock halogens..everything looks great but Im not able to get the sequential turn signal to work or the start up even after I unplug the connectors specified in the instructions.
    I also have the drl fuse tap installed. Anyone have an idea of why it’s not working?
  11. Dec 23, 2022 at 1:01 PM
    #2871
    2kolay
    2kolay Member
    Tony
    Arlington, VA
    Wow looks like I solved my first question on here. Apparently for my headlights to get the sequential turn signals the two sequence connectors need to be plugged into eachother. I could have sworn this was the opposite of the instructions and what I’ve read/seen
    tacotroy17 likes this.
  12. Dec 23, 2022 at 1:34 PM
    #2872
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    That is weird. They must've changed something
    2kolay[QUOTED] likes this.
  13. Dec 25, 2022 at 7:47 PM
    #2873
    baboolian
    baboolian Member
    Julian
    '22 TRD Sport 4x4 DCLB Lunar Rock
    Did you ever figure this out? I’ve got a 2022 with OEM LEDs and using the harness as well, so far I’m down 3 fuses from the high beams, and starting sequence doesn’t work either. Did you try the fuse tap, and if so which fuse did you tap into?
  14. Dec 26, 2022 at 2:58 PM
    #2874
    baboolian
    baboolian Member
    Julian
    Another pack of blown fuses later and I managed to figure it out!
    Morimoto botched it and reversed the polarity on the hi beam cable in their 2020+ harness (it’s the same on both of my harnesses). I flipped the hi beam adapter upside down, and suddenly my high beams work and no more blown fuses. I don’t feel great driving around like that, as the connection is not secure. I’ll try calling them when they open tomorrow and see what the deal is.
    For what it’s worth, I tried with and without the fuse tap. I noticed no difference with or without.
    The startup sequence never worked, with or without the tap.
    Everything else seems to work. To set the blinkers to sequential, do the exact opposite of what their “instructions” say.
  15. Dec 26, 2022 at 3:01 PM
    #2875
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    male H9 is easy to de-pin and swap. 1.5mm screwdriver is best but 2mm may work OK. Push the tab towards the midline while you pull back on the wire. Best to push the wire forward first. Do one side at a time. If you mangle the male h9, that's one part you can find easily or I can even send.
    Male h9's truly suck, it's not Toyota and I won't even blame Morimoto (other than screwing up polarity.)
    NOTE: Polarity of high and low beams is opposite, that's an odd Toyota thing. White w black stripe is always ground.
  16. Dec 26, 2022 at 8:40 PM
    #2876
    baboolian
    baboolian Member
    Julian
    Thanks for the tip! I’ll give it a shot when the rain subsides.
    Interesting, I don’t have a white with black stripe (or even white) on my high beam or low beam cabling. Here’s a photo: https://imgur.com/a/OYyOF2N This is with the high beam plugged in as designed, which fries my fuses. When I flip it around so red lines up with red and black with gray, the high beams work there’s just no locking mechanism to hold them together. On the low beams the wires are lined up by color already when plugged in the intended way. I’ll give ur tip a shot and try to reverse it in the housing cable side for the high beams, thanks again!
    Any ideas on getting the startup sequence to work? Not the end of the world, but would be nice if it worked.
  17. Dec 26, 2022 at 8:48 PM
    #2877
    daveeasa
    David
    PNW
    Ask Intergerdy for specifics on the assemblies, I don’t know anything about them.
    driver side white is high beam positive, red is low beam positive. Ground is always white w black stripe. Speaking of Oem wiring not any morimoto harness wires.
    passenger side high beam is yellow and low beam is blue.
    For a conversion harness with black for ground you want black to white w black stripe.
    if you look closely at the Oem female H9 (yellow high beam) vs h11 (green low beam) you’ll notice polarity is opposite. That’s how Toyota does it. A halogen filament doesn’t care about polarity.
  18. Jan 2, 2023 at 5:53 PM
    #2878
    elukianic
    elukianic Well-Known Member
    Eugene
    Tacoma ,WA
    2018 Toyota tacoma TRD Sport
    TRD pro grille Raptor grille lights TRD grill badge TRD rear emblem Rokblokz Mud flaps Tyger steel running boards Toyota black exhaust tip Blacked out emblems Black tailgate letter inserts Body armor 4x4 bumper Cali raised 22” light bar Prinsu roof rack Diode dynamics SS3 fog lights Auxbeam low beams LEDs AVS bug deflector AVS rain guards Led interior lights Led license plate and backup lights Seat covers Rough country bed cover Smoked Mirror sequential turn signals TRD pro rims on Falken Wildpeaks AlphaRex smoked taillights 6112 and 5160s and Icon AAL (2.5/1.5 inches lift) TRD Skid plate Magnet Phone holder Glove box organizers TRD Shift knob
    Hello guys just had the morimotos installed. The cut on left and right headlight don’t match. How do i adjust them?
  19. Jan 3, 2023 at 12:58 PM
    #2879
    CanadaToy
    Greg
    Toronto
    Did you already adjust to the right height, now they don't match?
  20. Jan 3, 2023 at 1:02 PM
    #2880
    elukianic
    Eugene
    Tacoma ,WA
    I adjusted them but on a wall 25 feet away the left headlight has like a weird streak up. So the left and right is not a straight line. It starts straight and then goes up a bit and then down again.I can send a picture later today.
