OFFICIAL XB LED HEADLIGHTS THREAD 16+
Discussion in 'Lighting' started by eledobleu, Feb 20, 2019.
  1. Jun 29, 2023 at 11:21 PM
    #2901
    giant22000
    giant22000 Member
    Thomas
    2023 Tacoma SR5 Silver
    Undercover ArmorFlex bed cover
    After reading up on these XB headlights and trying to understand their compatibility, I’m just looking for confirmation my understanding is correct.
    I have a 23 SR5 that DOES have “DRL Off” on the stalk but will still need to drl harness to the INJ fuse. Also I’m of the understanding that white drl’s wont work.
    Is my understanding correct?
  2. Jun 30, 2023 at 12:44 AM
    #2902
    StreetSr5
    StreetSr5 Well-Known Member
    Almost, the white drl works, my sr5 has the drl off on the stalk. The only way the Amber drl is on the sr5 is if you have the “daytime running lights” setting ON in the head unit. When it’s OFF like mine, the drl is white. 85027C0E-921A-4B91-BA55-57607C3C619B.jpg Using the inj fuse tap, the stalk controls on my sr5, with “daytime running light” setting OFF in the head unit is: drl off = white, auto = white, headlights and parking lights =white.
    When “daytime running lights” setting is ON inside the head unit, the stalk setting is as follows: drl off=white, auto+parking brake down= Amber, parking lights = Amber, headlights on =white.
    If you want the white drl, make sure you go inside your head unit and disengage the daytime running light setting. Basically on the sr/sr5 the daytime running light circuit is tied with the turn signal, as opposed the the trd models with the seperate led drl. I also recommend keeping the daytime running light setting off in the sr5 because the xb’s have a turn signal resistor, running them in Amber drl means the resister will get hot quickly, and could cause the headlight to fail.
    If you want the Amber drl, it’s probably better to order the Amber drl model, the white drl model is $1300 while the Amber drl model is $1500 on the morimoto website.
    giant22000[QUOTED] and Integerdy like this.
  3. Jun 30, 2023 at 12:57 AM
    #2903
    giant22000
    giant22000 Member
    Thomas
    Thank you for the detailed response!
    StreetSr5[QUOTED] likes this.
  4. Jul 10, 2023 at 7:37 PM
    #2904
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    2019 OR - Factory DRL. No fuse tap.
    Had the Gen 1's and everything worked fine.
    Swapping to the Gen 2's and the passenger side turn signal is blipping.
    Start-up sequence also not working.
    Low beams, high beams and DRL works.
    Just the turn signal. 4-way hazard. Lock/unlock. Just blips.
    Both sides has this harness. Matches the one from the Gen 1 I had installed. Even checked the one off the Gen 1. Same results.
    https://www.youtube.com/watch?v=ZJroPBqOmLI
    https://www.youtube.com/watch?v=9Nwe0-UaZKU
  5. Dec 10, 2023 at 8:16 AM
    #2905
    shingz_taco
    shingz_taco Active Member
    2021 VB Tacoma TRD OR
    Hey all! got a puzzling/funky situation.
    Working with a friend of mune who has a 2016 TRD Sport and were trying to install Morimoto XB LED v2 with the white DRL.
    Problems:
    Lows do not work at all
    High only works on drivers side
    Startup Sequence is not working
    What does work:
    DRL’s work
    Sequential Turn signals work
    Solutions Tried:
    Reversed polarity
    Checked all the fuses and they are good. (low fuses never blew but one high did during install)
    Please Help! LOL
  6. May 9, 2024 at 7:07 PM
    #2906
    Yodanator16
    Yodanator16 New Member
    21 Tacoma
    Hey guys, new here so rather than search through countless of forums I’d thought I’d just ask.
    Just installed the Amber DRL Morimoto headlights into my 21 Taco and I noticed that the DRL stays on even when the truck is still running but the headlight stalk is in the off position. Any fix for this? I still want the DRL to be on when I turn the headlight stalk to just the DRL without turning on the projectors. My old Alpharex headlights did that and I liked it.
    Thought about maybe just plugging it into a different fuse. Suggestions?
  7. May 9, 2024 at 8:20 PM
    #2907
    StreetSr5
    It’s because of the fuse tap you used. There isn’t any tap in the fuse box that will work as a drl. Is your truck and sr5 or trd model? If it’s a trd model ditch the fuse tap entirely and use the factory drl plug. If it’s an sr5 you’ll just have to live with the drls being on while in the off position
    Yodanator16[QUOTED] likes this.
  8. May 10, 2024 at 12:27 AM
    #2908
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    Don't use fuse tap = problem solved, but creates another problem with drl not being as bright white when you intentionally use them.
    Yodanator16 likes this.
  9. May 10, 2024 at 11:32 AM
    #2909
    Yodanator16
    21 Tacoma
    It’s a 2021 TRD Off Road model that had the halogen stock headlights. I don’t remember seeing a factory DRL plug. Where can I find that?
  10. May 10, 2024 at 12:39 PM
    #2910
    Concrete_taco
    Concrete_taco Well-Known Member
    CA
    2020 TRD Off Road
    Just ditch the fuse tap. I had initially installed using the fuse tap but removed it because the drls were constantly on and would occasionally turn on in the middle of the night.
    I removed the fuse tap and everything is peaches and works as expected, besides parking brake needs to be released to get the start up sequence. - 2020 off road with halogen stock headlights.
  11. May 10, 2024 at 2:06 PM
    #2911
    Integerdy
    Eric
    So-Lame, Oregon
    The fuse tap is really just for the start up sequence. And for sr5 models it gives us a brighter DRL since our drl signal is tied to our turn signal. Also it sounds like you tapped the fuse to the efi like their instructions say which is poor advice on their part. Best tap location is the ignition fuse
  12. May 10, 2024 at 3:48 PM
    #2912
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    INJ I believe, the fuel injector fuse.
  13. May 10, 2024 at 5:13 PM
    #2913
    StreetSr5
    IMG_3062.jpg This is the factory drl plug for the trd models, plug it into the headlight and unplug the fuse tap. You will have to reconnect the two plugs that the headlight came plugged in with where the fuse tap connects. Also yeah the drl wont come on until ebrake is released that’s how the factory drl is
  14. May 11, 2024 at 5:53 AM
    #2914
    Yodanator16
    21 Tacoma
    Yeah I just went based off the instructions. Do you know what’s the name of that fuse? I also have some grille lights tapped into another fuse.
  15. May 11, 2024 at 5:56 AM
    #2915
    Yodanator16
    21 Tacoma
    I see, so don’t use the fuse tap at all? Didn’t even know that was an option but based on what you’ve described that seems to be what I’m looking for. Thanks!
  16. May 11, 2024 at 9:57 AM
    #2916
    Integerdy
    Eric
    So-Lame, Oregon
    I have my grill lights tapped Into my lowbeams fuse for now. Eventually I'll get a t harness that taps em into something else.
    This is the inj fuse I tapped for morimotos
  17. May 19, 2024 at 4:12 PM
    #2917
    Ej8g82p
    Ej8g82p New Member
    Anybody else have an issue with the drivers side DRL partially going out?
    I got a 23 SR5 with gen 2s tapped into the INJ fuse for DRLs and with the headlight stalk in the auto position I lose a few LEDs in the drivers side DRL, but as soon as I switch the stalk to the DRL off position, the LEDs come back to life.
  18. May 19, 2024 at 7:01 PM
    #2918
    StreetSr5
    Definitely file a warranty claim thats not normal
    Integerdy likes this.
  19. May 19, 2024 at 7:31 PM
    #2919
    Ej8g82p
    Ej8g82p New Member
    Already got a replacement on the way. I was just curious if anyone else ran into an issue like that before. Hoping that this is a first and not something that is commonly found to fail.
  20. May 30, 2024 at 8:03 PM
    #2920
    808superwhite
    808superwhite Member
    Hi guys first time poster, long time lurker.
    I made a post if anyone could chime in that would be outstanding!
