OFFICIAL XB LED HEADLIGHTS THREAD 16+
Discussion in 'Lighting' started by eledobleu, Feb 20, 2019.
  1. Jun 2, 2019 at 7:15 PM
    #341
    Inferno75
    Inferno75 Well-Known Member
    Massachusetts
    2016 Trd sport double cab (premium and tech)
    K&n intake, full led replacement, interior custom orange carbon fiber kit, led roof bar...ditch pods...lower grill bar, meso add ons, custom raptor lights, bpf trd skid plate, trd shift knob, shift sense pro, redline triple reverse/brake/running lights strip on rear, custom switches, Tyger armor step sides, in Channel vent visors, strike plate covers, hood vinyl, custom American flag trailer hitch cover, graphite door sill vinyls, custom Tacoma dash insert(not vinyl), trd seat belt pads
    Believe they are spyders sold at Tacoma beast
    Caletaco[QUOTED] likes this.
  2. Jun 2, 2019 at 7:16 PM
    #342
    Inferno75
    Massachusetts
    Thx bud...they are egr fender flares
  3. Jun 2, 2019 at 11:14 PM
    #343
    2k19taco
    2k19taco Active Member
    Ij
    Central California
    2019 WHITE Tacoma TRD PRO
    285/70 R16 BFG KO2
    Any word on headlights now that it’s June?
  4. Jun 3, 2019 at 11:17 AM
    #344
    eledobleu
    eledobleu [OP] Well-Known Member
    Retrofit Wholesale
    No official word yet but TRS is receiving other XB headlight shipments so thats a good sign.
    Filterec, WHIT4K3R and ratcityrain like this.
  5. Jun 3, 2019 at 11:17 AM
    #345
    eledobleu
    Retrofit Wholesale
    Yes it has
  6. Jun 3, 2019 at 11:49 AM
    #346
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    I know this is an odd question, but is there going to be a way we can rewire the harness so that the drl's are full brightness at all times, even with parking or headlights on? I like to run with my parking lights on a lot of the times, but I want the drl's at full brightness at the same time rather than dimmed, but that is just me
    skynyrd87 likes this.
  7. Jun 3, 2019 at 12:32 PM
    #347
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    @LivinLoud
    LivinLoud likes this.
  8. Jun 3, 2019 at 12:55 PM
    #348
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    you can email the morimoto guys directly and they can answer that question.
    ratcityrain[QUOTED] likes this.
  9. Jun 3, 2019 at 12:56 PM
    #349
    ratcityrain
    Seattle, WA
    I will do that, but I'll wait until I have them in my possession
  10. Jun 3, 2019 at 4:35 PM
    #350
    WHIT4K3R
    WHIT4K3R Well-Known Member
    Saratoga Springs, UT
    2024 TRD Off-Road Hybrid - Bronze Oxide
    We’re getting closer! :yes:
    Inferno75 likes this.
  11. Jun 3, 2019 at 5:29 PM
    #351
    Inferno75
    Massachusetts
    lmk what you find out about that...love to know.
  12. Jun 4, 2019 at 12:46 PM
    #352
    eledobleu
    Retrofit Wholesale
    Should be as simple as adding a relay between the low and bright DRL's. There should be an official wire diagram when they are released but it wont be difficult. Before I stopped making them I used to be the #1 seller for the Tundra 14+ OEM LED headlight conversion kits. Most LED headlight designs are pretty straight forward.
  13. Jun 4, 2019 at 12:50 PM
    #353
    ratcityrain
    Seattle, WA
    Perfect. It was easy on the oemassive ones, just had to swap a wire in the harness on the housing side and it was done.
  14. Jun 4, 2019 at 12:51 PM
    #354
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    No relay required. Just 2 diodes and a quick wire jump.
  15. Jun 4, 2019 at 1:00 PM
    #355
    eledobleu
    Retrofit Wholesale
    Wow easier than I thought! Good to know thanks for sharing! Im assuming 1 diode for each side? What amps did you use? I used to use the 5a diodes for the OEM headlights and they worked flawlessly
  16. Jun 4, 2019 at 3:53 PM
    #356
    Larebel
    Larebel Member
    Larry
    2019 Black Tacoma TRD Off-Road DCSB
    I'm in, order number 7524.
  17. Jun 4, 2019 at 3:55 PM
    #357
    MESO
    State of Jefferson
    Yes. Just unplug the parking light wire from harness(headlight will see no Parking input and will not dim), add diode on the end and tap it into the DRL wire(100% bright) You will have to throw a diode on the DRL just so the parking doesn't back feed. I don't know why you'd want to do this because 100% output DRL at night is really bright and annoying.
    Vietguy likes this.
  18. Jun 4, 2019 at 6:18 PM
    #358
    eledobleu
    Retrofit Wholesale
    I won't do this personally, but its good to have this info available for those who want to this this mod. I agree that DRL's 100% at night is too bright!
  19. Jun 4, 2019 at 6:18 PM
    #359
    eledobleu
    Retrofit Wholesale
    Order received:thumbsup:
    Larebel[QUOTED] likes this.
  20. Jun 4, 2019 at 7:48 PM
    #360
    ratcityrain
    Seattle, WA
    I agre . I really want them full brightness when switch is on auto or parking lights and dim for headlights, but that's just me.
    eledobleu[QUOTED][OP] likes this.
