OFFICIAL XB LED HEADLIGHTS THREAD 16+
Discussion in 'Lighting' started by eledobleu, Feb 20, 2019.
  1. Jun 10, 2019 at 6:26 AM
    #401
    eledobleu
    eledobleu [OP] Well-Known Member
    Retrofit Wholesale
    *UPDATE*
    They are compatible with all models and are plug N play. Base models will have an amber drl apposed to white since they do not have stock led drl. I will post an example once made about which models will have what. This info is coming directly from MATT at TRS.
    Thorian and FishnTx like this.
  2. Jun 10, 2019 at 6:49 AM
    #402
    morcheez26
    morcheez26 Well-Known Member
    Brian
    New Orleans
    18 trd sport
    Well thats alot better info than the other thread gave us .. i was worried for a whole day :annoyed:
    Thorian likes this.
  3. Jun 10, 2019 at 6:58 AM
    #403
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    At this late in production and they are finding out what models are/are not supported....o_O
    I love Morimoto products, but I think they bit off a little more than they can chew expanding into so many different headlight categories too fast.
  4. Jun 10, 2019 at 7:04 AM
    #404
    eledobleu
    Retrofit Wholesale
    Agreed.
  5. Jun 10, 2019 at 7:23 AM
    #405
    Techsan
    Techsan Well-Known Member
    South Texas
    2017 BBPDC
    So if my SR5 doesn't have stock LED DRL's, I won't have the full functionality of the lights?? I'm stuck with amber DRL's?
    That is pure and total bullshit.
  6. Jun 10, 2019 at 7:30 AM
    #406
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    i remember there was a teaser pic of a SR with these headlights installed and they had white DRL's
    so will the amber DRL's still be on when the low/high beams are turned on? will they turn white?
    yeah, it's frustrating that these issues have come up now since i assumed prototypes were thoroughly tested. i'm afraid of what more is to come a few months after installing them. i better keep my stock ones around just in case.
  7. Jun 10, 2019 at 7:31 AM
    #407
    eledobleu
    Retrofit Wholesale
    Not exactly as different models have different features. Basically if you have a drl off option on your turn signal stock then they'll function normally. Base base models will be amber drls because they don't have this feature.
  8. Jun 10, 2019 at 7:32 AM
    #408
    Techsan
    South Texas
    2017 BBPDC
    As posted in the other thread, THIS is what I have.
  9. Jun 10, 2019 at 7:35 AM
    #409
    eledobleu
    Retrofit Wholesale
    Thanks for this post. Anyone who have these options in the it turn signal stalk will have functionality of the headlights as normal. I will use this picture in my example if you don't mind. As far as I know, only SR models will have amber drls
    Thorian likes this.
  10. Jun 10, 2019 at 7:36 AM
    #410
    Techsan
    South Texas
    2017 BBPDC
    You're more than welcome to use the picture.
    eledobleu[QUOTED][OP] likes this.
  11. Jun 10, 2019 at 7:40 AM
    #411
    SR has a DRL off option too
    https://imgur.com/lwsi5jU
  12. Jun 10, 2019 at 7:44 AM
    #412
    eledobleu
    Retrofit Wholesale
    I believe it depends on the year. Example, 2016/2017 may not have the options, but 18/19 may have the option. I have to check which years of the drl off options and will post once I confirm everything.
  13. Jun 10, 2019 at 8:02 AM
    #413
    Tim8
    Tim8 Well-Known Member
    SoCal
    2019 Dcsb 040 Pro
    Any updates on that first shipment?
  14. Jun 10, 2019 at 8:06 AM
    #414
    eledobleu
    Retrofit Wholesale
    Yes, the first 50 isn't available. They have already been sold mainly to TRS dealers. The first actual shipment is coming in by sea freight. Not exact ETA yet of the first shipment but hopefully soon.
    Tim8[QUOTED] likes this.
  15. Jun 10, 2019 at 8:13 AM
    #415
    MESO
    State of Jefferson
    Yeah I would figure the first 50 would be allocated to high volume dealers or whoever put orders in very first. Sea freight with customs, etc expect another 30 days:(
    Tim8 and eledobleu[QUOTED][OP] like this.
  16. Jun 10, 2019 at 8:33 AM
    #416
    Tim8
    SoCal
    2019 Dcsb 040 Pro
    Customs at the port can be a PIA, hopefully they don’t get flagged :fingerscrossed:
  17. Jun 10, 2019 at 8:42 AM
    #417
    MESO
    State of Jefferson
    Or tariffed to death
  18. Jun 10, 2019 at 11:22 AM
    #418
    eledobleu
    Retrofit Wholesale
    Heres a quick compatibility reference to help those understand if your truck is compatible with the XB Headlights.
  19. Jun 10, 2019 at 11:32 AM
    #419
    Techsan
    South Texas
    2017 BBPDC
    Just to ask it a little differently since your original statement mentioned LED DRL’s -
    If my stalk has the DRL/OFF position, but I do NOT currently have LED DRL’s, these XB headlights will still be compatible?
  20. Jun 10, 2019 at 11:37 AM
    #420
    eledobleu
    Retrofit Wholesale
    I mis-understood previously. According to Andrew it doesn't matter if you have stock LED DRL or halogen DRL. Because the XB LED DRL's functions from the stock system, if you have DRL option on the turn signal stock the headlights will function normally as it connects to the same system. It's those without this feature where it won't function normally.
