offroad axle to sport axle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by av8er2012, Jan 7, 2013.
  1. Jan 7, 2013 at 1:41 PM
    av8er2012
    av8er2012 [OP] Well-Known Member
    Nick
    Wasilla AK
    Impulse Red 05 TRD offroad
    icon coilovers, bilstein 5100 rear shocks, OME dakar leaf springs, ARB front bumper, Warn XD9000 winch, Heated mirror mod, Rear diff breather mod, fog light anytime mod, Alpine W203 headunit, boston SPZ front speakers, boston SL65 rear speakers, Jl Audio HD 750/1 and 600/4 amplifiers, JL Audio 10w6v2 sub in custom box white dash w/blue needles
    hey guys,
    im starting to get fed up with my e locker and looking into the options to get rid of it. I have an 05 offroad with the 8" e locker diff and im thinking of swapping to the 8.4" sport diff so i can throw an ARB lcoker in there and get rid of the electronics. ive seen plenty of threads where guys swapped out the entire axle from a sport and put in the e locker axle but nothing the other way around. has anyone here done it and if so where there any major issues or should this be a pretty straight forward thing? thanks for your help!
  2. Jan 7, 2013 at 1:43 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    it should be pretty simple.
  3. Jan 7, 2013 at 1:44 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    It should be easier than the opposite swap.
    Just gotta run an air line and the electronics to the compressor/switch.
    One thing to try though since I don't have a second gen and don't know about all the electronics gizmos and crap is to just unplug the eLocker at the pumpkin and make sure your 4x4 hi/low, ABS and all that still work. As far as the swap itself it'll be cake and you'll have a larger ring gear!
  4. Jan 7, 2013 at 1:47 PM
    av8er2012
    Nick
    Wasilla AK
    ya the air line and compressor dont concern me i can do that. i just want to make sure that if i dont have the e locker in there that my truck isnt going to throw a fit haha.
  5. Jan 7, 2013 at 1:51 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    From what I understand there both 8.4" axels
  6. Jan 7, 2013 at 1:56 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yep, that's why I suggested to pull the plug on the locker and try everything first.
    Nope.
    The TRD OR has a 8.0 ring gear, the TRD Sport has an 8.4" ring gear. Two different third members and different housings (slightly).
  7. Jan 7, 2013 at 2:03 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    there might be a way to close the circuit, similar to bypassing a clutch-start switch, just making a fake connection that when you push the button, you get a return signal.
    Haven't looked at my locker in a while, but if it's 2 wires, should be a quick job.
  8. Jan 7, 2013 at 2:08 PM
    av8er2012
    Nick
    Wasilla AK
    ya good idea. essentially id like to use the stock switch to engage the new locker. have one switch for the compressor then use the stock locker switch to engage it. since the locker is only engaged in 4 lo normaly i dont think not having the e locker there will make a difference. now if only i could find someone to trade axles with haha.
  9. Jan 7, 2013 at 2:08 PM
    av8er2012
    Nick
    Wasilla AK
    thanks ill do that
  10. Jan 7, 2013 at 2:22 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I believe the SR5 axle is the same 8.4" axle as the sport. Might be able to save some money by finding an open SR5 differential (although TRD Sport axles newer than 2008 will be open anyways, 2005 thru 2008 had a mechanical LSD).
  11. Jan 7, 2013 at 3:46 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    They're both 8" ring gears fwiw. Should bolt in. Abs brakes its all the same.
  12. Jan 7, 2013 at 3:57 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Depends on your definition of 8" I guess and how your round.
    The ring gears are NOT the same size. The 8.4" ring gear is 210mm (~8.25") compared to the 200mm (~7.9") ring gear in the 8" TRD OR.
  13. Jan 7, 2013 at 5:45 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    An SR5 or base model V6 6lug truck will have what you are looking for in an axle, since you are planning to ditch any mechanical LSD the sport might have. V6 only to match your gearing, if you are still stock 3.73s
    Should be easy to find someone to trade if yours is in decent condition.
  14. Jan 7, 2013 at 6:26 PM
    av8er2012
    Nick
    Wasilla AK
    well thats the other thing, i am still stock but id want to re gear to the 4.88 eventually so if i do get the arb locker do i do it now or should i wait till i re gear? can the locker work on either set of gears? ive found a couple axles here locally that are at a parts yard. basically 1095 for the drum to drum set up off a 2007 with the lsd in it. maybe i can sell the diff/gears that are in it and just put in my own 4.88 with the locker at once and save some time haha
  15. Jan 7, 2013 at 9:27 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    The gears aren't that much $$$ compared to locker and install. Do it all once.
  16. Jan 7, 2013 at 9:30 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  17. Jan 7, 2013 at 10:00 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Meh...to me without pictures it's just another myth.
    I still have a TRD ring gear in my garage. As I mentioned, it's a short hair less than 8", right arond 7 15/16. Yes, if you wanted to round it, you could round up and be at 8".
    That said....here's a picture of toyota ring gears stacked up against an D44 8.5.
    Front to back is IFS 7.5, 8.0, 8.4/8.25/T100/Tundra, and the rear is D44 8.5.
    So although it's not very much bigger, I'm pretty sure it is bigger than the 8.0. And yes again if you wanted to round it and call it 8" you could, but I still think it's a little bigger than the TRD 8.0"
    OP....sorry for the thread derailment.
    Ring gear sizes aside, I think Max and I will both agree the non-elocker third member is stronger than the elocker third.
  18. Jan 7, 2013 at 10:31 PM
    av8er2012
    Nick
    Wasilla AK
    ^^^ its no problem i like learning! I to agree the non e locker is stronger
  19. Jan 7, 2013 at 10:52 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Interdasting...
    They're both pissy little shits. :p
  20. Jan 8, 2013 at 1:06 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Subd
    May do this in the future...
