Offroad Characteristics
Discussion in '4th Gen. Tacomas (2024+)' started by PathFinder1776, May 31, 2023.
  1. May 31, 2023 at 9:01 AM
    PathFinder1776
    PathFinder1776 [OP] Well-Known Member
    Colorado Front Range
    2003 DCSB TRD OR 4WD
    TRD S/C & TRD Boost Gauge Snugtop Topper Chevy 63 Swap, Gen 1 Raptor Shocks Boxed rear frame Aluminum F/R bumpers, sliders AEM 340 Fuel Pump Odyssey 27F Battery Shifted LCAs UCAs Icon 2.5 Ext. Coilovers
    For those of us looking forward to some sucker taking the hit off the lot so that we can snag a 4G used and abuse it, it would be good to know what it's going to take to get these on a decent size tire and going some places.
    If you have key pieces of information to know what it will take to get one up and ready to run 35/37 or larger tires go ahead and add to the thread.
    -Rear axle. Sounds like the BD4 is a 9.5" ring gear
    -Front diff. Maybe the same as Tundra/Sequoia? -Likely 8.9"
    -Steering rack. Hopefully the same as Tundra/Sequoia or at least easily upgradeable
    -Tie rods. Look pretty much like the current ones in pictures I've seen. Easy upgrade.
    -Rear suspension. Looks like the 4 link setup will be really easy to coilover swap and get a decent amount of travel. Haven't seen much detail on the link configuration yet.
    - Frame. Fully boxed and welded should be a nice upgrade from the riveted mess that 2G/3G trucks have.
    - Bumpers. Front should be similar to a 3G. Rear should be an easy cut.
    -Trimming. Looks to have plenty of room to cut a lot back. Maybe even more clearance at the rear of the front wheel wells to simplify that a bit.
    -Gearing. What will stock gearing be and when will new gears be available.
    -Aftermarket. Remains to be seen, but I'm sure it won't take long for the usual companies to have LT kits, armor, gears, etc for them.
  2. Jun 2, 2023 at 10:45 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I heard the front diff will be likely the 8.9" that comes on other TNGA trucks
    PathFinder1776[OP] likes this.
