Offroad light oddity with a relay...
Discussion in 'Lighting' started by StandingCow, May 2, 2011.
  1. May 3, 2011 at 12:59 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Oh okay that make sense, just seems more complicated then it needs to be. :D
    Brie likes this.
  2. May 3, 2011 at 1:03 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    this is a problem.....power from the switch powers the relay
  3. May 3, 2011 at 1:08 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    john just do it properly the first time.....
    it should not be this hard.....
    power from aafuse to switch---then switch to relay
    power from battery to relay
    ground switch and relay
    ground lights to frame
    then run a power wire from relay to lights
    done....
    stop fucking around and do it right
    Brie likes this.
  4. May 3, 2011 at 1:19 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    also you original diagram is wrong.....
    85 and 86 are backwards that is all
  5. May 3, 2011 at 1:25 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    if i were you i would take a wire from your battery and connect it directly to your frame.....
    since you are a philly fan
  6. May 3, 2011 at 7:23 PM
    joes06tacoma
    Joe
    Central Coast, CA
    So, you connected 85 to battery positive, flip the switch and the lights come on? If so, then the terminal 86 is getting a ground from the switch, that means you have some wires mixed up at the switch.
    Just read the rest of it......I agree with the others....you need positive power at the switch and the switches ground is what causes the indicator light to come on inside the switch.
  7. May 3, 2011 at 7:48 PM
    StandingCow
    StandingCow [OP] Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Yea, I am grabbing an add-a-fuse tomorrow morning to grab power from the inside fuse panel (Rear window control which I don't even have in the truck).
    The switch has numbers 2,3,4... so I will try ground to 3, lights to 2, and fuse power to 4 (which is 85 of the relay).
    The ONLY reason (as others have mentioned) that it didn't work once I wired it up per my first diagram is because there was no power from the switch to the relay to allow the lights to get power. At least that is my understanding of it.
    Also, 85 and 86 being the coil, it shouldn't matter which is ground and which is load, right (Never mind Anthony answered this, it doesn't)? Like scott said, it shouldn't be this complicated at all, my first mistake was not using power from the switch to flip the relay.
    Oh well, I will know tomorrow. :)
  8. May 3, 2011 at 8:52 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Sounds like you are on the right track. Not sure about the numbers you have on the switch. The relay pin numbers are standard, but I have never seen a standard setup for a switch.
  9. May 3, 2011 at 9:05 PM
    StandingCow
    NJ
    I know. :/
    I couldn't find anything online, I am gonna research a bit more though.
    EDIT: In case any of you are following to learn: http://electronics.howstuffworks.co...teamrocs.com/technical/pages/relay_basics.htm
    So, I am confident that my setup is correct, the only slight concern I have is that I blew a low amp fuse, since the relay should have been fine on really low amperage... oh well.
    Brie likes this.
  10. May 3, 2011 at 10:10 PM
    Drunknsloth
    Retribution
    South West
    If it was the fuse for the switch then you shouldn't have blown it, something else is wrong. If it's the fuse from the power source to the relay then yeah try running 15A or 20A
  11. May 3, 2011 at 10:15 PM
    StandingCow
    NJ
    Nah, was the fuse for the power source to the relay. :)
    If I blew the fuse for the switch I would have thrown a fit.
  12. May 3, 2011 at 10:20 PM
    Drunknsloth
    Retribution
    South West
    Haha sounds like you got it then. Good luck!
  13. May 3, 2011 at 10:31 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
  14. May 3, 2011 at 11:37 PM
    StandingCow
    NJ
  15. May 3, 2011 at 11:39 PM
    #35
    brutalguyracing
    F.U> GUYZ
    broken mods
    yes that is a good dia...
  16. May 4, 2011 at 1:14 AM
    #36
    StandingCow
    NJ
    85 and 86 cannot be backwards, there is no backwards. :p
  17. May 4, 2011 at 5:00 AM
    #37
    brutalguyracing
    F.U> GUYZ
    broken mods
    Says the guy who can not wire a relay
    Brie likes this.
  18. May 4, 2011 at 6:22 AM
    #38
    StandingCow
    NJ
    :spy:
  19. May 4, 2011 at 7:44 AM
    #39
    brutalguyracing
    F.U> GUYZ
    broken mods
    :eek:
  20. May 4, 2011 at 4:31 PM
    #40
    StandingCow
    NJ
    It's done, its working, thanks all. :)
    They aren't very bright though... so once I save a bit of money I may have to upgrade the wiring to a heavier gauge and the lights.
